6597 Discussions
Faied for running "demo_squeezenet_download_convert_run.sh -d MYRIAD"
Murakawa__Ryo
Hi
I just start using NCS2 on my Ubuntu 16.0.4 server. When I following the steps in the documentation and run "./demo_squeezenet_download_convert_run.sh -d MYRIAD", I got the error below.
target = MYRIAD
target_precision = FP16
Downloading the Caffe model and the prototxt
Installing dependencies
Run sudo -E apt -y install build-essential python3-pip virtualenv cmake libpng12-dev libcairo2-dev libpango1.0-dev libglib2.0-dev libgtk2.0-dev libswscale-dev libavcodec-dev libavformat-dev libgstreamer1.0-0 gstreamer1.0-plugins-base
[sudo] password for murakawa:
Hit:1 http://ftp.jaist.ac.jp/pub/Linux/ubuntu xenial InRelease
Hit:2 http://ftp.jaist.ac.jp/pub/Linux/ubuntu xenial-updates InRelease
Hit:3 http://ftp.jaist.ac.jp/pub/Linux/ubuntu xenial-backports InRelease
Ign:4 http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1604/x86_64 ; InRelease
Hit:5 http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1604/x86_64 ; Release
Hit:7 http://security.ubuntu.com/ubuntu xenial-security InRelease
Reading package lists... Done
Building dependency tree
Reading state information... Done
37 packages can be upgraded. Run 'apt list --upgradable' to see them.
build-essential is already the newest version (12.1ubuntu2).
libcairo2-dev is already the newest version (1.14.6-1).
libpango1.0-dev is already the newest version (1.38.1-1).
cmake is already the newest version (3.5.1-1ubuntu3).
gstreamer1.0-plugins-base is already the newest version (1.8.3-1ubuntu0.2).
libglib2.0-dev is already the newest version (2.48.2-0ubuntu4.1).
libgstreamer1.0-0 is already the newest version (1.8.3-1~ubuntu0.1).
libgtk2.0-dev is already the newest version (2.24.30-1ubuntu1.16.04.2).
libpng12-dev is already the newest version (1.2.54-1ubuntu1.1).
libavcodec-dev is already the newest version (7:2.8.15-0ubuntu0.16.04.1).
libavformat-dev is already the newest version (7:2.8.15-0ubuntu0.16.04.1).
libswscale-dev is already the newest version (7:2.8.15-0ubuntu0.16.04.1).
python3-pip is already the newest version (8.1.1-2ubuntu0.4).
virtualenv is already the newest version (15.0.1+ds-3ubuntu1).
0 upgraded, 0 newly installed, 0 to remove and 37 not upgraded.
The directory '/home/murakawa/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/home/murakawa/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Requirement already satisfied: pyyaml in /usr/local/lib/python3.5/dist-packages (3.13)
Requirement already satisfied: requests in /usr/lib/python3/dist-packages (2.9.1)
Run /home/murakawa/intel/computer_vision_sdk/deployment_tools/demo/../model_downloader/downloader.py --name "squeezenet1.1" --output_dir "/home/murakawa/openvino_models/FP16"
###############|| Start downloading models ||###############
...100%, 9 KB, 74285 KB/s, 0 seconds passed ========= squeezenet1.1.prototxt ====> /home/murakawa/openvino_models/FP16/classification/squeezenet/1.1/caffe/squeezenet1.1.prototxt
###############|| Start downloading weights ||###############
...100%, 4834 KB, 5128 KB/s, 0 seconds passed ========= squeezenet1.1.caffemodel ====> /home/murakawa/openvino_models/FP16/classification/squeezenet/1.1/caffe/squeezenet1.1.caffemodel
###############|| Start downloading topologies in tarballs ||###############
###############|| Post processing ||###############
========= Changing input dimensions in squeezenet1.1.prototxt =========
Configure Model Optimizer
INTEL_CVSDK_DIR environment variable is not set. Trying to run ./setvars.sh to set it.
[setupvars.sh] OpenVINO environment initialized
Install Model Optimizer dependencies
python3-venv is already the newest version (3.5.1-3).
libgfortran3 is already the newest version (5.4.0-6ubuntu1~16.04.10).
Requirement already satisfied: networkx>=1.11 in /usr/local/lib/python3.5/dist-packages (from -r /home/murakawa/intel/computer_vision_sdk_2018.4.420/deployment_tools/model_optimizer/install_prerequisites/../requirements_caffe.txt (line 1)) (2.2)
Requirement already satisfied: numpy>=1.12.0 in /usr/local/lib/python3.5/dist-packages (from -r /home/murakawa/intel/computer_vision_sdk_2018.4.420/deployment_tools/model_optimizer/install_prerequisites/../requirements_caffe.txt (line 2)) (1.15.4)
Requirement already satisfied: protobuf==3.5.1 in /usr/local/lib/python3.5/dist-packages (from -r /home/murakawa/intel/computer_vision_sdk_2018.4.420/deployment_tools/model_optimizer/install_prerequisites/../requirements_caffe.txt (line 3)) (3.5.1)
Requirement already satisfied: decorator>=4.3.0 in /usr/local/lib/python3.5/dist-packages (from networkx>=1.11->-r /home/murakawa/intel/computer_vision_sdk_2018.4.420/deployment_tools/model_optimizer/install_prerequisites/../requirements_caffe.txt (line 1)) (4.3.0)
Requirement already satisfied: setuptools in /usr/lib/python3/dist-packages (from protobuf==3.5.1->-r /home/murakawa/intel/computer_vision_sdk_2018.4.420/deployment_tools/model_optimizer/install_prerequisites/../requirements_caffe.txt (line 3)) (20.7.0)
Requirement already satisfied: six>=1.9 in /usr/lib/python3/dist-packages (from protobuf==3.5.1->-r /home/murakawa/intel/computer_vision_sdk_2018.4.420/deployment_tools/model_optimizer/install_prerequisites/../requirements_caffe.txt (line 3)) (1.10.0)
[WARNING] All Model Optimizer dependencies are installed globally.
[WARNING] If you want to keep Model Optimizer in separate sandbox
[WARNING] run install_prerequisites.sh venv {caffe|tf|mxnet|kaldi|onnx}
Convert a model with Model Optimizer
Target folder /home/murakawa/openvino_models/ir/squeezenet1.1/FP16 already exists. Skipping IR generation../demo_squeezenet_download_convert_run.sh: line 181: If you want to convert a model again, remove the entire ${$ir_dir} folder. ${run_again}: bad substitution
Build Inference Engine samples
Target folder /home/murakawa/inference_engine_samples already exists. Skipping samples building.If you want to rebuild samples, remove the entire /home/murakawa/inference_engine_samples folder. Then run the script again
Run Inference Engine classification sample
Run ./classification_sample -d MYRIAD -i /home/murakawa/intel/computer_vision_sdk/deployment_tools/demo/../demo/car.png -m /home/murakawa/openvino_models/ir/squeezenet1.1/FP16/squeezenet1.1.xml
[ INFO ] InferenceEngine:
    API version ............ 1.4
    Build .................. 17328
[ INFO ] Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ]     /home/murakawa/intel/computer_vision_sdk/deployment_tools/demo/../demo/car.png
[ INFO ] Loading plugin
    Description ....... myriadPlugin
[ INFO ] Loading network files:
    /home/murakawa/openvino_models/ir/squeezenet1.1/FP16/squeezenet1.1.bin
[ INFO ] Preparing input blobs
[BMP] file is not bmp type
[ WARNING ] Image /home/murakawa/intel/computer_vision_sdk/deployment_tools/demo/../demo/car.png cannot be read!
[ ERROR ] Valid input images were not found!
Error on or near line 215; exiting with status 1
I can find the file "/home/murakawa/intel/computer_vision_sdk/deployment_tools/demo/../demo/car.png" and this file is png type.
This log says this script assumes the file type is bmp.  Currently I can't find how to resolve this.
Any advice or comment is helpful for me.
Regards.
nikogamulin
I had the same problem. After creating and running on new VM instance, it worked as expected.
Tegwyn_Twmffat
I have similar problem:
	API version ............ 1.2
	Build .................. 13911
	/home/tegwyn/openvino_models/ir/squeezenet1.1/squeezenet1.1.xml
	/home/tegwyn/openvino_models/ir/squeezenet1.1/squeezenet1.1.bin
[ WARNING ] Image is resized from (787, 259) to (227, 227)
[ INFO ] Batch size is 1
[ INFO ] Preparing output blobs
[ INFO ] Loading model to the plugin
[ ERROR ] The plugin does not support networks with FP32 format.
Supported format: FP16.
Error on or near line 210; exiting with status 1
It works OK with -d CPU but not -d MYRIAD .
cat <<EOF > 97-usbboot.rules
SUBSYSTEM=="usb", ATTRS{idProduct}=="2150", ATTRS{idVendor}=="03e7", GROUP="users", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1"
SUBSYSTEM=="usb", ATTRS{idProduct}=="2485", ATTRS{idVendor}=="03e7", GROUP="users", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1"
SUBSYSTEM=="usb", ATTRS{idProduct}=="f63b", ATTRS{idVendor}=="03e7", GROUP="users", MODE="0666", ENV{ID_MM_DEVICE_IGNORE}="1"
EOF
sudo cp 97-usbboot.rules /etc/udev/rules.d/
sudo udevadm control --reload-rules
sudo udevadm trigger
sudo ldconfig
rm 97-usbboot.rules
The above USB rules were set. I'm trying to test neural compute stick 2.
Any ideas at all would be much appreciated!
nikos1
Valued Contributor I
Hi gg,
Please try FP16  IR for MYRIAD plugin on the NCS2
Robinson__Michael
I just finished all the steps for the install and I am attempting to run ./demo_squeezenet_download_convert_run.sh -d MYRIAD
I am getting this error message.
[ ERROR ] The "/home/kaesgg/openvino_models/models/FP16/classification/squeezenet/1.1/caffe/squeezenet1.1.caffemodel" is not existing file
Any suggestions?
Melcon__Ruben
Hi Ryo:
The demo that you are trying to execute is trying to use an image, so you will need to install the opencv library. After this step, you should be able to execute the demo. Please, could you try this step and confirm that it works?
Thank you
manzano__juan
Did you fix it Michael RObinson?? I am having the same problem now and I can't find help
Any suggestions?
