6605 Discussions
Faster R-CNN Inception V2 custom trained, conversion in OV 1.1.
Pise__Abhijeet
I am using Openvino R1.1 to convert a custom trained faster rcnn inception v2 model.
I have used the models zoo as a checkpoint with reduced no of classes. I am using TF 1.14 for training and I have TF 1.15 in the OpenVino envt.
I am able to generate the .bin and .xml files. However when i am running inference, using the below lines
plugin_dir = r'C:\Program Files (x86)\IntelSWTools\openvino_2019.1.148\deployment_tools\inference_engine\bin\intel64\Release'
model_xml = '.\frozen_inference_graph.xml'
model_bin = '.\frozen_inference_graph.bin'
plugin = IEPlugin("CPU")
plugin.add_cpu_extension(r"C:\Program Files (x86)\IntelSWTools\openvino_2019.1.148\deployment_tools\inference_engine\bin\intel64\Release\cpu_extension_avx2.dll")
net = IENetwork(model=model_xml, weights=model_bin)
I get the below error:
Traceback (most recent call last):
  File "infer.py", line 15, in <module>
  File "ie_api.pyx", line 271, in openvino.inference_engine.ie_api.IENetwork.__cinit__
RuntimeError: Error reading network: in Layer FirstStageFeatureExtractor/InceptionV2/InceptionV2/Conv2d_1a_7x7/Relu: trying to connect an edge to non existing output port: 8.5
I would be grateful if you could help.
Munesh_Intel
Hi Abhijeet,
Thanks for reaching out.
I would suggest you use Intel® Distribution of OpenVINO™ Toolkit version 2020.3 LTS, which is a vastly improved version with latest features and leading performance.
As for your question regarding the .json files, the <INSTALL_DIR>/deployment_tools/model_optimizer/extensions/front/tf directory contains .json files for the models downloaded from the TensorFlow Object Detection API zoo.
More information can be obtained at the following page:
https://docs.openvinotoolkit.org/2020.3/_docs_MO_DG_prepare_model_convert_model_tf_specific_Convert_Object_Detection_API_Models.html#how_to_convert_a_model
Munesh
Pise__Abhijeet
Also, what purpose do the other json files with versions in extensions\front\tf folder serve? I am using faster_rcnn_support.json
Munesh_Intel
Hi Abhijeet,
Munesh
Pise__Abhijeet
Thank you Munesh for your prompt response.
