6574 Discussions
Factors affecting the inference time by GPU plugin
liang__heng
when doing inference by GPU plugin,I test my program in diferent PCs and find the time cost is so differnt. I want to
 find the major factor affecting the inference time,can any one give me some adcice?
nikos1
Valued Contributor I
Hello Liang Heng,
What are the GPU models in the systems you are testing?
I think you will find in most cases GPU inference will be faster on GPUs with more EUs and/or higher GPU clock but there are many other factors too.
For details on GPU EU/Clock please refer to https://ark.intel.com/content/www/us/en/ark.html
Cheers,
Nikos
Shubha_R_Intel
Dear liang, heng,
In your experiments I assume that you're using the same image(s) each time. What nikos said is correct but also depending on the model you are using and the image sizes you are passing in, the GPU plugin optimizes models for certain ideal kernel sizes. It's best to feed in an image size which is optimal for the model.
You can also use the benchmark_app to perform experiments.
Hope it helps,
Shubha
