Failed to create plugin MKLDNNPlugin.dll
adrian2
Hi, I've just installed version 2020 of OpenVINO Toolkit according to the installation guide at here, all of the steps goes well until running the two verification script. I got an error that said something like
Failed to create plugin MKLDNNPlugin.dll for device CPU
Please check your environment
cannot load library <path to openvino mkldnn>\mkldnnplugin.dll
on the last part of "demo_squeezenet_download_convert_run.bat", I've also tried to run "demo_security_barrier_camera.bat" and got the same error. Can anyone help me? Thanks!
OS: Windows 10 64-bit
Processor: Intel Atom x5-z8350
Max_L_Intel
Hi Adrian.
Have you followed "Set the Environment Variables" step? https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_windows.html#set-the-environment-variables
OpenVINO toolkit environment variables are removed when you close the Command Prompt window. As an option, you can permanently set the environment variables manually.
zhang__duoduo
Hi,I have the same problem,I'm sure I have followed "Set the Environment Variables" step,and I can run correctly under debug,but  have error under release:
无法定位程序输入点
?fill@numa_topology@internal@tbb@@YAXPEAH@Z于动态链接库C:\Program Files(x86)\...\Release\MKLDNNPlugin.dll上
Max_L_Intel
无法定位程序输入点
Hello, zhang, duoduo
Can I please take a look at program's full command line output (demo security barrier camera or squeezenet download convert run)?
And please also specify what CPU do you use in your system?
adrian2
Max L. (Intel) wrote:
Hi Adrian.
Have you followed "Set the Environment Variables" step? https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_...
Yes, I have followed the set environment from bin/setupvars.bat, and I still have the same error
Max_L_Intel
Hi Adrian.
This error might be related to the fact that Atom x5-z8350 processor does not support AVX instructions that required for Model Optimizer usage. And as I see, demo_squeezenet_download_convert_run.sh uses Model Optimizer for model conversion.
This is a known limitation described here https://docs.openvinotoolkit.org/latest/_docs_MO_DG_Known_Issues_Limitations.html
However, demo security barrier camera script should not have any references to Model Optimizer, since it downloads the model already converted to IR format.
So please double confirm if you see the same error message using demo security barrier camera. And if so, please provide us with a full command's output.
Best regards, Max.
aag
This isn't just MO. Inference Engine fails on CPUs without AVX2 as well - https://github.com/opencv/dldt/issues/387
aag
So, it seems like this isn't fixed in 2020.2 (based on the reports here - https://github.com/opencv/dldt/issues/387#issuecomment-613432147 )... any idea when we may expect the fix?
rizk__abdelrazek
can not use openvino in my computer after windows update to 1909
I was able to use openvino v 2019 with my old build
