Face detection error
yleal
Hi, I am trying to run the model of face_detection_mtcnn_demo
but I get the following error:
[ INFO ] OpenVINO Runtime
[ INFO ] build: 2022.2.0-7713-af16ea1d79a-releases/2022/2
[ INFO ] Reading Proposal model /media/ssd/open_model_zoo/demos/face_detection_mtcnn_demo/python/openvino_env/lib/python3.8/site-packages/openvino/model_zoo/models/public/mtcnn/mtcnn-p
Traceback (most recent call last):
File "face_detection_mtcnn_demo.py", line 283, in <module>
sys.exit(main() or 0)
File "face_detection_mtcnn_demo.py", line 106, in main
p_net = core.read_model(args.model_pnet)
RuntimeError: [ NETWORK_NOT_READ ] Unable to read the model: /media/ssd/open_model_zoo/demos/face_detection_mtcnn_demo/python/openvino_env/lib/python3.8/site-packages/openvino/model_zoo/models/public/mtcnn/mtcnn-p Please check that model format: 8/site-packages/openvino/model_zoo/models/public/mtcnn/mtcnn-p is supported and the model is correct. Available frontends: paddle ir onnx
Can anyone help me, please??
Hairul_Intel
Hi yleal,
For your information, you need to download and convert the models into Intermediate Representation (IR) format before running the Face Detection MTCNN Python Demo.
Here is the command to download the model:
omz_downloader --list models.lst
Here is the command to convert the model into IR format:
omz_converter --list models.lst
To run the demo, provide paths to the model in the IR format (.xml), and to an input video or image(s):
python face_detection_mtcnn_demo.py -m_o public\mtcnn\mtcnn-o\FP16\mtcnn-o.xml -m_p public\mtcnn\mtcnn-p\FP16\mtcnn-p.xml -m_r public\mtcnn\mtcnn-r\FP16\mtcnn-r.xml -i video.mp4
Hairul
Hairul_Intel
Hi yleal,
Hairul
yleal
When I run that command I get this:
/media/ssd/open_model_zoo/demos/face_detection_mtcnn_demo/python/openvino_env/bin/omz_converter: 2: exec: /media/minsait/ce4fa857-5cbb-4591-b9b5-225656d17b2a/open_model_zoo/demos/face_detection_mtcnn_demo/python/openvino_env/bin/python3: not found
And I don't know how to solve it, could you help me??
Hairul_Intel
Hi yleal,
For your information, the 'omz_downloader' and 'omz_converter' commands are automation tools for downloading and converting models into IR format. These tools are only available from OpenVINO™ Development Tools.
On another note, please provide the following information:
  1. Operating System that you are using.
  2. Steps used when installing OpenVINO™ Toolkit.
  3. Steps for cloning the Open Model Zoo repository.
  4. The command that you are running when the error occurred.
Hairul
yleal
I did everything you explained me, thank you so much, but I still get an error:
File "face_detection_mtcnn_demo.py", line 190, in main
compiled_pnet = core.compile_model(p_net, args.device)
File "/media/ssd/openvino_env/lib/python3.8/site-packages/openvino/runtime/ie_api.py", line 387, in compile_model
super().compile_model(model, device_name, {} if config is None else config),
RuntimeError: Cannot load library 'libopenvino_intel_myriad_plugin.so: libopenvino_intel_myriad_plugin.so: cannot open shared object file: No such file or directory
when I try:
python3 face_detection_mtcnn_demo.py -i /media/ssd/open_model_zoo/models/intel/face-detection-0200/assets/face-detection-0200.png -m_r /media/ssd/public/mtcnn/mtcnn-r/FP16/mtcnn-r.xml -m_o /media/ssd/public/mtcnn/mtcnn-o/FP16/mtcnn-o.xml -m_p /media/ssd/public/mtcnn/mtcnn-p/FP16/mtcnn-p.xml -d MYRIAD --loop
What should I do?
Hairul_Intel
Hi yleal,
The previously reported error (shown below) is likely due to unsupported CPU hardware. Please refer to System Requirements for more information.
[INFO ] OpenVINO Runtime
[ INFO ] Reading Proposal model /media/ssd/public/mtcnn/mtcnn-p/FP16/mtcnn-p.xml
[ INFO ] Reading Refine model /media/ssd/public/mtcnn/mtcnn-r/FP16/mtcnn-r.xml
[ INFO ] Reading Output model /media/ssd/public/mtcnn/mtcnn-o/FP16/mtcnn-o.xml
[ INFO ] The Proposal model /media/ssd/public/mtcnn/mtcnn-p/FP16/mtcnn-p.xml is loaded to CPU
[ INFO ] The Refine model /media/ssd/public/mtcnn/mtcnn-r/FP16/mtcnn-r.xml is loaded to CPU
Illegal instruction (core dumped)
Hairul
Hairul_Intel
Hi yleal,
We have moved your subsequent question to a new thread (given below) so that we can provide better support.
https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/Re-Re-Help-on-face-detection-demo/m-p/1434333
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Hairul
