6583 Discussions
ImportError when running OpenVino face recognition python demo
vinsonlau99
When I was trying to run the face recognition python demo, it shows this error message: "ImportError: DLL load failed: The specified module could not be found" as provided in the image.
SIRIGIRI_V_Intel
Hi Vinsonlau,
It seems to be an issue with scipy library. Please install the libraries as per the requirements.txt.
If you are still facing the issue, please re-install again.
We recommend to use the latest OpenVINO(2020.2) version.
Ram prasad
vinsonlau99
Hi Ram, I tried reinstalling the latest OpenVINO but it still gives me the same error. Do you have other alternatives?
SIRIGIRI_V_Intel
Since you are using the scipy library through Anaconda, Please make sure that you are using the scipy>1.1.0. if not, Could you please re-install the Anaconda with the required scipy version.
Ram prasad
vinsonlau99
My current scipy version is 1.4. I solved it by reinstalling it to scipy 1.1.0 without reinstalling Anaconda. Thank you so much!
SIRIGIRI_V_Intel
I was glad that you have solved. Thank you for sharing with the community.
Ram prasad
