6594 Discussions
Extracting a feature map of Convolution layer by inputing differebt image size
timosy
I'd like to extract feature map from Convolution layer by inputting
larger or smaller image size which is different size when a model was trained.
segmentation_model = ie.read_model(model=inmodel)
segmentation_input_layer = next(iter(segmentation_model.inputs))
segmentation_output_layer = next(iter(segmentation_model.outputs))
print("~~~~ ORIGINAL MODEL ~~~~")
print(f"input shape: {segmentation_input_layer.shape}")
print(f"output shape: {segmentation_output_layer.shape}")
new_shape = PartialShape([1, 3, 448, 448])
segmentation_model.reshape({segmentation_input_layer.any_name: new_shape})
segmentation_compiled_model = ie.compile_model(model=segmentation_model, device_name="CPU")
# help(segmentation_compiled_model)
print("~~~~ RESHAPED MODEL ~~~~")
print(f"model input shape: {segmentation_input_layer.shape}")
print(
f"compiled_model input shape: "
f"{segmentation_compiled_model.input(index=0).shape}"
print(f"compiled_model output shape: {segmentation_output_layer.shape}")
I can reshape using ResNet50
But, I can't using AlexNet. I got following message...
RuntimeError: Check 'input_dim.get_length() % output_dim.get_length() == 0' failed at core/src/op/reshape.cpp:338:While validating node 'v1::Reshape 31 (30[0]:f32{1,256,13,13}, Constant_266[0]:i64{2}) -> (f32{?,?})' with friendly_name '31':
Non-'-1' output dimensions do not evenly divide the input dimensions
While validating node 'v1::Reshape 31 (30[0]:f32{1,256,8,8}, Constant_266[0]:i64{2}) -> (f32{?,?})' with friendly_name '31':
Labels (2)
