VGG16 CPU vs GPU latency & throughput
username_007
Probably a naive question. I am working with Openvino 2022.2. I have downloaded the VGG16 model using omz_downloader. I converted it to IR using the command
omz_converter --name vgg16
When I run a benchmark comparing my CPU and GPU using the following commands
benchmark_app.exe -m C:\Users\Sami\public\vgg16\FP16\vgg16.xml -d CPU
and
benchmark_app.exe -m C:\Users\Sami\public\vgg16\FP16\vgg16.xml -d GPU
I get the following results
CPU
CPUCPU
GPU
GPUGPU
I am a bit confused about these results. On the CPU the average latency is lower, and the throughput is also lower?
With low latency shouldn't the throughput be higher because it takes less amount of time per result (low latency)
Similarly for the GPU the latency and throughput are both high. Can anyone please explain this
My CPU is Intel 6500T and GPU is Intel HD Graphics 530.
Nothing fancy
Peh_Intel
Hi username_007,
Yes, you’re right. Latency measures the inference time (ms) required to process a single input if inferencing synchronously.
For your information, if running Benchmark App with default parameters, it is inferencing in asynchronous mode. Therefore, the calculated latency measures the total inference time (ms) required to process the number of inference requests.
In addition, 4 inference requests are created if running Benchmark App on CPU with default parameters while running Benchmark App on GPU with default parameters, 16 inference requests are created.
You can re-run Benchmark App by setting the same inference requests when inferencing on CPU and GPU and compare the inference results again.
benchmark_app.exe -m C:\Users\Sami\public\vgg16\FP16\vgg16.xml -d CPU -nireq 4
benchmark_app.exe -m C:\Users\Sami\public\vgg16\FP16\vgg16.xml -d GPU -nireq 4
Peh
Peh_Intel
Hi username_007,
This thread will no longer be monitored since we have provided answers. If you need any additional information from Intel, please submit a new question.
Peh
