Failed to allocate graph: NC_ERROR
Hellmark__jacob
When i run sudo ./demo_security_barrier_camera.sh -d MYRIAD i get this error:
E: [xLink] [    974908] dispatcherEventSend:924    Write failed header -1 | event XLINK_WRITE_REQ
E: [xLink] [    974908] eventSchedulerRun:584    Event sending failed
E: [xLink] [    975084] handleIncomingEvent:279    handleIncomingEvent() Read failed -4
E: [xLink] [    975084] dispatcherEventReceive:347    dispatcherEventReceive() Read failed -4 | event 0x7f2a5e029c60 XLINK_WRITE_REQ
E: [xLink] [    975084] eventReader:233    eventReader stopped
E: [xLink] [    975084] XLinkReadDataWithTimeOut:1343    Event data is invalid
E: [ncAPI] [    975084] ncGraphAllocate:1822    Can't read input tensor descriptors of the graph, rc: X_LINK_ERROR
[ ERROR ] Failed to allocate graph: NC_ERROR
Error on or near line 228; exiting with status 1
when it tries to load Vehicle Detection to the MYRIAD plugin
a while a go everyting worked fine but now suddenly i got this error
anyone have a sulution
Shubha_R_Intel
Dear Hellmark, jacob,
First of all, did you upgrade your Linux OS ? What version of OpenVino are you using ? It could be your usb boot rules. Kindly check the below document:
http://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux.html#additional-NCS-steps
Hope it helps,
Shubha
