6580 Discussions
Failed(code:126) to load Jobmodule_detector_yalo_openvino.dll
WeiSeng
Hi Team,
When we try to build openVINO project detected error:
Any suggestion?
Picture attached.
Zulkifli_Intel
Hi WeiSeng,
Please share with us these details for further investigation:
  • Are you trying to build OpenVINO Samples and Demos or your own project?
  • Which OpenVINO version did you use?
  • Operating System
Zulkifli
WeiSeng
Hi Zulkifli,
Thanks for your support, please find a reply.
  • Are you trying to build OpenVINO Samples and Demos or your own project?[Reply] We're try to build demo based on OpenVINO.
  • Which OpenVINO version did you use?[Reply] The openVINO is 2023.1.0
  • Operating System[Reply] Is Windows 10 and Visual Studio env.
Thanks!
Zulkifli_Intel
Hi Weiseng,
Can you share all the related files to build the demo and the steps to replicate the issue?
Zulkifli
WeiSeng
Hi Zulkifli,
Thanks for supporting.
This is customer projects and using the VC++ for development.
For this issue, is like path configuration issue.
Maybe you have some guide how to configure the path on the DLL file?
Many Thanks!
Zulkifli_Intel
Hi WeiSeng,
Sorry for the delay.
A lot of users faced the same error with code 126. Here is one of the suggested workaround to identify the cause. Use the sysinternals utility Process Monitor https://learn.microsoft.com/en-us/sysinternals/downloads/procmon from Microsoft to trace all file access while your DLL is trying to load. With this utility, you will see everything that DLL is trying to pull in, and usually, the problem can be determined from there. You can refer to this comment. "
In StackOverflow, there is a discussion related to setting the path to the DLL file in Visual Studio. I hope this info helps.
Zulkifli
WeiSeng
Hi Zulkifli,
Actually, the customer still facing this "Jobmodule_detector_yolo_openvino.dll" load fail.
Has your time had anyone using this DLL before?
Any suggestions?
Thanks!
Zulkifli_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
