Failing to run a very simple Keras example
I'm moving the first steps in deep learning with Movidius stick, and I'm stuck in this very simple problem..
I have this very simple code in Keras:
import numpy as np
np.random.seed(123) # for reproducibility
from keras.models import Sequential
from keras.layers import Dense, Dropout, Activation, Flatten
from keras.layers import Convolution2D, MaxPooling2D
from keras.utils import np_utils
from keras.datasets import mnist
4. Load pre-shuffled MNIST data into train and test sets
(X_train, y_train), (X_test, y_test) = mnist.load_data()
5. Preprocess input data
X_train = X_train.reshape(X_train.shape[0], 28, 28, 1)
X_test = X_test.reshape(X_test.shape[0], 28, 28, 1)
X_train = X_train.astype('float32')
X_test = X_test.astype('float32')
X_train /= 255
X_test /= 255
6. Preprocess class labels
Y_train = np_utils.to_categorical(y_train, 10)
Y_test = np_utils.to_categorical(y_test, 10)
7. Define model architecture
model = Sequential()
model.add(Convolution2D(32, 3, 3, activation='relu', input_shape=(28,28,1), name="input"))
model.add(Convolution2D(32, 3, 3, activation='relu'))
model.add(MaxPooling2D(pool_size=(2,2)))
model.add(Dropout(0.25))
model.add(Flatten())
model.add(Dense(128, activation='relu'))
model.add(Dropout(0.5))
model.add(Dense(10, activation='softmax', name="output"))
8. Compile model
model.compile(loss='categorical_crossentropy',
optimizer='adam',
metrics=['accuracy'])
9. Fit model on training data
model.fit(X_train, Y_train,
batch_size=32, epochs=1, verbose=1)
10. Evaluate model on test data
score = model.evaluate(X_test, Y_test, verbose=0)
model_json = model.to_json()
with open("model.json", "w") as json_file:
json_file.write(model_json)
model.save_weights("model.h5")
I'm trying to generate a graph file using this tool: https://github.com/ardamavi/Intel-Movidius-NCS-Keras
But when it run mvNCCompile I get this error: KeyError: "The name 'input:0' refers to a Tensor which does not exist. The operation, 'input', does not exist in the graph."
Can you help me?
Thank you
Sorry for my ignorance, I solved.. I just turned the model into functional keras mode and removed Dropouts layers.
