6595 Discussions
How to enable the Post-Training Optimization Tool?
11792097
I have installed the Accuracy Checker Tool and Post-Training Optimization Toolkit successfully now. I can also run the Accuracy Checker Sample successfully to get the right 75.02% accuracy.
But when I launch the command-line tool with the configuration file running the following command:
pot -c /home/xu/Desktop/quantize/sample_config.yml
The log information is shown as below. It seems that there is someting wrong with the configuration file sample_config.yml. (Note that I have modified the related file paths in the configuration file sample_config.yml such as: model, weights and datasets following the guides)
14:16:44 accuracy_checker WARNING: /usr/local/lib/python3.5/site-packages/pot-1.0-py3.5.egg/compression/algorithms/quantization/optimization/algorithm.py:44: UserWarning: Nevergrad package could not be imported. If you are planning to use theFQ range optimization algo, consider installing itusing pip. This implies advanced usage of the tool.Note that nevergrad is compatible only with Python 3.6+
  'Nevergrad package could not be imported. If you are planning to use the'
Traceback (most recent call last):
  File "/usr/local/bin/pot", line 11, in <module>
    load_entry_point('pot==1.0', 'console_scripts', 'pot')()
  File "/usr/local/lib/python3.5/site-packages/pot-1.0-py3.5.egg/app/run.py", line 36, in main
    app(sys.argv[1:])
  File "/usr/local/lib/python3.5/site-packages/pot-1.0-py3.5.egg/app/run.py", line 43, in app
    config = Config.read_config(args.config)
  File "/usr/local/lib/python3.5/site-packages/pot-1.0-py3.5.egg/compression/configs/config.py", line 46, in read_config
    cls._configure_engine_params(config)
  File "/usr/local/lib/python3.5/site-packages/pot-1.0-py3.5.egg/compression/configs/config.py", line 231, in _configure_engine_params
    self._configure_ac_params()
  File "/usr/local/lib/python3.5/site-packages/pot-1.0-py3.5.egg/compression/configs/config.py", line 258, in _configure_ac_params
    ConfigReader.check_local_config(ac_conf)
  File "/opt/intel/openvino_2020.2.120/deployment_tools/open_model_zoo/tools/accuracy_checker/accuracy_checker/config/config_reader.py", line 198, in check_local_config
    config_checker_func(config)
  File "/opt/intel/openvino_2020.2.120/deployment_tools/open_model_zoo/tools/accuracy_checker/accuracy_checker/config/config_reader.py", line 140, in _check_models_config
    raise ConfigError('Each model must specify {}'.format(', '.join(required_model_entries)))
accuracy_checker.config.config_validator.ConfigError: Each model must specify name, launchers, datasets
So how to solve this problem? Any sugguestion?
Thanks!
SIRIGIRI_V_Intel
Could you please follow the Documentation and provide the config file with the parameters required.
Ram prasad
Mingming_X_Intel
Ram prasad
Hi, Ram prasad,
Thanks for your help!
Sorry to use incorrect configuration file yesterday. Now I use a correct configruation file named sample.json defined by myself. I run the command line as below to quantize deeplabv3 model downloaded from open model zoo:
python3 downloader.py --name deeplabv3
python3 converter.py --name deeplabv3 --mo /opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer/mo.py
pot -c /home/xu/Desktop/quantize/sample.json --output-dir /home/xu/Desktop/quantize
I attach the content of sample.json as below:
    "model": {
        "model_name": "deeplabv3",
        "model": "/opt/intel/openvino_2020.2.120/deployment_tools/tools/post_training_optimization_toolkit/libs/open_model_zoo/tools/downloader/public/deeplabv3/FP32/deeplabv3.xml",
        "weights": "/opt/intel/openvino_2020.2.120/deployment_tools/tools/post_training_optimization_toolkit/libs/open_model_zoo/tools/downloader/public/deeplabv3/FP32/deeplabv3.bin"
    "engine": {
        "type": "simplified",
        // you can specify path to directory with images or video file
        // also you can specify template for file names to filter images to load
        // templates are unix style
        "data_source": "<PATH_TO_DATASET>''
    "compression": {
        "target_device": "CPU",
        "algorithms": [
                "name": "DefaultQuantization",
                "params": {
                    "preset": "performance",
                    "stat_subset_size": 300
But I don’t know how to config the "data_source": "<PATH_TO_DATASET>'' here. I don’t want to use the accuracy checker tool, so I set the "engine" to "simplified" mode. Why do I still need the dataset to enable the Post-Training Optimization Tool? And how to set the "data_source" for deeplabv3 model?
Thanks!
Mingming (11792097)
SIRIGIRI_V_Intel
The dataset is used to collect statistics during the quantization process. Please use the dataset or the path to directory of images.
Please refer the Model Optimization flow
Hope this helps.
Ram prasad
Mingming_X_Intel
Hope this helps.
Ram prasad
Hi, Ram prasad,
Thanks very much! I did it as you said successfully.
Mingming
SIRIGIRI_V_Intel
I was glad that worked for you. Thank you for sharing with the community.
Ram prasad
