Faster RCNN with resnet 101 IR conversion issues
Kulkarni__Vinay
Hi ,
    I am using openvino latest Release R2, on windows 10 machine.
I tried converting the fasterRCNN with resnet 101 of .pb to IR format. But getting issues as follows :
The .pb is from :   https://storage.googleapis.com/intel-optimized-tensorflow/models/resnet101_fp32_pretrained_model.pb
(tf_1.14) C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\install_prerequisites>python ..\mo.py --input_model C:\Users\GF63\Documents\Intel\OpenVINO\faster_rcnn_resnet101_coco_2018_01_28\frozen_inference_graph.pb --input_shape (100,224,224,3) --output_dir D:\Openvino\ --log_level DEBUG
[ 2019-08-21 15:09:20,540 ] [ DEBUG ] [ main:134 ]  Namespace(batch=None, blobs_as_inputs=False, caffe_parser_path='..\\mo\\front\\caffe\\proto', counts=None, data_type='float', disable_fusing=None, disable_gfusing=None, disable_nhwc_to_nchw=False, disable_omitting_optional=False, disable_resnet_optimization=False, enable_concat_optimization=False, enable_flattening_nested_params=False, enable_ssd_gluoncv=False, extensions='C:\\Program Files (x86)\\IntelSWTools\\openvino\\deployment_tools\\model_optimizer\\extensions', finegrain_fusing=None, framework='tf', freeze_placeholder_with_value=None, generate_deprecated_IR_V2=None, generate_experimental_IR_V10=False, input=None, input_checkpoint=None, input_meta_graph=None, input_model='C:\\Users\\GF63\\Documents\\Intel\\OpenVINO\\faster_rcnn_resnet101_coco_2018_01_28\\frozen_inference_graph.pb', input_model_is_text=False, input_proto=None, input_shape='(100,224,224,3)', input_symbol=None, k='..\\extensions\\front\\caffe\\CustomLayersMapping.xml', keep_quantize_ops_in_IR=False, keep_shape_ops=False, legacy_mxnet_model=False, log_level='DEBUG', mean_file=None, mean_file_offsets=None, mean_values=(), model_name=None, move_to_preprocess=False, nd_prefix_name=None, output=None, output_dir='D:\\Openvino\\', pretrained_model_name=None, remove_output_softmax=False, reverse_input_channels=False, save_params_from_nd=False, saved_model_dir=None, saved_model_tags=None, scale=None, scale_values=(), silent=False, tensorboard_logdir=None, tensorflow_custom_layer_libraries=None, tensorflow_custom_operations_config_update=None, tensorflow_object_detection_api_pipeline_config=None, tensorflow_operation_patterns=None, tensorflow_subgraph_patterns=None, tensorflow_use_custom_operations_config=None, version=False)
[ 2019-08-21 15:09:20,540 ] [ DEBUG ] [ main:135 ]  Model Optimizer started
[ 2019-08-21 15:09:20,540 ] [ DEBUG ] [ main:149 ]  Output model name would be frozen_inference_graph{.xml, .bin}
Model Optimizer arguments:
Common parameters:
        - Path to the Input Model:      C:\Users\GF63\Documents\Intel\OpenVINO\faster_rcnn_resnet101_coco_2018_01_28\frozen_inference_graph.pb
        - Path for generated IR:        D:\Openvino\
        - IR output name:       frozen_inference_graph
        - Log level:    DEBUG
        - Batch:        Not specified, inherited from the model
        - Input layers:         Not specified, inherited from the model
        - Output layers:        Not specified, inherited from the model
        - Input shapes:         (100,224,224,3)
        - Mean values:  Not specified
        - Scale values:         Not specified
        - Scale factor:         Not specified
        - Precision of IR:      FP32
        - Enable fusing:        True
        - Enable grouped convolutions fusing:   True
        - Move mean values to preprocess section:       False
        - Reverse input channels:       False
TensorFlow specific parameters:
        - Input model in text protobuf format:  False
        - Path to model dump for TensorBoard:   None
        - List of shared libraries with TensorFlow custom layers implementation:        None
        - Update the configuration file with input/output node names:   None
        - Use configuration file used to generate the model with Object Detection API:  None
        - Operations to offload:        None
        - Patterns to offload:  None
        - Use the config file:  None
Model Optimizer version:        2019.2.0-436-gf5827d4
[ 2019-08-21 15:09:21,453 ] [ DEBUG ] [ main:235 ]  Placeholder shapes : [100 224 224   3]
[ INFO ]  Importing extensions from: C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo
[ INFO ]  New subclass: <class 'extensions.ops.gather.Gather'>
[ INFO ]  Registered a new subclass with key: Gather
[ INFO ]  New subclass: <class 'mo.ops.const.Const'>
[ INFO ]  Registered a new subclass with key: Const
[ INFO ]  New subclass: <class 'extensions.ops.transpose.Transpose'>
[ INFO ]  Registered a new subclass with key: Transpose
[ INFO ]  New subclass: <class 'mo.ops.reshape.Reshape'>
[ INFO ]  Registered a new subclass with key: Reshape
[ INFO ]  New subclass: <class 'mo.ops.scale_shift.ScaleShiftOp'>
[ INFO ]  Registered a new subclass with key: ScaleShift
[ INFO ]  New subclass: <class 'mo.ops.clamp.Clamp'>
[ INFO ]  Registered a new subclass with key: Clamp
[ INFO ]  New subclass: <class 'extensions.ops.activation_ops.Activation'>
[ INFO ]  New subclass: <class 'extensions.ops.activation_ops.LeakyReLU'>
[ INFO ]  Registered a new subclass with key: LeakyReLU
[ INFO ]  New subclass: <class 'mo.ops.concat.Concat'>
[ INFO ]  Registered a new subclass with key: Concat
[ INFO ]  New subclass: <class 'mo.ops.convolution.Convolution'>
[ INFO ]  Registered a new subclass with key: Convolution
[ INFO ]  New subclass: <class 'mo.ops.crop.Crop'>
[ INFO ]  Registered a new subclass with key: Crop
[ INFO ]  New subclass: <class 'mo.ops.softmax.Softmax'>
[ INFO ]  Registered a new subclass with key: SoftMax
[ INFO ]  New subclass: <class 'extensions.ops.elementwise.Elementwise'>
[ INFO ]  New subclass: <class 'mo.ops.activation.Activation'>
[ INFO ]  Registered a new subclass with key: Activation
[ INFO ]  New subclass: <class 'mo.ops.broadcast.Broadcast'>
[ INFO ]  Registered a new subclass with key: Broadcast
[ INFO ]  New subclass: <class 'mo.ops.deconvolution.Deconvolution'>
[ INFO ]  Registered a new subclass with key: Deconvolution
[ INFO ]  New subclass: <class 'mo.ops.deformable_convolution.DeformableConvolution'>
[ INFO ]  Registered a new subclass with key: DeformableConvolution
[ INFO ]  New subclass: <class 'mo.ops.eltwise.Eltwise'>
[ INFO ]  Registered a new subclass with key: Eltwise
[ INFO ]  New subclass: <class 'mo.ops.eltwise_n.EltwiseN'>
[ INFO ]  Registered a new subclass with key: EltwiseN
[ INFO ]  New subclass: <class 'mo.ops.eltwise_ninputs_in_1.EltwiseNin1'>
[ INFO ]  Registered a new subclass with key: EltwiseNin1
[ INFO ]  New subclass: <class 'mo.ops.expand_dims.ExpandDims'>
[ INFO ]  Registered a new subclass with key: ExpandDims
[ INFO ]  New subclass: <class 'mo.ops.fill.Fill'>
[ INFO ]  Registered a new subclass with key: Fill
[ INFO ]  New subclass: <class 'mo.ops.flatten.Flatten'>
[ INFO ]  Registered a new subclass with key: Flatten
[ INFO ]  New subclass: <class 'mo.ops.flatten_onnx.FlattenONNX'>
[ INFO ]  Registered a new subclass with key: FlattenONNX
[ INFO ]  New subclass: <class 'mo.ops.group_norm.GroupNorm'>
[ INFO ]  Registered a new subclass with key: GroupNorm
[ INFO ]  New subclass: <class 'mo.ops.inner_product.InnerProduct'>
[ INFO ]  Registered a new subclass with key: FullyConnected
[ INFO ]  New subclass: <class 'mo.ops.lrn.LRN'>
[ INFO ]  Registered a new subclass with key: LRN
[ INFO ]  New subclass: <class 'mo.ops.lstmnonlinearity.LstmNonLinearity'>
[ INFO ]  Registered a new subclass with key: LstmNonLinearity
[ INFO ]  New subclass: <class 'mo.ops.memory.Memory'>
[ INFO ]  Registered a new subclass with key: Memory
[ INFO ]  New subclass: <class 'mo.ops.memoryoffset.MemoryOffset'>
[ INFO ]  Registered a new subclass with key: MemoryOffset
[ INFO ]  New subclass: <class 'mo.ops.pad.Pad'>
[ INFO ]  Registered a new subclass with key: Pad
[ INFO ]  New subclass: <class 'mo.ops.permute.Permute'>
[ INFO ]  Registered a new subclass with key: Permute
[ INFO ]  New subclass: <class 'mo.ops.pooling.Pooling'>
[ INFO ]  Registered a new subclass with key: Pooling
[ INFO ]  New subclass: <class 'mo.ops.power.Power'>
[ INFO ]  Registered a new subclass with key: Power
[ INFO ]  New subclass: <class 'mo.ops.result.Result'>
[ INFO ]  Registered a new subclass with key: Result
[ INFO ]  New subclass: <class 'mo.ops.roipooling.ROIPooling'>
[ INFO ]  Registered a new subclass with key: ROIPooling
[ INFO ]  New subclass: <class 'mo.ops.shape.Shape'>
[ INFO ]  Registered a new subclass with key: ShapeOf
[ INFO ]  New subclass: <class 'mo.ops.slice.Slice'>
[ INFO ]  Registered a new subclass with key: Slice
[ INFO ]  New subclass: <class 'mo.ops.split.Split'>
[ INFO ]  Registered a new subclass with key: Split
[ INFO ]  New subclass: <class 'mo.ops.squeeze.Squeeze'>
[ INFO ]  Registered a new subclass with key: Squeeze
[ INFO ]  New subclass: <class 'mo.ops.strided_slice.StridedSlice'>
[ INFO ]  Registered a new subclass with key: StridedSlice
[ INFO ]  New subclass: <class 'mo.ops.tile.Tile'>
[ INFO ]  Registered a new subclass with key: Tile
[ INFO ]  New subclass: <class 'mo.ops.unsqueeze.Unsqueeze'>
[ INFO ]  Registered a new subclass with key: Unsqueeze
[ INFO ]  New subclass: <class 'mo.front.common.replacement.FrontReplacementSubgraph'>
[ INFO ]  New subclass: <class 'mo.front.tf.replacement.FrontReplacementFromConfigFileGeneral'>
[ INFO ]  New subclass: <class 'mo.front.common.replacement.FrontReplacementOp'>
[ INFO ]  Registered a new subclass with key: UnknownOp
[ INFO ]  New subclass: <class 'mo.front.tf.replacement.FrontReplacementFromConfigFileSubGraph'>
[ INFO ]  New subclass: <class 'mo.front.tf.replacement.FrontReplacementFromConfigFileOp'>
[ WARNING ]  Skipped <class 'mo.front.common.replacement.FrontReplacementSubgraph'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.front.tf.replacement.FrontReplacementFromConfigFileGeneral'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.front.common.replacement.FrontReplacementOp'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.front.tf.replacement.FrontReplacementFromConfigFileSubGraph'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.front.tf.replacement.FrontReplacementFromConfigFileOp'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.middle.ConcatOptimization.ConcatOptimization'>
[ INFO ]  New subclass: <class 'extensions.middle.EltwiseChecker.EltwiseChecker'>
[ INFO ]  New subclass: <class 'extensions.middle.EltwiseInputReshape.Eltwise1DInputReshape'>
[ INFO ]  New subclass: <class 'extensions.middle.EltwiseInputReshape.EltwiseInputReshape'>
[ INFO ]  New subclass: <class 'extensions.middle.EltwiseInputNormalization.EltwiseInputNormalize'>
[ INFO ]  New subclass: <class 'extensions.back.CreateConstNodes.CreateConstNodesReplacement'>
[ INFO ]  New subclass: <class 'extensions.back.FuseReshapesSequence.FuseReshapesSequence'>
[ INFO ]  New subclass: <class 'extensions.back.InsertLayoutPropagationTransposes.InsertLayoutPropagationTranspose'>
[ INFO ]  New subclass: <class 'extensions.back.RemoveRedundantReshapes.RemoveRedundantReshapes'>
[ INFO ]  New subclass: <class 'extensions.middle.LayoutChangeForConstantShapePaths.LayoutChangeForConstantShapePaths'>
[ INFO ]  New subclass: <class 'mo.front.tf.extractors.strided_slice.StridedSliceFrontExtractor'>
[ INFO ]  Importing extensions from: C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\extensions
[ WARNING ]  Skipped <class 'extensions.ops.gather.Gather'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.const.Const'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.ops.transpose.Transpose'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.reshape.Reshape'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.scale_shift.ScaleShiftOp'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.clamp.Clamp'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.ops.activation_ops.Activation'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.ops.activation_ops.LeakyReLU'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.concat.Concat'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.convolution.Convolution'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.crop.Crop'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.softmax.Softmax'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.ops.elementwise.Elementwise'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.activation.Activation'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.broadcast.Broadcast'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.deconvolution.Deconvolution'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.deformable_convolution.DeformableConvolution'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.eltwise.Eltwise'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.eltwise_n.EltwiseN'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.eltwise_ninputs_in_1.EltwiseNin1'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.expand_dims.ExpandDims'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.fill.Fill'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.flatten.Flatten'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.flatten_onnx.FlattenONNX'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.group_norm.GroupNorm'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.inner_product.InnerProduct'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.lrn.LRN'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.lstmnonlinearity.LstmNonLinearity'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.memory.Memory'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.memoryoffset.MemoryOffset'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.pad.Pad'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.permute.Permute'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.pooling.Pooling'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.power.Power'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.result.Result'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.roipooling.ROIPooling'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.shape.Shape'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.slice.Slice'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.split.Split'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.squeeze.Squeeze'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.strided_slice.StridedSlice'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.tile.Tile'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'mo.ops.unsqueeze.Unsqueeze'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.ops.BatchMatMul.BatchMatMul'>
[ INFO ]  Registered a new subclass with key: BatchMatMul
[ INFO ]  New subclass: <class 'extensions.ops.BlockLSTM.BlockLSTM'>
[ INFO ]  Registered a new subclass with key: BlockLSTM
[ INFO ]  New subclass: <class 'extensions.ops.Cast.Cast'>
[ INFO ]  Registered a new subclass with key: Cast
[ INFO ]  New subclass: <class 'extensions.ops.DetectionOutput.DetectionOutput'>
[ INFO ]  Registered a new subclass with key: DetectionOutput
[ INFO ]  New subclass: <class 'extensions.ops.Enter.Enter'>
[ INFO ]  Registered a new subclass with key: Enter
[ INFO ]  New subclass: <class 'extensions.ops.Exit.Exit'>
[ INFO ]  Registered a new subclass with key: Exit
[ INFO ]  New subclass: <class 'extensions.ops.RNN.RNN'>
[ INFO ]  Registered a new subclass with key: RNN
[ INFO ]  New subclass: <class 'extensions.ops.GRU.GRU'>
[ INFO ]  Registered a new subclass with key: GRU
[ INFO ]  New subclass: <class 'extensions.ops.GRUCell.GRUCell'>
[ INFO ]  Registered a new subclass with key: GRUCell
[ INFO ]  New subclass: <class 'extensions.ops.GatherNd.GatherNd'>
[ INFO ]  Registered a new subclass with key: GatherNd
[ INFO ]  New subclass: <class 'extensions.ops.GatherTree.GatherTree'>
[ INFO ]  Registered a new subclass with key: GatherTree
[ INFO ]  New subclass: <class 'extensions.ops.LSTM.LSTM'>
[ INFO ]  Registered a new subclass with key: LSTM
[ INFO ]  New subclass: <class 'extensions.ops.Log.LogOp'>
[ INFO ]  Registered a new subclass with key: Log
[ INFO ]  New subclass: <class 'extensions.ops.NextIteration.NextIteration'>
[ INFO ]  Registered a new subclass with key: NextIteration
[ INFO ]  New subclass: <class 'extensions.ops.RNNCell.RNNCell'>
[ INFO ]  Registered a new subclass with key: RNNCell
[ INFO ]  New subclass: <class 'extensions.ops.ReduceOps.ReduceOp'>
[ INFO ]  New subclass: <class 'extensions.ops.Reverse.Reverse'>
[ INFO ]  Registered a new subclass with key: Reverse
[ INFO ]  New subclass: <class 'extensions.ops.SquaredDifference.SquaredDifference'>
[ INFO ]  Registered a new subclass with key: SquaredDifference
[ INFO ]  New subclass: <class 'extensions.ops.TensorArray.TensorArray'>
[ INFO ]  Registered a new subclass with key: TensorArrayV3
[ INFO ]  New subclass: <class 'extensions.ops.TensorArrayGather.TensorArrayGather'>
[ INFO ]  Registered a new subclass with key: TensorArrayGatherV3
[ INFO ]  New subclass: <class 'extensions.ops.TensorArrayRead.TensorArrayReader'>
[ INFO ]  Registered a new subclass with key: TensorArrayReadV3
[ INFO ]  New subclass: <class 'extensions.ops.TensorArrayScatter.TensorArrayScatter'>
[ INFO ]  Registered a new subclass with key: TensorArrayScatterV3
[ INFO ]  New subclass: <class 'extensions.ops.TensorArraySize.TensorArraySize'>
[ INFO ]  Registered a new subclass with key: TensorArraySizeV3
[ INFO ]  New subclass: <class 'extensions.ops.TensorArrayWrite.TensorArrayWriter'>
[ INFO ]  Registered a new subclass with key: TensorArrayWriteV3
[ INFO ]  New subclass: <class 'extensions.ops.TensorIterator_ops.TensorIteratorInput'>
[ INFO ]  Registered a new subclass with key: TensorIteratorInput
[ INFO ]  New subclass: <class 'extensions.ops.TensorIterator_ops.TensorIteratorOutput'>
[ INFO ]  Registered a new subclass with key: TensorIteratorOutput
[ INFO ]  New subclass: <class 'extensions.ops.TensorIterator_ops.TensorIteratorCondition'>
[ INFO ]  Registered a new subclass with key: TensorIteratorCondition
[ INFO ]  New subclass: <class 'extensions.ops.TensorIterator_ops.TensorIteratorBackEdge'>
[ INFO ]  Registered a new subclass with key: TensorIteratorBackEdge
[ INFO ]  New subclass: <class 'extensions.ops.accum.AccumOp'>
[ INFO ]  Registered a new subclass with key: Accum
[ INFO ]  New subclass: <class 'extensions.ops.argmax.ArgMaxOp'>
[ INFO ]  Registered a new subclass with key: ArgMax
[ INFO ]  New subclass: <class 'extensions.ops.assert_op.Assert'>
[ INFO ]  Registered a new subclass with key: Assert
[ INFO ]  New subclass: <class 'extensions.ops.axpy.AxpyOp'>
[ INFO ]  Registered a new subclass with key: Axpy
[ INFO ]  New subclass: <class 'extensions.ops.binarization.Binarization'>
[ INFO ]  Registered a new subclass with key: Binarization
[ INFO ]  New subclass: <class 'extensions.ops.bn.BNOp'>
[ INFO ]  Registered a new subclass with key: BN
[ INFO ]  New subclass: <class 'extensions.ops.box_nms.BoxNms'>
[ INFO ]  Registered a new subclass with key: _contrib_box_nms
[ INFO ]  New subclass: <class 'extensions.ops.constant_fill.ConstantFill'>
[ INFO ]  Registered a new subclass with key: ConstantFill
[ INFO ]  New subclass: <class 'extensions.ops.copy.CopyOp'>
[ INFO ]  Registered a new subclass with key: copy
[ INFO ]  New subclass: <class 'extensions.ops.correlation.CorrelationOp'>
[ INFO ]  Registered a new subclass with key: Correlation
[ INFO ]  New subclass: <class 'extensions.ops.ctc_greedy_decoder.CTCGreedyDecoderOp'>
[ INFO ]  Registered a new subclass with key: CTCGreedyDecoder
[ INFO ]  New subclass: <class 'extensions.ops.data_augmentation.DataAugmentationOp'>
[ INFO ]  Registered a new subclass with key: DataAugmentation
[ INFO ]  New subclass: <class 'extensions.ops.depth_to_space.DepthToSpaceOp'>
[ INFO ]  Registered a new subclass with key: DepthToSpace
[ INFO ]  New subclass: <class 'extensions.ops.detectionoutput_onnx.ExperimentalDetectronDetectionOutput'>
[ INFO ]  Registered a new subclass with key: ExperimentalDetectronDetectionOutput
[ INFO ]  New subclass: <class 'extensions.ops.exp.ExpOp'>
[ INFO ]  New subclass: <class 'extensions.ops.fakequantize.FakeQuantize'>
[ INFO ]  Registered a new subclass with key: FakeQuantize
[ INFO ]  New subclass: <class 'extensions.ops.grn.GRNOp'>
[ INFO ]  Registered a new subclass with key: GRN
[ INFO ]  New subclass: <class 'extensions.ops.identity.IdentityOp'>
[ INFO ]  Registered a new subclass with key: Identity
[ INFO ]  New subclass: <class 'extensions.ops.instance_normalization.InstanceNormalization'>
[ INFO ]  Registered a new subclass with key: InstanceNormalization
[ INFO ]  New subclass: <class 'extensions.ops.interp.InterpOp'>
[ INFO ]  Registered a new subclass with key: Interp
[ INFO ]  New subclass: <class 'extensions.ops.interpolate.Interpolate'>
[ INFO ]  Registered a new subclass with key: Interpolate
[ INFO ]  New subclass: <class 'extensions.ops.lstm_cell.LSTMCell'>
[ INFO ]  Registered a new subclass with key: LSTMCell
[ INFO ]  New subclass: <class 'extensions.ops.lstm_sequence.LSTMSequence'>
[ INFO ]  Registered a new subclass with key: LSTMSequence
[ INFO ]  New subclass: <class 'extensions.ops.merge.Merge'>
[ INFO ]  Registered a new subclass with key: Merge
[ INFO ]  New subclass: <class 'extensions.ops.mvn.MVN'>
[ INFO ]  Registered a new subclass with key: MVN
[ INFO ]  New subclass: <class 'extensions.ops.normalize.NormalizeOp'>
[ INFO ]  Registered a new subclass with key: Normalize
[ INFO ]  New subclass: <class 'extensions.ops.one_hot.OneHot'>
[ INFO ]  Registered a new subclass with key: OneHot
[ INFO ]  New subclass: <class 'extensions.ops.pack.PackOp'>
[ INFO ]  Registered a new subclass with key: Pack
[ INFO ]  New subclass: <class 'extensions.ops.parameter.Parameter'>
[ INFO ]  Registered a new subclass with key: Parameter
[ INFO ]  New subclass: <class 'extensions.ops.power_file.PowerFileOp'>
[ INFO ]  Registered a new subclass with key: PowerFile
[ INFO ]  New subclass: <class 'extensions.ops.prediction_heatmap.PredictionHeatmapOp'>
[ INFO ]  Registered a new subclass with key: PredictionHeatmap
[ INFO ]  New subclass: <class 'extensions.ops.prelu.PreluOp'>
[ INFO ]  Registered a new subclass with key: PReLU
[ INFO ]  New subclass: <class 'extensions.ops.priorbox.PriorBoxOp'>
[ INFO ]  Registered a new subclass with key: PriorBox
[ INFO ]  New subclass: <class 'extensions.ops.priorbox_clustered.PriorBoxClusteredOp'>
[ INFO ]  Registered a new subclass with key: PriorBoxClustered
[ INFO ]  New subclass: <class 'extensions.ops.priorgridgenerator_onnx.ExperimentalDetectronPriorGridGenerator'>
[ INFO ]  Registered a new subclass with key: ExperimentalDetectronPriorGridGenerator
[ INFO ]  New subclass: <class 'extensions.ops.proposal.ProposalOp'>
[ INFO ]  Registered a new subclass with key: Proposal
[ INFO ]  New subclass: <class 'extensions.ops.proposal_onnx.ExperimentalDetectronGenerateProposalsSingleImage'>
[ INFO ]  Registered a new subclass with key: ExperimentalDetectronGenerateProposalsSingleImage
[ INFO ]  New subclass: <class 'extensions.ops.psroipooling.PSROIPoolingOp'>
[ INFO ]  Registered a new subclass with key: PSROIPooling
[ INFO ]  New subclass: <class 'extensions.ops.range.Range'>
[ INFO ]  Registered a new subclass with key: Range
[ INFO ]  New subclass: <class 'extensions.ops.rank.Rank'>
[ INFO ]  Registered a new subclass with key: Rank
[ INFO ]  New subclass: <class 'extensions.ops.regionyolo.RegionYoloOp'>
[ INFO ]  Registered a new subclass with key: RegionYolo
[ INFO ]  New subclass: <class 'extensions.ops.reorgyolo.ReorgYoloOp'>
[ INFO ]  Registered a new subclass with key: ReorgYolo
[ INFO ]  New subclass: <class 'extensions.ops.resample.ResampleOp'>
[ INFO ]  Registered a new subclass with key: Resample
[ INFO ]  New subclass: <class 'extensions.ops.reverse_sequence.ReverseSequence'>
[ INFO ]  Registered a new subclass with key: ReverseSequence
[ INFO ]  New subclass: <class 'extensions.ops.roifeatureextractor_onnx.ExperimentalDetectronROIFeatureExtractor'>
[ INFO ]  Registered a new subclass with key: ExperimentalDetectronROIFeatureExtractor
[ INFO ]  New subclass: <class 'extensions.ops.select.Select'>
[ INFO ]  Registered a new subclass with key: Select
[ INFO ]  New subclass: <class 'extensions.ops.shufflechannel.ShuffleChannelOp'>
[ INFO ]  Registered a new subclass with key: ShuffleChannel
[ INFO ]  New subclass: <class 'extensions.ops.simplernms.SimplerNMSOp'>
[ INFO ]  Registered a new subclass with key: SimplerNMS
[ INFO ]  New subclass: <class 'extensions.ops.size.Size'>
[ INFO ]  Registered a new subclass with key: Size
[ INFO ]  New subclass: <class 'extensions.ops.space_to_depth.SpaceToDepth'>
[ INFO ]  Registered a new subclass with key: SpaceToDepth
[ INFO ]  New subclass: <class 'extensions.ops.spatial_transformer.SpatialTransformOp'>
[ INFO ]  Registered a new subclass with key: SpatialTransformer
[ INFO ]  New subclass: <class 'extensions.ops.splice.Splice'>
[ INFO ]  Registered a new subclass with key: Splice
[ INFO ]  New subclass: <class 'extensions.ops.splitv.SplitV'>
[ INFO ]  Registered a new subclass with key: SplitV
[ INFO ]  New subclass: <class 'extensions.ops.stop_gradient.StopGradientOp'>
[ INFO ]  Registered a new subclass with key: StopGradient
[ INFO ]  New subclass: <class 'extensions.ops.swapaxis.SwapAxis'>
[ INFO ]  Registered a new subclass with key: SwapAxis
[ INFO ]  New subclass: <class 'extensions.ops.switch.Switch'>
[ INFO ]  Registered a new subclass with key: Switch
[ INFO ]  New subclass: <class 'extensions.ops.tensor_iterator.TensorIterator'>
[ INFO ]  New subclass: <class 'extensions.ops.topk.TopK'>
[ INFO ]  Registered a new subclass with key: TopK
[ INFO ]  New subclass: <class 'extensions.ops.topkrois_onnx.ExperimentalDetectronTopKROIs'>
[ INFO ]  Registered a new subclass with key: ExperimentalDetectronTopKROIs
[ INFO ]  New subclass: <class 'extensions.ops.upsample.UpsampleOp'>
[ INFO ]  Registered a new subclass with key: Upsample
[ WARNING ]  Skipped <class 'mo.front.tf.extractors.strided_slice.StridedSliceFrontExtractor'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.front.InterpolateNormalizer.InterpolateNormalizer'>
[ INFO ]  New subclass: <class 'extensions.front.LRNReplacer.LRNReplacer'>
[ INFO ]  New subclass: <class 'extensions.front.Pack.Pack'>
[ INFO ]  New subclass: <class 'extensions.front.PowerToEltwises.PowerToEltwises'>
[ INFO ]  New subclass: <class 'extensions.front.tf.FakeQuantWithMinMaxVars.FakeQuantWithMinMaxVarsToQuantize'>
[ INFO ]  Registered a new subclass with key: FakeQuantWithMinMaxVars
[ INFO ]  New subclass: <class 'extensions.front.div.Div'>
[ INFO ]  Registered a new subclass with key: Div
[ INFO ]  New subclass: <class 'extensions.front.eltwise_n.EltwiseNReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.image_scaler.ImageScaler'>
[ INFO ]  Registered a new subclass with key: ImageScaler
[ INFO ]  New subclass: <class 'extensions.front.instance_normalization.InstanceNormalization'>
[ INFO ]  New subclass: <class 'extensions.front.reciprocal.ReciprocalReplacer'>
[ INFO ]  Registered a new subclass with key: Reciprocal
[ INFO ]  New subclass: <class 'extensions.front.sub.Sub'>
[ INFO ]  Registered a new subclass with key: Sub
[ INFO ]  New subclass: <class 'extensions.front.squared_difference.SquaredDifference'>
[ INFO ]  New subclass: <class 'extensions.front.ExpandDimsToUnsqueeze.ExpandDimsToUnsqueeze'>
[ INFO ]  New subclass: <class 'extensions.front.FillToBroadcast.FillToBroadcast'>
[ INFO ]  New subclass: <class 'extensions.front.SqueezeNormalize.SqueezeNormalize'>
[ INFO ]  New subclass: <class 'extensions.front.TopKNormalize.TopKNormalize'>
[ INFO ]  New subclass: <class 'extensions.front.binary_quantize_normalization.BinaryFakeQuantizeNormalization'>
[ INFO ]  New subclass: <class 'extensions.front.create_tensor_nodes.CreateTensorNodes'>
[ INFO ]  New subclass: <class 'extensions.front.disable_weights_quantize_value_propagation.DisableQuantizeValuePropagation'>
[ INFO ]  New subclass: <class 'extensions.front.input_cut.InputCut'>
[ INFO ]  New subclass: <class 'extensions.front.output_cut.OutputCut'>
[ INFO ]  New subclass: <class 'extensions.front.override_batch.OverrideBatch'>
[ INFO ]  New subclass: <class 'extensions.front.pass_separator.FrontStart'>
[ INFO ]  New subclass: <class 'extensions.front.pass_separator.FrontFinish'>
[ INFO ]  New subclass: <class 'extensions.front.user_data_repack.UserDataRepack'>
[ INFO ]  New subclass: <class 'extensions.front.ArgMaxSqueeze.ArgMaxSqueeze'>
[ INFO ]  New subclass: <class 'extensions.front.TransposeOrderNormalizer.TransposeOrderNormalizer'>
[ INFO ]  New subclass: <class 'extensions.front.freeze_placeholder_value.FreezePlaceholderValue'>
[ INFO ]  New subclass: <class 'extensions.front.no_op_eraser.NoOpEraser'>
[ INFO ]  New subclass: <class 'extensions.front.reduce_axis_normalizer.ReduceAxisNormalizer'>
[ INFO ]  New subclass: <class 'extensions.front.reshape_dim_normalizer.ReshapeDimNormalizer'>
[ INFO ]  New subclass: <class 'extensions.front.restore_ports.RestorePorts'>
[ INFO ]  New subclass: <class 'extensions.front.softmax.SoftmaxFromKeras'>
[ INFO ]  New subclass: <class 'extensions.front.standalone_const_eraser.StandaloneConstEraser'>
[ INFO ]  New subclass: <class 'extensions.front.tf.BatchMatMul_ext.BatchMatMulExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.BlockLSTM_ext.BlockLSTMExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.CTCGreedyDecoder_ext.CTCCGreedyDecoderFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.Cast_ext.CastFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.FakeQuantWithMinMaxVars_ext.FakeQuantWithMinMaxVarsExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.FloorMod_ext.EltwiseFrontExtractor'>
[ INFO ]  Registered a new subclass with key: FloorMod
[ INFO ]  New subclass: <class 'extensions.front.tf.GatherTree_ext.GatherTreeFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.LoopCond_ext.LoopCondFrontExtractor'>
[ INFO ]  Registered a new subclass with key: LoopCond
[ INFO ]  New subclass: <class 'extensions.front.tf.Not_ext.LogicalNotFrontExtractor'>
[ INFO ]  Registered a new subclass with key: LogicalNot
[ INFO ]  New subclass: <class 'extensions.front.tf.TensorArrayExtractors.TensorArrayExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.TensorArrayGatherV3.TensorArrayGatherV3Exteractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.all_ext.AllFrontExtractor'>
[ INFO ]  Registered a new subclass with key: All
[ INFO ]  New subclass: <class 'extensions.front.tf.argmax_ext.ArgMaxFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.concat_ext.ConcatFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.conv_ext.Conv2DFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Conv2D
[ INFO ]  New subclass: <class 'extensions.front.tf.conv_ext.DepthwiseConv2dNativeFrontExtractor'>
[ INFO ]  Registered a new subclass with key: DepthwiseConv2dNative
[ INFO ]  New subclass: <class 'extensions.front.tf.conv_ext.Conv3DFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Conv3D
[ INFO ]  New subclass: <class 'extensions.front.tf.crop_and_resize_ext.CropAndResizeFrontExtractor'>
[ INFO ]  Registered a new subclass with key: CropAndResize
[ INFO ]  New subclass: <class 'extensions.front.tf.deconv_ext.Conv2DBackpropInputFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Conv2DBackpropInput
[ INFO ]  New subclass: <class 'extensions.front.tf.deconv_ext.Conv3DBackpropInputV2InputFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Conv3DBackpropInputV2
[ INFO ]  New subclass: <class 'extensions.front.tf.depth_to_space.DepthToSpaceFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.AddExtractor'>
[ INFO ]  Registered a new subclass with key: Add
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.AddNExtractor'>
[ INFO ]  Registered a new subclass with key: AddN
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.BiasAddExtractor'>
[ INFO ]  Registered a new subclass with key: BiasAdd
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.MulExtractor'>
[ INFO ]  Registered a new subclass with key: Mul
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.SubExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.DivExtractor'>
[ INFO ]  Registered a new subclass with key: RealDiv
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.SqrtExtractor'>
[ INFO ]  Registered a new subclass with key: Sqrt
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.RsqrtExtractor'>
[ INFO ]  Registered a new subclass with key: Rsqrt
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.SquareExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.NegExtractor'>
[ INFO ]  Registered a new subclass with key: Neg
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.ZerosLike'>
[ INFO ]  Registered a new subclass with key: ZerosLike
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.MaximumExtractor'>
[ INFO ]  Registered a new subclass with key: Maximum
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.MinimumExtractor'>
[ INFO ]  Registered a new subclass with key: Minimum
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.PowExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.LogicalAndFrontExtractor'>
[ INFO ]  Registered a new subclass with key: LogicalAnd
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.LogicalOrFrontExtractor'>
[ INFO ]  Registered a new subclass with key: LogicalOr
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.EqualExtractor'>
[ INFO ]  Registered a new subclass with key: Equal
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.LessEqualExtractor'>
[ INFO ]  Registered a new subclass with key: LessEqual
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.LessExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.GreaterExtractor'>
[ INFO ]  Registered a new subclass with key: Greater
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.GreaterEqualExtractor'>
[ INFO ]  Registered a new subclass with key: GreaterEqual
[ INFO ]  New subclass: <class 'extensions.front.tf.elementwise_ext.NotEqualExtractor'>
[ INFO ]  Registered a new subclass with key: NotEqual
[ INFO ]  New subclass: <class 'extensions.front.tf.elu_ext.EluFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Elu
[ INFO ]  New subclass: <class 'extensions.front.tf.erf_ext.ErfFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Erf
[ INFO ]  New subclass: <class 'extensions.front.tf.exp_ext.ExpExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.expand_dims_ext.ExpandDimsExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.extract_image_patches_ext.ExtractImagePatchesExtractor'>
[ INFO ]  Registered a new subclass with key: ExtractImagePatches
[ INFO ]  New subclass: <class 'extensions.front.tf.fifo_queue_v2_ext.FIFOQueueV2Extractor'>
[ INFO ]  Registered a new subclass with key: FIFOQueueV2
[ INFO ]  New subclass: <class 'extensions.front.tf.fill_ext.FillExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.gather_ext.GatherFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.gather_ext.ResourceGatherFrontExtractor'>
[ INFO ]  Registered a new subclass with key: ResourceGather
[ INFO ]  New subclass: <class 'extensions.front.tf.gather_ext.GatherV2FrontExtractor'>
[ INFO ]  Registered a new subclass with key: GatherV2
[ INFO ]  New subclass: <class 'extensions.front.tf.leaky_relu_ext.LeakyReLUFrontExtractor'>
[ INFO ]  Registered a new subclass with key: LeakyRelu
[ INFO ]  New subclass: <class 'extensions.front.tf.max_ext.MaxFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.mean_ext.MeanExtractor'>
[ INFO ]  Registered a new subclass with key: Mean
[ INFO ]  New subclass: <class 'extensions.front.tf.next_iteration_ext.NextIterationExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.one_hot_ext.OneHotFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.pad_ext.PadFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.pad_ext.PadV2FrontExtractor'>
[ INFO ]  Registered a new subclass with key: PadV2
[ INFO ]  New subclass: <class 'extensions.front.tf.pad_ext.MirrorPadFrontExtractor'>
[ INFO ]  Registered a new subclass with key: MirrorPad
[ INFO ]  New subclass: <class 'extensions.front.tf.placeholder_ext.PlaceholderFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Placeholder
[ INFO ]  New subclass: <class 'extensions.front.tf.pooling_ext.AvgPoolFrontExtractor'>
[ INFO ]  Registered a new subclass with key: AvgPool
[ INFO ]  New subclass: <class 'extensions.front.tf.pooling_ext.MaxPoolFrontExtractor'>
[ INFO ]  Registered a new subclass with key: MaxPool
[ INFO ]  New subclass: <class 'extensions.front.tf.pooling_ext.MaxPool3DFrontExtractor'>
[ INFO ]  Registered a new subclass with key: MaxPool3D
[ INFO ]  New subclass: <class 'extensions.front.tf.pooling_ext.AvgPool3DFrontExtractor'>
[ INFO ]  Registered a new subclass with key: AvgPool3D
[ INFO ]  New subclass: <class 'extensions.front.tf.prod_ext.ProdFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Prod
[ INFO ]  New subclass: <class 'extensions.front.tf.rank_ext.RankFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.relu6_ext.Relu6FrontExtractor'>
[ INFO ]  Registered a new subclass with key: Relu6
[ INFO ]  New subclass: <class 'extensions.front.tf.relu_ext.ReluFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.reshape_ext.ReshapeExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.resize_bilinear.ResizeBilinearFrontExtractor'>
[ INFO ]  Registered a new subclass with key: ResizeBilinear
[ INFO ]  New subclass: <class 'extensions.front.tf.resize_nearest_neighbor.ResizeNearestNeighborFrontExtractor'>
[ INFO ]  Registered a new subclass with key: ResizeNearestNeighbor
[ INFO ]  New subclass: <class 'extensions.front.tf.reverse_sequence.ReverseSequenceFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.reverse_v2.ReverseV2FrontExtractor'>
[ INFO ]  Registered a new subclass with key: ReverseV2
[ INFO ]  New subclass: <class 'extensions.front.tf.select_ext.SelectExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.shape_ext.ShapeExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.sigmoid.SigmoidFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Sigmoid
[ INFO ]  New subclass: <class 'extensions.front.tf.size_ext.SizeFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.slice_ext.SliceExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.softmax_ext.SoftmaxFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Softmax
[ INFO ]  New subclass: <class 'extensions.front.tf.space_to_depth_ext.SpaceToDepthFrontExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.split_ext.SplitVExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.squeeze_ext.SqueezeExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.stop_gradient_ext.StopGradientExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.sum_ext.SumFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Sum
[ INFO ]  New subclass: <class 'extensions.front.tf.tanh.TanhFrontExtractor'>
[ INFO ]  Registered a new subclass with key: Tanh
[ INFO ]  New subclass: <class 'extensions.front.tf.tile_ext.TileExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.topk_ext.TopKExtractor'>
[ INFO ]  New subclass: <class 'extensions.front.tf.topk_ext.TopKV2Extractor'>
[ INFO ]  Registered a new subclass with key: TopKV2
[ INFO ]  New subclass: <class 'extensions.front.tf.transpose_ext.TransposeFrontExtractorTF'>
[ INFO ]  New subclass: <class 'extensions.front.tf.variable_ext.VariableExtractor'>
[ INFO ]  Registered a new subclass with key: Variable
[ INFO ]  New subclass: <class 'extensions.front.tf.variable_ext.VariableV2Extractor'>
[ INFO ]  Registered a new subclass with key: VariableV2
[ WARNING ]  Skipped <class 'extensions.front.InterpolateNormalizer.InterpolateNormalizer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.LRNReplacer.LRNReplacer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.Pack.Pack'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.PowerToEltwises.PowerToEltwises'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.tf.FakeQuantWithMinMaxVars.FakeQuantWithMinMaxVarsToQuantize'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.div.Div'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.eltwise_n.EltwiseNReplacement'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.image_scaler.ImageScaler'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.instance_normalization.InstanceNormalization'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.reciprocal.ReciprocalReplacer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.sub.Sub'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.squared_difference.SquaredDifference'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.front.tf.BlockLSTM.BlockLSTM'>
[ INFO ]  New subclass: <class 'extensions.front.tf.CropAndResizeReplacement.CropAndResizeReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.LogSoftmax.LogSoftmaxFrontReplacer'>
[ INFO ]  Registered a new subclass with key: LogSoftmax
[ INFO ]  New subclass: <class 'extensions.front.tf.Unpack.Unpack'>
[ INFO ]  Registered a new subclass with key: Unpack
[ INFO ]  New subclass: <class 'extensions.front.tf.SizeReplacer.SizeFrontReplacer'>
[ INFO ]  New subclass: <class 'extensions.front.tf.assign_elimination.AssignElimination'>
[ INFO ]  Registered a new subclass with key: Assign
[ INFO ]  New subclass: <class 'extensions.front.tf.assign_elimination.AssignSubElimination'>
[ INFO ]  Registered a new subclass with key: AssignSub
[ INFO ]  New subclass: <class 'extensions.front.tf.assign_elimination.AssignAddElimination'>
[ INFO ]  Registered a new subclass with key: AssignAdd
[ INFO ]  New subclass: <class 'extensions.front.tf.assign_elimination.AssertElimination'>
[ INFO ]  New subclass: <class 'extensions.front.tf.fake_const_ext.FakeConstToConst'>
[ INFO ]  Registered a new subclass with key: FakeConst
[ WARNING ]  Skipped <class 'extensions.front.ExpandDimsToUnsqueeze.ExpandDimsToUnsqueeze'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.FillToBroadcast.FillToBroadcast'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.SqueezeNormalize.SqueezeNormalize'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.TopKNormalize.TopKNormalize'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.binary_quantize_normalization.BinaryFakeQuantizeNormalization'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.create_tensor_nodes.CreateTensorNodes'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.disable_weights_quantize_value_propagation.DisableQuantizeValuePropagation'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.input_cut.InputCut'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.output_cut.OutputCut'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.override_batch.OverrideBatch'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.pass_separator.FrontStart'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.pass_separator.FrontFinish'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.user_data_repack.UserDataRepack'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.front.tf.GNMT_DynamicSequenceLengths.GNMT_sequence_lengths'>
[ INFO ]  New subclass: <class 'extensions.front.tf.tensorflow_custom_operations_config_update.TensorflowCustomOperationsConfigUpdate'>
[ INFO ]  New subclass: <class 'extensions.front.tf.tensorflow_patterns.TensorflowSubgraphPatterns'>
[ INFO ]  New subclass: <class 'extensions.front.tf.tensorflow_patterns.TensorflowOperationPatterns'>
[ INFO ]  New subclass: <class 'extensions.front.tf.tensorflow_use_custom_operations_config.TensorflowUseCustomOperationsConfig'>
[ INFO ]  New subclass: <class 'extensions.front.tf.variables_values_freezing.VariablesToConstants'>
[ WARNING ]  Skipped <class 'extensions.front.ArgMaxSqueeze.ArgMaxSqueeze'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.TransposeOrderNormalizer.TransposeOrderNormalizer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.freeze_placeholder_value.FreezePlaceholderValue'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.no_op_eraser.NoOpEraser'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.reduce_axis_normalizer.ReduceAxisNormalizer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.reshape_dim_normalizer.ReshapeDimNormalizer'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.restore_ports.RestorePorts'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.softmax.SoftmaxFromKeras'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.front.standalone_const_eraser.StandaloneConstEraser'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.front.tf.CTCGreedyDecoder.CTCGreedyDecoderReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.nearest_neighbor_upsampling.NearestNeighborUpsampling'>
[ INFO ]  New subclass: <class 'extensions.front.tf.FlattenToReshape.FlattenToReshapeableReshape'>
[ INFO ]  New subclass: <class 'extensions.front.tf.basic_lstm_cell.BasicLSTMCell'>
[ INFO ]  New subclass: <class 'extensions.front.tf.concat.Concat'>
[ INFO ]  New subclass: <class 'extensions.front.tf.fifo_replacer.FIFOQueue'>
[ INFO ]  New subclass: <class 'extensions.front.tf.fifo_replacer.QueueDequeueManyV2'>
[ INFO ]  New subclass: <class 'extensions.front.tf.mvn.MVN'>
[ INFO ]  New subclass: <class 'extensions.front.tf.mvn_unrolled.MVNUnrolled'>
[ INFO ]  New subclass: <class 'extensions.front.tf.prelu.PReLU'>
[ INFO ]  New subclass: <class 'extensions.front.tf.prelu.PReLUWithAbs'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIPreprocessorReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIDetectionOutputReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIMaskRCNNROIPoolingSecondReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIProposalReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPISSDPostprocessorReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIPSROIPoolingReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.RetinaNetFilteredDetectionsReplacement.RetinaNetFilteredDetectionsReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.SSDToolboxDetectionOutput.SSDToolboxDetectionOutputReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIMaskRCNNSigmoidReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIOutputReplacement'>
[ INFO ]  New subclass: <class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIConstValueOverride'>
[ INFO ]  New subclass: <class 'extensions.front.tf.YOLO.YoloRegionAddon'>
[ INFO ]  New subclass: <class 'extensions.front.tf.YOLO.YoloV3RegionAddon'>
[ WARNING ]  Skipped <class 'extensions.middle.ConcatOptimization.ConcatOptimization'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.middle.EltwiseChecker.EltwiseChecker'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.middle.EltwiseInputReshape.Eltwise1DInputReshape'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.middle.EltwiseInputReshape.EltwiseInputReshape'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.middle.EltwiseInputNormalization.EltwiseInputNormalize'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.middle.PartialInfer.PartialInfer'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorCondition.LoopConditionMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorCondition.SimpleConditionMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorCondition.DynamicDecoderConditionMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.MulFakeQuantizeFuse.MulFakeQuantizeFuse'>
[ INFO ]  New subclass: <class 'extensions.middle.AddFakeQuantizeFuse.AddFakeQuantizeFuse'>
[ INFO ]  New subclass: <class 'extensions.middle.AddIsCyclicAttribute.AddIsCyclicAttribute'>
[ INFO ]  New subclass: <class 'extensions.middle.AddMeanScaleValues.AddMeanScaleValues'>
[ INFO ]  New subclass: <class 'extensions.middle.AnchorToPriorBox.AnchorToPriorBoxes'>
[ INFO ]  New subclass: <class 'extensions.middle.ArgMaxToTopK.ArgMaxToTopK'>
[ INFO ]  New subclass: <class 'extensions.middle.CheckForCycle.CheckForCycle'>
[ INFO ]  New subclass: <class 'extensions.middle.DeleteNotExecutable.DeleteNotExecutable'>
[ INFO ]  New subclass: <class 'extensions.middle.BinarizeWeightsM1P1.BinarizeWeightsM1P1'>
[ INFO ]  New subclass: <class 'extensions.middle.BlockLSTMtoLSTMSequence.BlockLSTMtoLSTMSequence'>
[ INFO ]  New subclass: <class 'extensions.middle.RemoveIdentity.RemoveIdentity'>
[ INFO ]  New subclass: <class 'extensions.middle.RemoveIdentity.RemoveDropout'>
[ INFO ]  New subclass: <class 'extensions.middle.RemoveIdentity.RemoveNodesWithZeroPhase'>
[ INFO ]  New subclass: <class 'extensions.middle.Cast.CastToFloatMark'>
[ INFO ]  New subclass: <class 'extensions.middle.ChangePlaceholderTypes.ChangePlaceholderTypes'>
[ INFO ]  New subclass: <class 'extensions.middle.ConstSwitchResolver.ConstSwitchEraser'>
[ INFO ]  New subclass: <class 'extensions.middle.ConvToBinaryConv.ConvToBinaryConv'>
[ INFO ]  New subclass: <class 'extensions.middle.SliceConverter.ConvertSlice'>
[ INFO ]  New subclass: <class 'extensions.middle.ConvertGroupedStridedSlice.ConvertGroupedStridedSlice'>
[ INFO ]  New subclass: <class 'extensions.middle.ConvertLayoutDependentOperations.ConvertLayoutDependentOperations'>
[ INFO ]  New subclass: <class 'extensions.middle.ConvertMultiInputConv.ConvertMultiInputConv'>
[ INFO ]  New subclass: <class 'extensions.middle.CustomSubgraphCall.CustomSubgraphCall'>
[ INFO ]  New subclass: <class 'extensions.middle.DecomposeBias.DecomposeBias'>
[ INFO ]  New subclass: <class 'extensions.middle.DecomposeBidirectionalRNNSequence.DecomposeBidirectionalRNNSequence'>
[ INFO ]  New subclass: <class 'extensions.middle.DeleteControlFlowEdges.DeleteControlFlowEdges'>
[ INFO ]  New subclass: <class 'extensions.middle.DepthToSpace.DepthToSpace'>
[ INFO ]  New subclass: <class 'extensions.middle.DilatedConvolution.DilatedConvolutionConverter'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorMerge.TensorIteratorMerge'>
[ INFO ]  New subclass: <class 'extensions.middle.FakeSplitOutputs.AddFakeOutputsToSplit'>
[ INFO ]  New subclass: <class 'extensions.middle.FlattenONNXToReshape.FlattenONNXToReshape'>
[ INFO ]  New subclass: <class 'extensions.middle.FusedBatchNormNonConstant.FusedBatchNormNonConstant'>
[ INFO ]  New subclass: <class 'extensions.middle.FusedBatchNormTrainingCatch.FusedBatchNormTrainingCatch'>
[ INFO ]  New subclass: <class 'extensions.middle.GRURNNSequenceToTensorIterator.GRUAndRNNToTensorIterator'>
[ INFO ]  New subclass: <class 'extensions.middle.GatherNdNormalizer.GatherNdNormalize'>
[ INFO ]  New subclass: <class 'extensions.middle.GemmResolver.GemmResolver'>
[ INFO ]  New subclass: <class 'extensions.middle.GemmToFullyConnected.GemmToFullyConnected'>
[ INFO ]  New subclass: <class 'extensions.middle.GroupNorm.GroupNormToMVN'>
[ INFO ]  New subclass: <class 'extensions.middle.InputCut.MiddleInputCut'>
[ INFO ]  New subclass: <class 'extensions.middle.L2NormToNorm.L2NormToNorm'>
[ INFO ]  New subclass: <class 'extensions.middle.RNNSequenceNormalizeToIE.RNNSequenceNormalize'>
[ INFO ]  New subclass: <class 'extensions.middle.LSTMRNNSequenceToTensorIterator.LSTMToTensorIterator'>
[ INFO ]  New subclass: <class 'extensions.middle.MXNetRNNSequenceNormalize.MXNetRNNSequenceNormalize'>
[ INFO ]  New subclass: <class 'extensions.middle.MXNetSplitMultiLayers.MXNetSplitLayersToRNNSequence'>
[ INFO ]  New subclass: <class 'extensions.middle.MinimumMiddleReplacer.MinimumMiddleReplacer'>
[ INFO ]  New subclass: <class 'extensions.middle.NasNet.NasNet'>
[ INFO ]  New subclass: <class 'extensions.middle.NormalizeFullyConnected.NormalizeFullyConnected'>
[ INFO ]  New subclass: <class 'extensions.middle.NormalizePad.NormalizePad'>
[ INFO ]  New subclass: <class 'extensions.middle.ONNXRNNSequenceNormalize.ONNXRNNSequenceNormalize'>
[ INFO ]  New subclass: <class 'extensions.middle.ReluQuantizeFuse.ReluFakeQuantizeMark'>
[ INFO ]  New subclass: <class 'extensions.middle.ReluQuantizeFuse.ClampQuantizeMark'>
[ INFO ]  New subclass: <class 'extensions.middle.ReluQuantizeFuse.ReluQuantizeFuse'>
[ INFO ]  New subclass: <class 'extensions.middle.RemoveDuplicationMemory.RemoveMemoryDuplicationPattern'>
[ INFO ]  New subclass: <class 'extensions.middle.RemoveRedundantReshapeAfterCropAndResize.RemoveRedundantReshapeAfterCropAndResize'>
[ INFO ]  New subclass: <class 'extensions.middle.RemoveUselessCrops.RemoveUselessCropsPattern'>
[ INFO ]  New subclass: <class 'extensions.middle.ReplaceMemoryOffsetWithSplice.ReplaceMemoryOffsetNodePattern'>
[ INFO ]  New subclass: <class 'extensions.middle.ReplaceMemoryOffsetWithSplice.ReplaceMemoryOffsetWithMemoryNodePattern'>
[ INFO ]  New subclass: <class 'extensions.middle.ReplaceSpliceNodePattern.ReplaceSpliceNodePattern'>
[ INFO ]  New subclass: <class 'extensions.middle.ReverseTransposeNormalization.ReverseTransposeNormalization'>
[ INFO ]  New subclass: <class 'extensions.middle.ReverseV2ToReverseSequence.ReverseToReverseSequence'>
[ INFO ]  New subclass: <class 'extensions.middle.ScaleInput.ScaleInput'>
[ INFO ]  New subclass: <class 'extensions.middle.SharedWeightsDuplication.SharedWeightsDuplication'>
[ INFO ]  New subclass: <class 'extensions.middle.ShuffleChannel.ShuffleChannel'>
[ INFO ]  New subclass: <class 'extensions.middle.SwapAxesMiddleReplacer.SwapAxisMiddleReplacer'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorInput.SmartInputMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorInput.SimpleInputMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorInput.BackEdgeSimpleInputMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.SwitchMergeOptimization.SwitchMergeMiddleReplacer'>
[ INFO ]  New subclass: <class 'extensions.middle.TF_lstm_cell_to_generic.TensorFlowLSTMtoGeneric'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorBackEdge.BackEdgesMatching'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorConditionChecker.ConditionChecks'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorLSTMToLSTMSequence.TensorIteratorLSTM'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorOutput.SmartOutputMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.TensorIteratorOutput.SimpleOutputMatcher'>
[ INFO ]  New subclass: <class 'extensions.middle.TileReplacer.TileMultipleAxisReplacer'>
[ INFO ]  New subclass: <class 'extensions.middle.UpsampleToResample.UpsampleToResample'>
[ INFO ]  New subclass: <class 'extensions.middle.UselessMerge.UselessMergeEraser'>
[ INFO ]  New subclass: <class 'extensions.middle.UselessSplitEraser.UselessSplitEraser'>
[ INFO ]  New subclass: <class 'extensions.middle.UselessStridedSlice.UselessStridedSliceEraser'>
[ INFO ]  New subclass: <class 'extensions.middle.pass_separator.PreMiddleStart'>
[ INFO ]  New subclass: <class 'extensions.middle.pass_separator.MiddleStart'>
[ INFO ]  New subclass: <class 'extensions.middle.pass_separator.MiddleFinish'>
[ INFO ]  New subclass: <class 'extensions.middle.permute_tensor_iterator.TransposeTensorIteratorLSTM'>
[ INFO ]  New subclass: <class 'extensions.middle.quantize_fuses.MarkNodesToFuseUpToFakeQuantize'>
[ INFO ]  New subclass: <class 'extensions.middle.quantize_fuses.FakeQuantizeFuse'>
[ INFO ]  New subclass: <class 'extensions.middle.reverse_tensor_iterator.ReverseTensorIteratorLSTM'>
[ INFO ]  New subclass: <class 'extensions.middle.space_to_depth.SpaceToDepth'>
[ INFO ]  New subclass: <class 'extensions.middle.ssd_anchors_to_const.SsdAnchorsMiddleReplacer'>
[ INFO ]  New subclass: <class 'extensions.middle.wights_permute_normalizer.WeightsPermuteNormalizer'>
[ WARNING ]  Skipped <class 'extensions.back.CreateConstNodes.CreateConstNodesReplacement'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.back.FuseReshapesSequence.FuseReshapesSequence'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.back.InsertLayoutPropagationTransposes.InsertLayoutPropagationTranspose'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.back.RemoveRedundantReshapes.RemoveRedundantReshapes'> registration because it was already registered or it was disabled.
[ WARNING ]  Skipped <class 'extensions.middle.LayoutChangeForConstantShapePaths.LayoutChangeForConstantShapePaths'> registration because it was already registered or it was disabled.
[ INFO ]  New subclass: <class 'extensions.back.ActivationsNormalizer.ActivationsNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.AvgPool.AvgPool'>
[ INFO ]  New subclass: <class 'extensions.back.ConvolutionNormalizer.ConvolutionNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.EltwiseBroadcast.EltwiseBroadcast'>
[ INFO ]  New subclass: <class 'extensions.back.ForceStrictPrecision.ForceStrictPrecision'>
[ INFO ]  New subclass: <class 'extensions.back.FuseTransposesSequence.FuseTransposesSequence'>
[ INFO ]  New subclass: <class 'extensions.back.OptimizeTransposeReshapeSequence.OptimizeTransposeReshapeSequence'>
[ INFO ]  New subclass: <class 'extensions.back.ReshapeMutation.ReshapeMutation'>
[ INFO ]  New subclass: <class 'extensions.back.ReshapeMutation.FlattenMutation'>
[ INFO ]  New subclass: <class 'extensions.back.ReshapeMutation.DisableReshapeMutationInTensorIterator'>
[ INFO ]  New subclass: <class 'extensions.back.ConvolutionReshaper.ConvolutionReshaper'>
[ INFO ]  New subclass: <class 'extensions.back.CropToStridedSlice.CropToStridedSlice'>
[ INFO ]  New subclass: <class 'extensions.back.DumpFakeQuantStat.DumpFakeQuantStat'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.SimpleEltwiseToEltwiseOp'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.DivideToEltwises'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.SubtractToEltwises'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.EltwisesWithScalarInputToPower'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.MulAddPowerMerge'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.MulPowPowerMerge'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.AddPowPowerMerge'>
[ INFO ]  New subclass: <class 'extensions.back.ElementwiseOpsToEltwiseOps.MulAddPowPowerMerge'>
[ INFO ]  New subclass: <class 'extensions.back.EnableConstantStridedSlice.EnableConstantStridedSlice'>
[ INFO ]  New subclass: <class 'extensions.back.GroupedConvWeightsNormalize.GroupedConvWeightsNormalize'>
[ INFO ]  New subclass: <class 'extensions.back.InterpolateToInterpOrResample.InterpolateToInterpOrResample'>
[ INFO ]  New subclass: <class 'extensions.back.LRNToNorm.LRNToNorm'>
[ INFO ]  New subclass: <class 'extensions.back.LeakyReluToReluWithNegativeSlope.LeakyReluToReluWithNegativeSlope'>
[ INFO ]  New subclass: <class 'extensions.back.MatMulNormalizer.MatMulNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.MaxPool.MaxPool'>
[ INFO ]  New subclass: <class 'extensions.back.NormalizeToNormalizeL2.NormalizeToNormalizeL2'>
[ INFO ]  New subclass: <class 'extensions.back.PackBinaryWeights.PackBinaryWeights'>
[ INFO ]  New subclass: <class 'extensions.back.PadNormalizer.PadNormalize'>
[ INFO ]  New subclass: <class 'extensions.back.ParameterToPlaceholder.ParameterToInput'>
[ INFO ]  New subclass: <class 'extensions.back.RNNSequenceTypeRename.RNNSequence'>
[ INFO ]  New subclass: <class 'extensions.back.ReduceToPooling.ReduceReplacer'>
[ INFO ]  New subclass: <class 'extensions.back.ReduceTransposeDimensions.ReduceTransposeDimensions'>
[ INFO ]  New subclass: <class 'extensions.back.RepackFCWeightsNHWCToNCHW.RepackFCWeightsNHWCToNCHW'>
[ INFO ]  New subclass: <class 'extensions.back.ResultNormalizer.ResultNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.ScalarConstNormalize.ScalarNormalize'>
[ INFO ]  New subclass: <class 'extensions.back.ScalarConstNormalize.ScalarNormalizeForSpecificOps'>
[ INFO ]  New subclass: <class 'extensions.back.SelectBroadcast.SelectBroadcast'>
[ INFO ]  New subclass: <class 'extensions.back.SelectInputNormalizer.SelectInputNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.ShapeOfToShape.ShapeOfToShape'>
[ INFO ]  New subclass: <class 'extensions.back.TransposeToPermute.TransposeToPermute'>
[ INFO ]  New subclass: <class 'extensions.back.ShuffleChannelPatternOptimization.ShuffleChannelPatternOptimization'>
[ INFO ]  New subclass: <class 'extensions.back.ShufflenetReLUReorder.ShufflenetReLUReorder'>
[ INFO ]  New subclass: <class 'extensions.back.TileReshaper.TileReshaper'>
[ INFO ]  New subclass: <class 'extensions.back.TopKNormalizer.TopKNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.TransposeFCWeights.TransposeFCWeights'>
[ INFO ]  New subclass: <class 'extensions.back.blob_normalizer.BlobNormalizer'>
[ INFO ]  New subclass: <class 'extensions.back.disable_unsupported_ND_operations.DisableUnsupportedNDOperations'>
[ INFO ]  New subclass: <class 'extensions.back.insert_compatibility_l2normalization.CompatibilityL2NormalizationPattern'>
[ INFO ]  New subclass: <class 'extensions.back.kaldi_remove_memory_output.KaldiRemoveMemoryOutputBackReplacementPattern'>
[ INFO ]  New subclass: <class 'extensions.back.priorbox_mutation.PriorboxMutation'>
[ INFO ]  New subclass: <class 'extensions.back.remove_last_softmax_pattern.RemoveLastSoftMaxPattern'>
[ 2019-08-21 15:09:22,223 ] [ DEBUG ] [ class_registration:48 ]  All replacers has unique idxs.
[ 2019-08-21 15:11:16,512 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,512 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_44/sub_2/y/ExpandDims_/Dims
[ 2019-08-21 15:11:16,512 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,512 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,512 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,513 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,513 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,513 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_85/ExpandDims_11547/Dims
[ 2019-08-21 15:11:16,513 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,513 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,513 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,513 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_85/ExpandDims_/Dims
[ 2019-08-21 15:11:16,514 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,514 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,514 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,514 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,514 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack_3/ExpandDims_11544/Dims
[ 2019-08-21 15:11:16,514 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,515 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack_3/ExpandDims_/Dims
[ 2019-08-21 15:11:16,515 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,515 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,515 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,515 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,515 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,515 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_6/sub_2/y/ExpandDims_11541/Dims
[ 2019-08-21 15:11:16,516 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,516 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,516 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_6/sub_2/y/ExpandDims_11540/Dims
[ 2019-08-21 15:11:16,516 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,516 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,516 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,517 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_6/sub_2/y/ExpandDims_11539/Dims
[ 2019-08-21 15:11:16,519 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,520 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,520 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,520 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,520 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,520 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_6/sub_2/y/ExpandDims_/Dims
[ 2019-08-21 15:11:16,520 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,521 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,521 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,521 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,521 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,521 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_20/ExpandDims_11536/Dims
[ 2019-08-21 15:11:16,521 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,522 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,522 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,522 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,522 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_20/ExpandDims_/Dims
[ 2019-08-21 15:11:16,522 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,523 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,523 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,523 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,523 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,523 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_72/ExpandDims_11533/Dims
[ 2019-08-21 15:11:16,523 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,524 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,524 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,524 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,524 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,524 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_72/ExpandDims_/Dims
[ 2019-08-21 15:11:16,524 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,525 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,525 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,525 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_29/ExpandDims_11530/Dims
[ 2019-08-21 15:11:16,525 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,525 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,525 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,525 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_29/ExpandDims_/Dims
[ 2019-08-21 15:11:16,526 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,526 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,526 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,526 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,526 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_31/sub_2/y/ExpandDims_11527/Dims
[ 2019-08-21 15:11:16,526 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,527 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,527 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,527 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_31/sub_2/y/ExpandDims_11526/Dims
[ 2019-08-21 15:11:16,527 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,527 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,527 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,528 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,531 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,531 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_31/sub_2/y/ExpandDims_11525/Dims
[ 2019-08-21 15:11:16,531 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,531 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,531 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,531 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,532 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,532 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_31/sub_2/y/ExpandDims_/Dims
[ 2019-08-21 15:11:16,532 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,532 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,532 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,533 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,533 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,533 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_46/sub_2/y/ExpandDims_11522/Dims
[ 2019-08-21 15:11:16,533 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,533 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,533 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,534 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,534 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,534 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_46/sub_2/y/ExpandDims_11521/Dims
[ 2019-08-21 15:11:16,534 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,534 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,534 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,535 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,535 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_46/sub_2/y/ExpandDims_11520/Dims
[ 2019-08-21 15:11:16,535 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,535 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,535 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,535 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,535 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_46/sub_2/y/ExpandDims_/Dims
[ 2019-08-21 15:11:16,536 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,536 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,536 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_30/sub_2/y/ExpandDims_11517/Dims
[ 2019-08-21 15:11:16,536 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,536 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,536 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,536 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_30/sub_2/y/ExpandDims_11516/Dims
[ 2019-08-21 15:11:16,537 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,537 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,537 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,537 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,537 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_30/sub_2/y/ExpandDims_11515/Dims
[ 2019-08-21 15:11:16,537 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,538 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,538 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,538 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,538 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_30/sub_2/y/ExpandDims_/Dims
[ 2019-08-21 15:11:16,538 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,538 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,539 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,542 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,542 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_57/ExpandDims_11512/Dims
[ 2019-08-21 15:11:16,542 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,542 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,542 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,542 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,543 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,543 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_57/ExpandDims_/Dims
[ 2019-08-21 15:11:16,543 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,543 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,543 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,543 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,544 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,544 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_59/sub_2/y/ExpandDims_11509/Dims
[ 2019-08-21 15:11:16,544 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,544 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,544 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,544 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,545 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_59/sub_2/y/ExpandDims_11508/Dims
[ 2019-08-21 15:11:16,545 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,545 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,545 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,545 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,545 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,545 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_59/sub_2/y/ExpandDims_11507/Dims
[ 2019-08-21 15:11:16,546 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,546 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,546 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_59/sub_2/y/ExpandDims_/Dims
[ 2019-08-21 15:11:16,546 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,546 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,546 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,546 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_25/sub_2/y/ExpandDims_11504/Dims
[ 2019-08-21 15:11:16,547 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,547 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,547 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,547 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,547 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_25/sub_2/y/ExpandDims_11503/Dims
[ 2019-08-21 15:11:16,547 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,548 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,548 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_25/sub_2/y/ExpandDims_11502/Dims
[ 2019-08-21 15:11:16,548 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,548 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,548 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,548 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,548 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_25/sub_2/y/ExpandDims_/Dims
[ 2019-08-21 15:11:16,549 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,549 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,549 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_40/sub_2/y/ExpandDims_11499/Dims
[ 2019-08-21 15:11:16,549 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,549 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,549 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,550 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,553 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_40/sub_2/y/ExpandDims_11498/Dims
[ 2019-08-21 15:11:16,553 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,553 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,553 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,553 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,553 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,554 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_40/sub_2/y/ExpandDims_11497/Dims
[ 2019-08-21 15:11:16,554 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,554 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,554 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,554 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,554 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,555 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_40/sub_2/y/ExpandDims_/Dims
[ 2019-08-21 15:11:16,555 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,555 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,555 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,555 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,555 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,556 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_66/ExpandDims_11494/Dims
[ 2019-08-21 15:11:16,556 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,556 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,556 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,556 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,556 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,556 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_66/ExpandDims_/Dims
[ 2019-08-21 15:11:16,557 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,557 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,557 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,557 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,557 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_18/sub_2/y/ExpandDims_11491/Dims
[ 2019-08-21 15:11:16,557 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,558 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,558 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,558 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_18/sub_2/y/ExpandDims_11490/Dims
[ 2019-08-21 15:11:16,558 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,558 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,558 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,558 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_18/sub_2/y/ExpandDims_11489/Dims
[ 2019-08-21 15:11:16,559 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,559 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,559 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,559 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,559 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_18/sub_2/y/ExpandDims_/Dims
[ 2019-08-21 15:11:16,559 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,560 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,560 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,560 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_65/ExpandDims_11486/Dims
[ 2019-08-21 15:11:16,560 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,560 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,560 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,560 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_65/ExpandDims_/Dims
[ 2019-08-21 15:11:16,561 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,561 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,561 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,561 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,561 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,561 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_64/ExpandDims_11483/Dims
[ 2019-08-21 15:11:16,562 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,565 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,565 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_64/ExpandDims_/Dims
[ 2019-08-21 15:11:16,565 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,565 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,565 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,566 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,566 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,566 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_83/sub_2/y/ExpandDims_11480/Dims
[ 2019-08-21 15:11:16,566 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,566 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,567 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,567 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,567 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,567 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_83/sub_2/y/ExpandDims_11479/Dims
[ 2019-08-21 15:11:16,567 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,567 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,568 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,568 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,568 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,568 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_83/sub_2/y/ExpandDims_11478/Dims
[ 2019-08-21 15:11:16,568 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,568 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,569 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,569 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,569 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ChangeCoordinateFrame_83/sub_2/y/ExpandDims_/Dims
[ 2019-08-21 15:11:16,569 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,569 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,569 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,569 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/stack/ExpandDims_11475/Dims
[ 2019-08-21 15:11:16,570 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,570 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,570 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,570 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,570 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/stack/ExpandDims_11474/Dims
[ 2019-08-21 15:11:16,570 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,571 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,571 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/stack/ExpandDims_11473/Dims
[ 2019-08-21 15:11:16,571 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,571 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,571 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,571 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,571 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/stack/ExpandDims_/Dims
[ 2019-08-21 15:11:16,572 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,572 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,572 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_18/ExpandDims_11470/Dims
[ 2019-08-21 15:11:16,572 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,572 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,572 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,573 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_18/ExpandDims_/Dims
[ 2019-08-21 15:11:16,573 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,573 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,573 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,573 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,573 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,573 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11467
[ 2019-08-21 15:11:16,574 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 -1]
[ 2019-08-21 15:11:16,577 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,577 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11465
[ 2019-08-21 15:11:16,577 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,577 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,577 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,577 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,577 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11463
[ 2019-08-21 15:11:16,578 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,578 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,578 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,578 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,578 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,578 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11461
[ 2019-08-21 15:11:16,579 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,579 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,579 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,579 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,579 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11459
[ 2019-08-21 15:11:16,579 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,580 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,580 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,580 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,580 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,580 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11457
[ 2019-08-21 15:11:16,580 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,581 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,581 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,581 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11455
[ 2019-08-21 15:11:16,581 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,581 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,581 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,581 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11453
[ 2019-08-21 15:11:16,582 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,582 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,582 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,582 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11451
[ 2019-08-21 15:11:16,582 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,582 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,582 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11449
[ 2019-08-21 15:11:16,583 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,583 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,583 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,583 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,583 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11447
[ 2019-08-21 15:11:16,583 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,584 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,584 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,584 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11445
[ 2019-08-21 15:11:16,584 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,584 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,584 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,584 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11443
[ 2019-08-21 15:11:16,585 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,585 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,585 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,585 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,585 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11441
[ 2019-08-21 15:11:16,585 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,585 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11439
[ 2019-08-21 15:11:16,586 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,588 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,589 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,589 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,589 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,589 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11437
[ 2019-08-21 15:11:16,589 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,589 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,590 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,590 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,590 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11435
[ 2019-08-21 15:11:16,590 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,590 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,590 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,591 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,591 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,591 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11433
[ 2019-08-21 15:11:16,591 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,591 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,591 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,592 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,592 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,592 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11431
[ 2019-08-21 15:11:16,592 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,592 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,592 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,593 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11429
[ 2019-08-21 15:11:16,593 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,593 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,593 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,593 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,593 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,593 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11427
[ 2019-08-21 15:11:16,594 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,594 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11425
[ 2019-08-21 15:11:16,594 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,594 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,594 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,594 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,594 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11423
[ 2019-08-21 15:11:16,595 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,595 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,595 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11421
[ 2019-08-21 15:11:16,595 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,595 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,595 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,595 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11419
[ 2019-08-21 15:11:16,596 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,596 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,596 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11417
[ 2019-08-21 15:11:16,596 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,596 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,596 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,597 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,599 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,600 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11415
[ 2019-08-21 15:11:16,600 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,600 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,600 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,600 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,601 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,601 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11413
[ 2019-08-21 15:11:16,601 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,601 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,601 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,601 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,601 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11411
[ 2019-08-21 15:11:16,602 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,602 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,602 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,602 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,602 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,602 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11409
[ 2019-08-21 15:11:16,603 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,603 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,603 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11407
[ 2019-08-21 15:11:16,603 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,603 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,603 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,603 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11405
[ 2019-08-21 15:11:16,604 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,604 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,604 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,604 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,604 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11403
[ 2019-08-21 15:11:16,604 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,604 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11401
[ 2019-08-21 15:11:16,605 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,605 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,605 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,605 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,605 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,605 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11399
[ 2019-08-21 15:11:16,606 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11397
[ 2019-08-21 15:11:16,606 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,606 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,606 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,606 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,606 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,606 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11395
[ 2019-08-21 15:11:16,607 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,607 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11393
[ 2019-08-21 15:11:16,607 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,607 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,607 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,607 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,607 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11391
[ 2019-08-21 15:11:16,608 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,610 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,611 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11389
[ 2019-08-21 15:11:16,611 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,611 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,611 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,611 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,611 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,611 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11387
[ 2019-08-21 15:11:16,612 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,612 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,612 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,612 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,612 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11385
[ 2019-08-21 15:11:16,612 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,612 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11383
[ 2019-08-21 15:11:16,613 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,613 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,613 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,613 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,613 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,613 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11381
[ 2019-08-21 15:11:16,614 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,614 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11379
[ 2019-08-21 15:11:16,614 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,614 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,614 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,614 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,614 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11377
[ 2019-08-21 15:11:16,615 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,615 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11375
[ 2019-08-21 15:11:16,615 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,615 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,615 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,615 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,615 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11373
[ 2019-08-21 15:11:16,616 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,616 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,616 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11371
[ 2019-08-21 15:11:16,616 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,616 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,616 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,616 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11369
[ 2019-08-21 15:11:16,617 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,617 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,617 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,617 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,617 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,617 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11367
[ 2019-08-21 15:11:16,618 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,618 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11365
[ 2019-08-21 15:11:16,618 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,618 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,618 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,618 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,618 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11363
[ 2019-08-21 15:11:16,621 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,622 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11361
[ 2019-08-21 15:11:16,622 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,622 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,622 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,622 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,622 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,623 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11359
[ 2019-08-21 15:11:16,623 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,623 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,623 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,623 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,623 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,623 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11357
[ 2019-08-21 15:11:16,624 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,624 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,624 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,624 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11355
[ 2019-08-21 15:11:16,624 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,624 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,624 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11353
[ 2019-08-21 15:11:16,625 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,625 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,625 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,625 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,625 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11351
[ 2019-08-21 15:11:16,625 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,625 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11349
[ 2019-08-21 15:11:16,626 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,626 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,626 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,626 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,626 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11347
[ 2019-08-21 15:11:16,626 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,626 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11345
[ 2019-08-21 15:11:16,627 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,627 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,627 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,627 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,627 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,627 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11343
[ 2019-08-21 15:11:16,628 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11341
[ 2019-08-21 15:11:16,628 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,628 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,628 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,628 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,628 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,628 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11339
[ 2019-08-21 15:11:16,629 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,629 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,629 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11337
[ 2019-08-21 15:11:16,629 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,629 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,629 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,629 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11335
[ 2019-08-21 15:11:16,632 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,633 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,633 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11333
[ 2019-08-21 15:11:16,633 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,633 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,633 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,634 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,634 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,634 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11331
[ 2019-08-21 15:11:16,634 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,634 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,634 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,635 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,635 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,635 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11329
[ 2019-08-21 15:11:16,635 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,635 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,635 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,636 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,636 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11327
[ 2019-08-21 15:11:16,636 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,636 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,636 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,636 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,637 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,637 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11325
[ 2019-08-21 15:11:16,637 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,637 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,637 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,637 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,637 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11323
[ 2019-08-21 15:11:16,638 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,638 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,638 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11321
[ 2019-08-21 15:11:16,638 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,638 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,638 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,638 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11319
[ 2019-08-21 15:11:16,639 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,639 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,639 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,639 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11317
[ 2019-08-21 15:11:16,639 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,639 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,639 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11315
[ 2019-08-21 15:11:16,640 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,640 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,640 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,640 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,640 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11313
[ 2019-08-21 15:11:16,640 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,640 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11311
[ 2019-08-21 15:11:16,643 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,644 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,644 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,644 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,644 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11309
[ 2019-08-21 15:11:16,644 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,644 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,645 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,645 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,645 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,645 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11307
[ 2019-08-21 15:11:16,645 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,645 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,646 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,646 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,646 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11305
[ 2019-08-21 15:11:16,646 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,646 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,646 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,647 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,647 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11303
[ 2019-08-21 15:11:16,647 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,647 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,647 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,647 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,647 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11301
[ 2019-08-21 15:11:16,648 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,648 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,648 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11299
[ 2019-08-21 15:11:16,648 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,648 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,648 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,648 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11297
[ 2019-08-21 15:11:16,649 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,649 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,649 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11295
[ 2019-08-21 15:11:16,649 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,649 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,649 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,649 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11293
[ 2019-08-21 15:11:16,650 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,650 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,650 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,650 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,650 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11291
[ 2019-08-21 15:11:16,650 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,651 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,651 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,651 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11289
[ 2019-08-21 15:11:16,651 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,651 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,651 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,651 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11287
[ 2019-08-21 15:11:16,654 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,655 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,655 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11285
[ 2019-08-21 15:11:16,655 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,655 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,655 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,655 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,655 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11283
[ 2019-08-21 15:11:16,656 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,656 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11281
[ 2019-08-21 15:11:16,656 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,656 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,656 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,656 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,656 ] [ DEBUG ] [ infer:130 ]  Partial infer for 11279
[ 2019-08-21 15:11:16,657 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,657 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,657 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,657 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,657 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,657 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_89/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,658 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,658 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,658 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,658 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,658 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,658 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_88/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,659 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,659 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,659 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,659 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,659 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_87/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,659 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,660 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,660 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,660 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,660 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_86/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,660 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,660 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,661 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_85/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,661 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,661 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,661 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,661 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,661 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,661 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_84/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,662 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,662 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,662 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_83/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,662 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,662 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,662 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,662 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_82/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,663 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,666 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,666 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,666 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,666 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_81/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,666 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,667 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,667 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,667 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,667 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,667 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_80/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,667 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,668 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,668 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,668 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,668 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,668 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_79/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,668 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,669 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,669 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,669 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_78/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,669 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,669 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,669 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,669 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_77/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,670 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,670 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,670 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,670 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,670 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_76/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,670 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,671 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,671 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_75/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,671 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,671 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,671 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,671 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,671 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_74/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,672 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,672 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,672 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_73/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,672 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,672 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,672 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,672 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_72/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,673 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,673 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,673 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,673 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,673 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_71/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,673 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,674 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,676 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,676 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_70/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,677 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,677 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,677 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,677 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,677 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,677 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_69/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,678 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,678 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,678 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_68/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,678 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,678 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,678 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,678 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_67/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,679 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,679 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,679 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,679 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,679 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,679 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_66/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,680 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,680 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,680 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,680 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,680 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_65/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,680 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,681 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,681 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,681 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_64/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,681 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,681 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,681 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,681 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_63/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,682 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,682 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,682 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,682 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,682 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,682 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_62/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,683 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,683 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,683 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_61/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,683 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,683 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,683 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,684 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,684 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_60/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,684 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,684 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,684 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,685 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,687 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,687 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_59/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,688 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,688 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,688 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,688 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,688 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,688 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_58/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,689 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,689 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,689 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_57/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,689 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,689 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,689 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,690 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,690 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,690 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_56/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,690 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,690 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,690 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,691 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,691 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,691 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_55/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,691 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,691 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,691 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,692 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,692 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,692 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_54/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,692 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,692 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,692 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,693 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_53/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,693 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,693 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,693 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,693 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,693 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,693 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_52/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,694 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,694 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,694 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_51/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,694 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,694 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,694 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,694 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_50/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,695 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,695 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,695 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,695 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,695 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_49/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,695 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,696 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,698 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_48/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,698 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,699 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,699 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,699 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,699 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,699 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_47/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,699 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,700 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,700 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,700 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,700 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_46/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,700 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,700 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,701 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,701 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,701 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_45/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,701 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,701 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,701 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,701 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_44/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,702 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,702 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,702 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,702 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,702 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_43/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,702 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,703 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,703 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_42/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,703 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,703 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,703 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,703 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,703 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_41/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,704 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,704 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,704 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_40/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,704 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,704 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,704 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,704 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_39/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,705 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,705 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,705 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,705 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,705 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_38/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,705 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,706 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,706 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,706 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_37/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,706 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,706 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,706 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,706 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_36/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,707 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,709 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,710 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,710 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,710 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,710 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_35/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,710 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,710 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,711 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,711 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_34/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,711 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,711 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,711 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,711 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,712 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,712 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_33/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,712 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,712 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,712 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,712 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,713 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,713 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_32/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,713 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,713 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,713 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,714 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,714 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,714 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_31/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,714 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,714 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,714 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,714 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_30/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,715 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,715 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,715 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,715 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,715 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,715 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_29/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,716 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,716 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_28/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,716 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,716 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,716 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,716 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,717 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_27/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,717 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,717 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,717 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,717 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,718 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,720 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_26/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,720 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,721 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,721 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,721 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,721 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,721 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_25/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,721 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,722 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,722 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_24/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,722 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,722 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,722 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,722 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,723 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,723 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_23/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,723 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,723 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,723 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,723 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,724 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,724 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_22/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,724 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,724 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,724 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,725 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,725 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,725 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_21/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,725 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,725 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,725 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,726 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,726 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,726 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_20/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,726 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,726 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,726 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,727 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_19/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,727 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,727 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,727 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,727 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,727 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,727 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_18/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,728 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,728 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,728 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_17/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,728 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,728 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,728 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,728 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_16/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,729 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,731 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,731 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,732 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,732 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_15/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,732 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,732 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,732 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,732 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,732 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_14/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,733 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,733 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,733 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,733 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,733 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_13/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,733 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,734 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,734 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,734 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,734 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,734 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_12/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,734 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,735 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,735 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,735 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,735 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,735 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_11/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,735 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,736 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,736 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,736 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_10/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,736 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,736 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,736 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,736 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_9/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,737 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,737 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,737 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,737 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,737 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,737 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_8/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,738 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,738 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_7/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,738 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,738 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,738 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,738 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,738 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_6/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,739 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,739 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,739 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,739 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_5/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,739 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,739 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,740 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,742 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_4/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,743 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,743 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,743 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,743 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,743 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,743 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_3/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,744 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,744 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,744 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,744 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,744 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,744 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_2/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,745 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,745 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,745 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,745 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,745 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow_1/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,745 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,746 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,746 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,746 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,746 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,746 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,746 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,746 ] [ DEBUG ] [ infer:130 ]  Partial infer for Squeeze_3/Dims
[ 2019-08-21 15:11:16,747 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,747 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,747 ] [ DEBUG ] [ infer:130 ]  Partial infer for Squeeze_2/Dims
[ 2019-08-21 15:11:16,747 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,747 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,747 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,747 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/ClipToWindow/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,748 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,748 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,748 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,748 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,748 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,748 ] [ DEBUG ] [ infer:130 ]  Partial infer for Squeeze_1/Dims
[ 2019-08-21 15:11:16,749 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:16,749 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,749 ] [ DEBUG ] [ infer:130 ]  Partial infer for ClipToWindow/Area/Squeeze/Dims
[ 2019-08-21 15:11:16,749 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,749 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,749 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,749 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,749 ] [ DEBUG ] [ infer:130 ]  Partial infer for Squeeze/Dims
[ 2019-08-21 15:11:16,750 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,750 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,750 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,750 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:16,750 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,750 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/Squeeze/Dims
[ 2019-08-21 15:11:16,753 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,753 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,754 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,754 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,754 ] [ DEBUG ] [ infer:130 ]  Partial infer for add/y
[ 2019-08-21 15:11:16,754 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,754 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,754 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,754 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1.0
[ 2019-08-21 15:11:16,754 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack_4/range/delta
[ 2019-08-21 15:11:16,755 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,755 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,755 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,755 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,755 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,755 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack_4/range/start
[ 2019-08-21 15:11:16,756 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,756 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,756 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,756 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,756 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,756 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack_2/range/delta
[ 2019-08-21 15:11:16,757 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,757 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,757 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,757 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,757 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack_2/range/start
[ 2019-08-21 15:11:16,757 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,758 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,758 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,758 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,758 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack_1/range/delta
[ 2019-08-21 15:11:16,758 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,758 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,758 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,758 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack_1/range/start
[ 2019-08-21 15:11:16,759 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,759 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,759 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,759 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,759 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack/range/delta
[ 2019-08-21 15:11:16,759 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,759 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,759 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayStack/range/start
[ 2019-08-21 15:11:16,760 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,760 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,760 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,760 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:16,760 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,760 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_89/shape
[ 2019-08-21 15:11:16,760 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,761 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,761 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_89/begin
[ 2019-08-21 15:11:16,761 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,761 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,761 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,761 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 89]
[ 2019-08-21 15:11:16,761 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_89/1
[ 2019-08-21 15:11:16,762 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,764 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,765 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,765 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,765 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_89/ExpandDims_1162012508
[ 2019-08-21 15:11:16,765 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,766 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,766 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,766 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,766 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,766 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,766 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,767 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_88/shape
[ 2019-08-21 15:11:16,767 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,767 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,767 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,767 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,768 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,768 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_88/begin
[ 2019-08-21 15:11:16,768 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,768 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,768 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,769 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 88]
[ 2019-08-21 15:11:16,769 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,769 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_88/1
[ 2019-08-21 15:11:16,769 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,769 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,769 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,770 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,770 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,770 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_88/ExpandDims_1173312674
[ 2019-08-21 15:11:16,770 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,771 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,771 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,771 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,771 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,771 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,772 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,772 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_87/shape
[ 2019-08-21 15:11:16,772 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,772 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,772 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,772 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,772 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_87/begin
[ 2019-08-21 15:11:16,773 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,775 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,776 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 87]
[ 2019-08-21 15:11:16,776 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,776 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_87/1
[ 2019-08-21 15:11:16,776 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,776 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,776 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,776 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,776 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_87/ExpandDims_1218013344
[ 2019-08-21 15:11:16,777 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,777 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,777 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,778 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,778 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,778 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,778 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,778 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_86/shape
[ 2019-08-21 15:11:16,778 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,779 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,779 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,779 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,779 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,779 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_86/begin
[ 2019-08-21 15:11:16,779 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,780 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,780 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 86]
[ 2019-08-21 15:11:16,780 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,780 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_86/1
[ 2019-08-21 15:11:16,780 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,780 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,781 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,781 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,781 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_86/ExpandDims_1201413096
[ 2019-08-21 15:11:16,781 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,781 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,782 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,782 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,782 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,782 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,782 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,782 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_85/shape
[ 2019-08-21 15:11:16,782 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,782 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,783 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,783 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,783 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_85/begin
[ 2019-08-21 15:11:16,783 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,783 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,783 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,783 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 85]
[ 2019-08-21 15:11:16,784 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,787 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_85/1
[ 2019-08-21 15:11:16,787 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,787 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,787 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,787 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,787 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,787 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_85/ExpandDims_1154712398
[ 2019-08-21 15:11:16,787 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,788 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,788 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,788 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,788 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,788 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,788 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,788 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_84/shape
[ 2019-08-21 15:11:16,788 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,789 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,789 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,789 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_84/begin
[ 2019-08-21 15:11:16,789 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,789 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,789 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,790 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 84]
[ 2019-08-21 15:11:16,790 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,790 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_84/1
[ 2019-08-21 15:11:16,790 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,790 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,790 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,790 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,791 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,791 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_84/ExpandDims_1222013404
[ 2019-08-21 15:11:16,791 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,791 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,792 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,792 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,792 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,792 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,792 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,792 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_83/shape
[ 2019-08-21 15:11:16,792 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,792 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,792 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,793 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,793 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_83/begin
[ 2019-08-21 15:11:16,793 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,793 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,793 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,793 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 83]
[ 2019-08-21 15:11:16,794 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_83/1
[ 2019-08-21 15:11:16,794 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,794 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,794 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,794 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,794 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,794 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_83/ExpandDims_1193112972
[ 2019-08-21 15:11:16,794 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,795 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,798 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,798 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,798 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,799 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,799 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,799 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_82/shape
[ 2019-08-21 15:11:16,799 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,800 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,800 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,800 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,800 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,801 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_82/begin
[ 2019-08-21 15:11:16,801 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,801 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,801 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,801 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 82]
[ 2019-08-21 15:11:16,801 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,802 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_82/1
[ 2019-08-21 15:11:16,802 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,802 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,802 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,802 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,802 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,802 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_82/ExpandDims_1177312732
[ 2019-08-21 15:11:16,802 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,803 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,803 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,804 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,804 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,804 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,804 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,804 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_81/shape
[ 2019-08-21 15:11:16,804 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,804 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,804 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,805 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,805 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_81/begin
[ 2019-08-21 15:11:16,805 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,805 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,805 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,805 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 81]
[ 2019-08-21 15:11:16,805 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_81/1
[ 2019-08-21 15:11:16,806 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,806 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,806 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,806 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_81/ExpandDims_1166112568
[ 2019-08-21 15:11:16,806 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,807 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,809 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,810 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,810 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,810 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,810 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,810 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_80/shape
[ 2019-08-21 15:11:16,810 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,810 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,810 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,811 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,811 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_80/begin
[ 2019-08-21 15:11:16,811 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,811 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,811 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,811 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 80]
[ 2019-08-21 15:11:16,812 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,812 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_80/1
[ 2019-08-21 15:11:16,812 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,812 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,812 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,812 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,813 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,813 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_80/ExpandDims_1227913494
[ 2019-08-21 15:11:16,813 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,813 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,814 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,814 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,814 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,814 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,814 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,814 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_79/shape
[ 2019-08-21 15:11:16,815 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,815 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,815 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,815 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,815 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,815 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_79/begin
[ 2019-08-21 15:11:16,816 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,816 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,816 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 79]
[ 2019-08-21 15:11:16,816 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,816 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_79/1
[ 2019-08-21 15:11:16,816 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,817 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,817 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,817 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_79/ExpandDims_1194812996
[ 2019-08-21 15:11:16,817 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,817 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,818 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,821 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,821 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,821 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,821 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,821 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_78/shape
[ 2019-08-21 15:11:16,821 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,821 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,822 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,822 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,822 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,822 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_78/begin
[ 2019-08-21 15:11:16,822 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,822 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,823 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 78]
[ 2019-08-21 15:11:16,823 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,823 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_78/1
[ 2019-08-21 15:11:16,823 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,823 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,823 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,823 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,824 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,824 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_78/ExpandDims_1212813268
[ 2019-08-21 15:11:16,824 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,824 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,824 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,825 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,825 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,825 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,825 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,825 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_77/shape
[ 2019-08-21 15:11:16,825 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,825 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,825 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,826 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,826 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_77/begin
[ 2019-08-21 15:11:16,826 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,826 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,826 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,826 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 77]
[ 2019-08-21 15:11:16,826 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_77/1
[ 2019-08-21 15:11:16,827 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,827 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,827 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_77/ExpandDims_1199513068
[ 2019-08-21 15:11:16,827 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,828 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,828 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,828 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,828 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,828 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,828 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,829 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_76/shape
[ 2019-08-21 15:11:16,831 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,832 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,832 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,832 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,833 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,833 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_76/begin
[ 2019-08-21 15:11:16,833 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,833 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,833 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,834 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 76]
[ 2019-08-21 15:11:16,834 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,834 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_76/1
[ 2019-08-21 15:11:16,834 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,834 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,834 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,835 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,835 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,835 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_76/ExpandDims_1216113316
[ 2019-08-21 15:11:16,835 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,836 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,836 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,836 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,836 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,836 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,837 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,837 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_75/shape
[ 2019-08-21 15:11:16,837 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,837 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,837 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,837 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,837 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_75/begin
[ 2019-08-21 15:11:16,838 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,838 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,838 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,838 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 75]
[ 2019-08-21 15:11:16,838 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,838 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_75/1
[ 2019-08-21 15:11:16,839 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,839 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,839 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,839 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_75/ExpandDims_1165812564
[ 2019-08-21 15:11:16,839 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,840 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,842 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,843 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,843 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,843 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,843 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,843 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_74/shape
[ 2019-08-21 15:11:16,843 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,843 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,844 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,844 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,844 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_74/begin
[ 2019-08-21 15:11:16,844 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,844 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,844 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,845 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 74]
[ 2019-08-21 15:11:16,845 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,845 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_74/1
[ 2019-08-21 15:11:16,845 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,845 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,845 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,846 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,846 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,846 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_74/ExpandDims_1164612548
[ 2019-08-21 15:11:16,846 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,847 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,847 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,847 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,847 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,847 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,848 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,848 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_73/shape
[ 2019-08-21 15:11:16,848 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,848 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,848 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,848 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,848 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_73/begin
[ 2019-08-21 15:11:16,849 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,849 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 73]
[ 2019-08-21 15:11:16,849 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,849 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_73/1
[ 2019-08-21 15:11:16,849 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,849 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,849 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,850 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,850 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_73/ExpandDims_1210013228
[ 2019-08-21 15:11:16,850 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,850 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,850 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,854 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,854 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,854 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,854 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,854 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_72/shape
[ 2019-08-21 15:11:16,855 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,855 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,855 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,855 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,855 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,856 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_72/begin
[ 2019-08-21 15:11:16,856 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,856 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,856 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,856 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 72]
[ 2019-08-21 15:11:16,856 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,856 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_72/1
[ 2019-08-21 15:11:16,857 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,857 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,857 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,857 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,857 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,857 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_72/ExpandDims_1153312378
[ 2019-08-21 15:11:16,857 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,858 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,858 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,858 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,858 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,858 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,858 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,858 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_71/shape
[ 2019-08-21 15:11:16,858 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,859 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,859 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,859 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,859 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,859 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_71/begin
[ 2019-08-21 15:11:16,859 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,859 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 71]
[ 2019-08-21 15:11:16,860 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,860 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_71/1
[ 2019-08-21 15:11:16,860 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,860 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,860 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,860 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,860 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_71/ExpandDims_1210313232
[ 2019-08-21 15:11:16,860 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,861 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,861 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,861 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,861 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,861 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,861 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,862 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_70/shape
[ 2019-08-21 15:11:16,864 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,865 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,865 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,865 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,865 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,865 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_70/begin
[ 2019-08-21 15:11:16,865 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,866 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,866 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 70]
[ 2019-08-21 15:11:16,867 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,867 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_70/1
[ 2019-08-21 15:11:16,867 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,867 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,867 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,867 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,868 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,868 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_70/ExpandDims_1165212556
[ 2019-08-21 15:11:16,868 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,868 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,869 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,869 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,869 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,869 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,869 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,870 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_69/shape
[ 2019-08-21 15:11:16,870 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,870 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,870 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,870 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,870 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,870 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_69/begin
[ 2019-08-21 15:11:16,871 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,871 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,871 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,871 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 69]
[ 2019-08-21 15:11:16,871 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,871 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_69/1
[ 2019-08-21 15:11:16,871 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,872 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,872 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_69/ExpandDims_1227313486
[ 2019-08-21 15:11:16,872 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,872 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,872 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,873 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,875 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,876 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,876 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,876 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_68/shape
[ 2019-08-21 15:11:16,876 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,876 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,876 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,876 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,877 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,877 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_68/begin
[ 2019-08-21 15:11:16,877 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,877 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,877 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,877 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 68]
[ 2019-08-21 15:11:16,878 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,878 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_68/1
[ 2019-08-21 15:11:16,878 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,878 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,878 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,878 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,879 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,879 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_68/ExpandDims_1210613236
[ 2019-08-21 15:11:16,879 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,880 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,880 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,880 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,880 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,880 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,880 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,881 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_67/shape
[ 2019-08-21 15:11:16,881 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,881 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,881 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,881 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,881 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,881 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_67/begin
[ 2019-08-21 15:11:16,882 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,882 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,882 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 67]
[ 2019-08-21 15:11:16,882 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,882 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_67/1
[ 2019-08-21 15:11:16,882 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,882 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,883 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_67/ExpandDims_1180412780
[ 2019-08-21 15:11:16,883 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,883 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,884 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,887 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,887 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,887 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,887 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,887 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_66/shape
[ 2019-08-21 15:11:16,887 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,887 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,888 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,888 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,888 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,888 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_66/begin
[ 2019-08-21 15:11:16,888 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,889 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,889 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,889 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 66]
[ 2019-08-21 15:11:16,889 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,889 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_66/1
[ 2019-08-21 15:11:16,889 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,890 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,890 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,890 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,890 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_66/ExpandDims_1149412318
[ 2019-08-21 15:11:16,890 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,891 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,891 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,891 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,892 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,892 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,892 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,892 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_65/shape
[ 2019-08-21 15:11:16,892 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,892 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,892 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,893 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,893 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_65/begin
[ 2019-08-21 15:11:16,893 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,893 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,893 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,893 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 65]
[ 2019-08-21 15:11:16,893 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_65/1
[ 2019-08-21 15:11:16,894 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,894 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,894 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_65/ExpandDims_1148612306
[ 2019-08-21 15:11:16,894 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,894 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,895 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,897 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,898 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,898 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,898 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,898 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_64/shape
[ 2019-08-21 15:11:16,898 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,898 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,899 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,899 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,899 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_64/begin
[ 2019-08-21 15:11:16,899 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,899 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,899 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,900 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 64]
[ 2019-08-21 15:11:16,900 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,900 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_64/1
[ 2019-08-21 15:11:16,900 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,900 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,901 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,901 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,901 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,901 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_64/ExpandDims_1148312302
[ 2019-08-21 15:11:16,901 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,902 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,902 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,902 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,902 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,902 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,903 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,903 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_63/shape
[ 2019-08-21 15:11:16,903 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,903 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,903 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,903 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,903 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_63/begin
[ 2019-08-21 15:11:16,904 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,904 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,904 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 63]
[ 2019-08-21 15:11:16,904 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,904 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_63/1
[ 2019-08-21 15:11:16,904 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,904 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,905 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_63/ExpandDims_1201113092
[ 2019-08-21 15:11:16,905 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,905 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,905 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,905 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,905 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,906 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,908 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,909 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_62/shape
[ 2019-08-21 15:11:16,909 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,909 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,909 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,909 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,910 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,910 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_62/begin
[ 2019-08-21 15:11:16,910 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,910 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,910 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,910 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 62]
[ 2019-08-21 15:11:16,911 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,911 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_62/1
[ 2019-08-21 15:11:16,911 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,911 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,911 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,911 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,911 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_62/ExpandDims_1191812952
[ 2019-08-21 15:11:16,911 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,912 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,912 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,912 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,912 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,913 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,913 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,913 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_61/shape
[ 2019-08-21 15:11:16,913 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,913 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,913 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,913 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,913 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_61/begin
[ 2019-08-21 15:11:16,914 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,914 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,914 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 61]
[ 2019-08-21 15:11:16,914 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,914 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_61/1
[ 2019-08-21 15:11:16,914 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,914 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,915 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,915 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_61/ExpandDims_1172712666
[ 2019-08-21 15:11:16,915 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,915 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,915 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,916 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,916 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,916 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,916 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,916 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_60/shape
[ 2019-08-21 15:11:16,916 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,916 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,917 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,920 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,920 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_60/begin
[ 2019-08-21 15:11:16,920 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,920 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,920 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,921 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 60]
[ 2019-08-21 15:11:16,921 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,921 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_60/1
[ 2019-08-21 15:11:16,921 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,921 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,921 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,921 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,922 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,922 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_60/ExpandDims_1199813072
[ 2019-08-21 15:11:16,922 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,923 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,923 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,923 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,923 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,923 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,923 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,924 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_59/shape
[ 2019-08-21 15:11:16,924 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,924 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,924 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,924 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,924 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,924 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_59/begin
[ 2019-08-21 15:11:16,925 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,925 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,925 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 59]
[ 2019-08-21 15:11:16,925 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,925 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_59/1
[ 2019-08-21 15:11:16,925 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,925 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,926 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,926 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_59/ExpandDims_1160712488
[ 2019-08-21 15:11:16,926 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,926 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,927 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,927 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,927 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,927 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,927 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,927 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_58/shape
[ 2019-08-21 15:11:16,927 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,927 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,928 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,930 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,931 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_58/begin
[ 2019-08-21 15:11:16,931 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,931 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,931 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,931 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 58]
[ 2019-08-21 15:11:16,931 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,932 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_58/1
[ 2019-08-21 15:11:16,932 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,932 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,932 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,932 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,932 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,932 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_58/ExpandDims_1160412484
[ 2019-08-21 15:11:16,932 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,933 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,933 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,934 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,934 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,934 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,934 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,934 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_57/shape
[ 2019-08-21 15:11:16,934 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,935 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,935 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,935 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,935 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,935 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_57/begin
[ 2019-08-21 15:11:16,935 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,936 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,936 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 57]
[ 2019-08-21 15:11:16,936 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,936 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_57/1
[ 2019-08-21 15:11:16,936 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,936 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,936 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,937 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,937 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_57/ExpandDims_1151212346
[ 2019-08-21 15:11:16,937 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,937 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,938 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,938 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,938 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,938 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,938 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,938 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_56/shape
[ 2019-08-21 15:11:16,938 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,938 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,939 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,941 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,941 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_56/begin
[ 2019-08-21 15:11:16,942 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,942 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,942 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,942 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 56]
[ 2019-08-21 15:11:16,942 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,942 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_56/1
[ 2019-08-21 15:11:16,942 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,943 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,943 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_56/ExpandDims_1212213260
[ 2019-08-21 15:11:16,943 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,943 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,944 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,944 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,944 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,944 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,944 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,944 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_55/shape
[ 2019-08-21 15:11:16,944 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,945 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,945 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,945 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,945 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,945 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_55/begin
[ 2019-08-21 15:11:16,946 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,946 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,946 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,946 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 55]
[ 2019-08-21 15:11:16,946 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,946 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_55/1
[ 2019-08-21 15:11:16,947 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,947 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,947 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,947 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,947 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_55/ExpandDims_1197713040
[ 2019-08-21 15:11:16,947 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,948 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,948 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,948 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,948 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,948 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,948 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,948 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_54/shape
[ 2019-08-21 15:11:16,949 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,949 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,949 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,949 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,949 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,949 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_54/begin
[ 2019-08-21 15:11:16,950 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 54]
[ 2019-08-21 15:11:16,953 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,953 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_54/1
[ 2019-08-21 15:11:16,953 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,953 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,953 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,954 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,954 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,954 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_54/ExpandDims_1157512440
[ 2019-08-21 15:11:16,954 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,955 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,955 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,955 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,955 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,955 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,956 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,956 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_53/shape
[ 2019-08-21 15:11:16,956 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,956 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,956 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,957 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,957 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,957 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_53/begin
[ 2019-08-21 15:11:16,957 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,957 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,957 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,958 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 53]
[ 2019-08-21 15:11:16,958 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,958 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_53/1
[ 2019-08-21 15:11:16,958 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,958 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,958 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,958 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,958 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_53/ExpandDims_1217713340
[ 2019-08-21 15:11:16,959 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,959 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,959 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,959 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,959 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,960 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,960 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,960 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_52/shape
[ 2019-08-21 15:11:16,960 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,960 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,960 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,960 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,961 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_52/begin
[ 2019-08-21 15:11:16,961 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,961 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,961 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,961 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 52]
[ 2019-08-21 15:11:16,961 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,961 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_52/1
[ 2019-08-21 15:11:16,965 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,965 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,965 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,965 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,966 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_52/ExpandDims_1221713400
[ 2019-08-21 15:11:16,966 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,966 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,967 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,967 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,967 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,967 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,967 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,967 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_51/shape
[ 2019-08-21 15:11:16,968 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,968 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,968 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,968 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,968 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,968 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_51/begin
[ 2019-08-21 15:11:16,969 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,969 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,969 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 51]
[ 2019-08-21 15:11:16,969 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,969 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_51/1
[ 2019-08-21 15:11:16,969 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,969 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,970 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,970 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_51/ExpandDims_1205313156
[ 2019-08-21 15:11:16,970 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,970 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,971 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,971 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,971 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,971 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,971 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,971 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_50/shape
[ 2019-08-21 15:11:16,971 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,971 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,972 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,972 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,972 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,972 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_50/begin
[ 2019-08-21 15:11:16,972 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,972 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,972 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 50]
[ 2019-08-21 15:11:16,973 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_50/1
[ 2019-08-21 15:11:16,973 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,973 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,973 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,973 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,973 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,973 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_50/ExpandDims_1214513292
[ 2019-08-21 15:11:16,973 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,974 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,977 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,977 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,977 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,977 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,977 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,977 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_49/shape
[ 2019-08-21 15:11:16,978 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,978 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,978 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,978 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,978 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,978 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_49/begin
[ 2019-08-21 15:11:16,979 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,979 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,979 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,979 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 49]
[ 2019-08-21 15:11:16,979 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,979 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_49/1
[ 2019-08-21 15:11:16,980 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,980 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,980 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,980 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,980 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_49/ExpandDims_1187012880
[ 2019-08-21 15:11:16,980 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,981 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,981 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,981 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,981 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,981 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,981 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,981 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_48/shape
[ 2019-08-21 15:11:16,981 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,982 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,982 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,982 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,982 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,982 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_48/begin
[ 2019-08-21 15:11:16,982 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,982 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 48]
[ 2019-08-21 15:11:16,983 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,983 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_48/1
[ 2019-08-21 15:11:16,983 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,983 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,983 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,983 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,983 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_48/ExpandDims_1187312884
[ 2019-08-21 15:11:16,984 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,984 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,987 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,988 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,988 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,988 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,988 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,988 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_47/shape
[ 2019-08-21 15:11:16,988 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,988 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,989 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,989 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,989 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,989 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_47/begin
[ 2019-08-21 15:11:16,989 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,989 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,990 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,990 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 47]
[ 2019-08-21 15:11:16,990 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,990 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_47/1
[ 2019-08-21 15:11:16,990 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,990 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,991 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,991 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,991 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_47/ExpandDims_1205613160
[ 2019-08-21 15:11:16,991 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,992 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,992 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,992 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,992 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,992 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,992 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,992 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_46/shape
[ 2019-08-21 15:11:16,992 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,993 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,993 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,993 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,993 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_46/begin
[ 2019-08-21 15:11:16,993 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,993 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,993 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 46]
[ 2019-08-21 15:11:16,994 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_46/1
[ 2019-08-21 15:11:16,994 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,994 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,994 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,994 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,994 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,994 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_46/ExpandDims_1173612678
[ 2019-08-21 15:11:16,994 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:16,995 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,995 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:16,995 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:16,995 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,995 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:16,995 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,995 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_45/shape
[ 2019-08-21 15:11:16,995 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:16,996 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:16,999 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:16,999 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:16,999 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:16,999 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_45/begin
[ 2019-08-21 15:11:16,999 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,000 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,000 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,000 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 45]
[ 2019-08-21 15:11:17,000 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,000 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_45/1
[ 2019-08-21 15:11:17,001 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,001 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,001 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,001 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,001 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,001 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_45/ExpandDims_1194212988
[ 2019-08-21 15:11:17,001 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,002 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,002 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,002 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,003 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,003 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,003 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,003 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_44/shape
[ 2019-08-21 15:11:17,003 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,003 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,003 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,004 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,004 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_44/begin
[ 2019-08-21 15:11:17,004 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,004 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,004 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,004 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 44]
[ 2019-08-21 15:11:17,005 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_44/1
[ 2019-08-21 15:11:17,005 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,005 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,005 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,005 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,005 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,005 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_44/ExpandDims_1157812444
[ 2019-08-21 15:11:17,005 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,006 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,006 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,006 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,006 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,006 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,006 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,007 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_43/shape
[ 2019-08-21 15:11:17,007 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,007 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,007 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,007 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,007 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,010 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_43/begin
[ 2019-08-21 15:11:17,010 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,011 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,011 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,011 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 43]
[ 2019-08-21 15:11:17,011 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,011 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_43/1
[ 2019-08-21 15:11:17,011 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,012 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,012 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,012 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_43/ExpandDims_1171612650
[ 2019-08-21 15:11:17,012 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,013 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,013 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,013 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,013 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,013 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,014 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,014 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_42/shape
[ 2019-08-21 15:11:17,014 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,014 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,014 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,014 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,015 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,015 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_42/begin
[ 2019-08-21 15:11:17,015 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,015 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,015 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,015 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 42]
[ 2019-08-21 15:11:17,016 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_42/1
[ 2019-08-21 15:11:17,016 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,016 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,016 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,016 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,016 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,016 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_42/ExpandDims_1160112480
[ 2019-08-21 15:11:17,016 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,017 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,017 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,017 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,017 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,018 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,018 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,018 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_41/shape
[ 2019-08-21 15:11:17,018 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,018 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,019 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,021 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,022 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,022 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_41/begin
[ 2019-08-21 15:11:17,022 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,022 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,022 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,022 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 41]
[ 2019-08-21 15:11:17,022 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_41/1
[ 2019-08-21 15:11:17,023 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,023 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,023 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,023 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_41/ExpandDims_1170312630
[ 2019-08-21 15:11:17,023 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,024 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,024 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,024 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,025 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,025 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,025 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,025 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_40/shape
[ 2019-08-21 15:11:17,025 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,026 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,026 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,026 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,026 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,026 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_40/begin
[ 2019-08-21 15:11:17,026 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,027 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,027 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,027 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 40]
[ 2019-08-21 15:11:17,027 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,027 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_40/1
[ 2019-08-21 15:11:17,027 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,028 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,028 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,028 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,028 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,028 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_40/ExpandDims_1223513426
[ 2019-08-21 15:11:17,028 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,029 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,029 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,029 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,029 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,029 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,029 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,029 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_39/shape
[ 2019-08-21 15:11:17,029 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,030 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,032 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,033 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,033 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,034 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_39/begin
[ 2019-08-21 15:11:17,034 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,034 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,034 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,034 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 39]
[ 2019-08-21 15:11:17,035 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,035 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_39/1
[ 2019-08-21 15:11:17,035 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,035 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,035 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,035 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,036 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,036 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_39/ExpandDims_1163812536
[ 2019-08-21 15:11:17,036 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,037 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,037 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,037 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,037 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,037 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,037 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,037 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_38/shape
[ 2019-08-21 15:11:17,038 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,038 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,038 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,038 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,038 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,038 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_38/begin
[ 2019-08-21 15:11:17,039 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 38]
[ 2019-08-21 15:11:17,039 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,039 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_38/1
[ 2019-08-21 15:11:17,039 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,039 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,039 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,039 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,039 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_38/ExpandDims_1217413336
[ 2019-08-21 15:11:17,039 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,040 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,040 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,040 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,040 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,040 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,041 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,043 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_37/shape
[ 2019-08-21 15:11:17,044 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,044 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,044 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,044 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,044 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,044 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_37/begin
[ 2019-08-21 15:11:17,045 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 37]
[ 2019-08-21 15:11:17,045 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,045 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_37/1
[ 2019-08-21 15:11:17,045 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,045 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,045 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,045 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,046 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,046 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_37/ExpandDims_1220613384
[ 2019-08-21 15:11:17,046 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,047 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,047 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,047 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,047 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,047 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,048 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,048 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_36/shape
[ 2019-08-21 15:11:17,048 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,048 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,048 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,048 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,049 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,049 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_36/begin
[ 2019-08-21 15:11:17,049 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,049 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,049 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,049 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 36]
[ 2019-08-21 15:11:17,049 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_36/1
[ 2019-08-21 15:11:17,050 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,050 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,050 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,050 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,050 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_36/ExpandDims_1181812800
[ 2019-08-21 15:11:17,050 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,051 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,051 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,052 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,054 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,054 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,055 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,055 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_35/shape
[ 2019-08-21 15:11:17,055 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,055 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,055 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,055 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,056 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_35/begin
[ 2019-08-21 15:11:17,056 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,056 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,056 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,056 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 35]
[ 2019-08-21 15:11:17,056 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,057 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_35/1
[ 2019-08-21 15:11:17,057 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,057 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,057 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,057 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,057 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,057 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_35/ExpandDims_1176612722
[ 2019-08-21 15:11:17,058 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,058 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,058 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,058 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,059 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,059 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,059 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,059 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_34/shape
[ 2019-08-21 15:11:17,059 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,059 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,060 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,060 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,060 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_34/begin
[ 2019-08-21 15:11:17,060 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,060 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,060 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,060 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 34]
[ 2019-08-21 15:11:17,061 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_34/1
[ 2019-08-21 15:11:17,061 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,061 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,061 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,061 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,061 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,061 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_34/ExpandDims_1173912682
[ 2019-08-21 15:11:17,061 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,062 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,062 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,062 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,062 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,062 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,062 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,062 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_33/shape
[ 2019-08-21 15:11:17,062 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,063 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,066 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,066 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,066 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,066 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_33/begin
[ 2019-08-21 15:11:17,067 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,067 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,067 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,067 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 33]
[ 2019-08-21 15:11:17,067 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,068 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_33/1
[ 2019-08-21 15:11:17,068 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,068 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,068 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,068 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,068 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,068 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_33/ExpandDims_1168012596
[ 2019-08-21 15:11:17,069 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,069 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,069 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,070 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,070 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,070 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,070 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,070 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_32/shape
[ 2019-08-21 15:11:17,070 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,071 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,071 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,071 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,071 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,071 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_32/begin
[ 2019-08-21 15:11:17,071 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,072 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 32]
[ 2019-08-21 15:11:17,072 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,072 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_32/1
[ 2019-08-21 15:11:17,072 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,072 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,072 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,072 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,073 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,073 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_32/ExpandDims_1175812710
[ 2019-08-21 15:11:17,073 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,074 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,074 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,074 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,074 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,074 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,074 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,074 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_31/shape
[ 2019-08-21 15:11:17,075 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,078 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,078 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,078 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,078 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,078 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_31/begin
[ 2019-08-21 15:11:17,078 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,079 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,079 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,079 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 31]
[ 2019-08-21 15:11:17,079 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,079 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_31/1
[ 2019-08-21 15:11:17,079 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,080 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,080 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,080 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,080 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,080 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_31/ExpandDims_1195113000
[ 2019-08-21 15:11:17,080 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,081 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,081 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,081 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,081 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,081 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,081 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,081 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_30/shape
[ 2019-08-21 15:11:17,081 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,082 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,082 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,082 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,082 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_30/begin
[ 2019-08-21 15:11:17,082 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,082 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,082 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 30]
[ 2019-08-21 15:11:17,083 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_30/1
[ 2019-08-21 15:11:17,083 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,083 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,083 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,083 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,083 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,083 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_30/ExpandDims_1191512948
[ 2019-08-21 15:11:17,083 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,084 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,084 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,084 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,084 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,085 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,085 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,085 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_29/shape
[ 2019-08-21 15:11:17,085 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,085 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,085 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,085 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,085 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_29/begin
[ 2019-08-21 15:11:17,086 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,088 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,089 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 29]
[ 2019-08-21 15:11:17,089 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,089 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_29/1
[ 2019-08-21 15:11:17,089 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,089 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,090 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,090 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,090 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,090 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_29/ExpandDims_1153012374
[ 2019-08-21 15:11:17,090 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,091 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,091 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,091 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,091 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,091 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,091 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,092 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_28/shape
[ 2019-08-21 15:11:17,092 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,092 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,092 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,092 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,092 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,093 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_28/begin
[ 2019-08-21 15:11:17,093 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,093 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,093 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,093 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 28]
[ 2019-08-21 15:11:17,093 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,094 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_28/1
[ 2019-08-21 15:11:17,094 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,094 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,094 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,094 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,094 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,094 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_28/ExpandDims_1204013136
[ 2019-08-21 15:11:17,094 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,095 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,095 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,095 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,095 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,096 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,096 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,096 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_27/shape
[ 2019-08-21 15:11:17,096 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,096 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,096 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,096 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,096 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_27/begin
[ 2019-08-21 15:11:17,097 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,100 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,100 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 27]
[ 2019-08-21 15:11:17,100 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,100 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_27/1
[ 2019-08-21 15:11:17,101 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,101 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,101 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,101 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,101 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,101 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_27/ExpandDims_1210913240
[ 2019-08-21 15:11:17,101 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,102 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,102 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,102 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,103 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,103 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,103 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,103 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_26/shape
[ 2019-08-21 15:11:17,103 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,103 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,104 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,104 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,104 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,104 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_26/begin
[ 2019-08-21 15:11:17,104 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,104 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,105 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,105 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 26]
[ 2019-08-21 15:11:17,105 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,105 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_26/1
[ 2019-08-21 15:11:17,105 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,105 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,105 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,106 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,106 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_26/ExpandDims_1213713280
[ 2019-08-21 15:11:17,106 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,106 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,106 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,107 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,107 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,107 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,107 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,107 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_25/shape
[ 2019-08-21 15:11:17,107 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,107 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,107 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,108 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,108 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_25/begin
[ 2019-08-21 15:11:17,108 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,108 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,108 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,108 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 25]
[ 2019-08-21 15:11:17,108 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_25/1
[ 2019-08-21 15:11:17,112 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,112 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,113 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,113 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,113 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_25/ExpandDims_1178112744
[ 2019-08-21 15:11:17,113 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,114 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,114 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,114 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,114 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,115 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,115 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,115 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_24/shape
[ 2019-08-21 15:11:17,115 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,115 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,115 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,116 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,116 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,116 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_24/begin
[ 2019-08-21 15:11:17,116 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,116 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,116 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,116 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 24]
[ 2019-08-21 15:11:17,117 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,117 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_24/1
[ 2019-08-21 15:11:17,117 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,117 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,117 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,117 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,117 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_24/ExpandDims_1169512618
[ 2019-08-21 15:11:17,117 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,118 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,118 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,118 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,118 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,119 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,119 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,119 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_23/shape
[ 2019-08-21 15:11:17,119 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,119 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,119 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,119 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,119 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_23/begin
[ 2019-08-21 15:11:17,120 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,120 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,120 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 23]
[ 2019-08-21 15:11:17,120 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,120 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_23/1
[ 2019-08-21 15:11:17,120 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,120 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,121 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_23/ExpandDims_1173012670
[ 2019-08-21 15:11:17,123 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,124 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,124 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,124 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,125 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,125 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,125 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,125 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_22/shape
[ 2019-08-21 15:11:17,125 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,125 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,126 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,126 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,126 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,126 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_22/begin
[ 2019-08-21 15:11:17,126 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,127 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,127 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,127 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 22]
[ 2019-08-21 15:11:17,127 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,127 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_22/1
[ 2019-08-21 15:11:17,127 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,128 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,128 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,128 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,128 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_22/ExpandDims_1183912832
[ 2019-08-21 15:11:17,128 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,129 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,129 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,129 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,129 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,129 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,129 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,129 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_21/shape
[ 2019-08-21 15:11:17,129 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,130 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,130 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,130 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,130 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_21/begin
[ 2019-08-21 15:11:17,130 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,130 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,130 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 21]
[ 2019-08-21 15:11:17,131 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_21/1
[ 2019-08-21 15:11:17,131 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,131 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,131 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,131 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,131 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,131 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_21/ExpandDims_1166412572
[ 2019-08-21 15:11:17,131 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,132 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,135 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,135 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,135 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,135 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,135 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,136 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_20/shape
[ 2019-08-21 15:11:17,136 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,136 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,136 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,136 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,136 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,136 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_20/begin
[ 2019-08-21 15:11:17,137 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 20]
[ 2019-08-21 15:11:17,137 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,137 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_20/1
[ 2019-08-21 15:11:17,137 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,137 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,137 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,137 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,137 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_20/ExpandDims_1153612382
[ 2019-08-21 15:11:17,137 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,138 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,138 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,138 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,138 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,139 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,139 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,139 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_19/shape
[ 2019-08-21 15:11:17,139 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,139 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,139 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,139 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,139 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_19/begin
[ 2019-08-21 15:11:17,140 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,140 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,140 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 19]
[ 2019-08-21 15:11:17,140 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,140 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_19/1
[ 2019-08-21 15:11:17,140 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,140 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,141 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_19/ExpandDims_1185212852
[ 2019-08-21 15:11:17,141 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,141 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,141 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,141 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,141 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,142 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,142 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,142 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_18/shape
[ 2019-08-21 15:11:17,142 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,142 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,142 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,142 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,143 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,143 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_18/begin
[ 2019-08-21 15:11:17,143 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,143 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,143 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,143 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 18]
[ 2019-08-21 15:11:17,143 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_18/1
[ 2019-08-21 15:11:17,144 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,147 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,147 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,147 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_18/ExpandDims_1147012282
[ 2019-08-21 15:11:17,147 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,148 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,148 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,148 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,148 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,149 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,149 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,149 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_17/shape
[ 2019-08-21 15:11:17,149 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,149 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,149 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,149 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,150 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,150 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_17/begin
[ 2019-08-21 15:11:17,150 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,150 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,150 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,150 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 17]
[ 2019-08-21 15:11:17,150 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_17/1
[ 2019-08-21 15:11:17,151 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,151 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,151 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,151 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,151 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,151 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_17/ExpandDims_1213413276
[ 2019-08-21 15:11:17,151 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,152 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,152 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,152 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,152 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,152 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,152 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,152 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_16/shape
[ 2019-08-21 15:11:17,152 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,153 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,153 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,153 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,153 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,153 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_16/begin
[ 2019-08-21 15:11:17,153 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,154 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 16]
[ 2019-08-21 15:11:17,154 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,154 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_16/1
[ 2019-08-21 15:11:17,154 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,154 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,154 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,154 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,154 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_16/ExpandDims_1189712920
[ 2019-08-21 15:11:17,154 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,155 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,155 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,155 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,155 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,156 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,158 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,158 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_15/shape
[ 2019-08-21 15:11:17,158 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,158 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,158 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,158 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,159 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_15/begin
[ 2019-08-21 15:11:17,159 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,159 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,159 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,159 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 15]
[ 2019-08-21 15:11:17,159 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,160 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_15/1
[ 2019-08-21 15:11:17,160 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,160 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,160 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,160 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,160 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,161 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_15/ExpandDims_1220313380
[ 2019-08-21 15:11:17,161 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,161 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,161 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,162 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,162 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,162 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,162 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,162 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_14/shape
[ 2019-08-21 15:11:17,162 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,162 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,163 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,163 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,163 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_14/begin
[ 2019-08-21 15:11:17,163 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,163 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,163 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,163 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 14]
[ 2019-08-21 15:11:17,163 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_14/1
[ 2019-08-21 15:11:17,164 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,164 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,164 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,164 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,164 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,164 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_14/ExpandDims_1165512560
[ 2019-08-21 15:11:17,164 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,165 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,165 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,165 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,165 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,165 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,165 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,165 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_13/shape
[ 2019-08-21 15:11:17,166 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,169 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,169 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,169 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,170 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,170 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_13/begin
[ 2019-08-21 15:11:17,170 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,170 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,170 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,170 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 13]
[ 2019-08-21 15:11:17,171 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,171 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_13/1
[ 2019-08-21 15:11:17,171 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,171 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,171 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,171 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,172 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_13/ExpandDims_1195913012
[ 2019-08-21 15:11:17,172 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,172 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,172 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,173 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,173 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,173 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,173 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,173 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_12/shape
[ 2019-08-21 15:11:17,173 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,173 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,173 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,174 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,174 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_12/begin
[ 2019-08-21 15:11:17,174 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,174 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,174 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,174 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 12]
[ 2019-08-21 15:11:17,174 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_12/1
[ 2019-08-21 15:11:17,175 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,175 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,175 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,175 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_12/ExpandDims_1156012418
[ 2019-08-21 15:11:17,175 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,176 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,176 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,176 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,176 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,176 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,176 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,176 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_11/shape
[ 2019-08-21 15:11:17,176 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,177 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,177 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,177 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,177 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_11/begin
[ 2019-08-21 15:11:17,177 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,177 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,177 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 11]
[ 2019-08-21 15:11:17,178 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_11/1
[ 2019-08-21 15:11:17,181 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,181 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,181 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,181 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,181 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,182 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_11/ExpandDims_1171912654
[ 2019-08-21 15:11:17,182 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,183 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,183 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,183 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,183 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,183 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,184 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,184 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_10/shape
[ 2019-08-21 15:11:17,184 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,184 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,184 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,184 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,185 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,185 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_10/begin
[ 2019-08-21 15:11:17,185 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,185 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,185 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,185 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [ 0 10]
[ 2019-08-21 15:11:17,186 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,186 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_10/1
[ 2019-08-21 15:11:17,186 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,186 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,186 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,186 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,187 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_10/ExpandDims_1193412976
[ 2019-08-21 15:11:17,187 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,187 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,187 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,188 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,188 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,188 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,188 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,188 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_9/shape
[ 2019-08-21 15:11:17,188 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,188 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,191 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,191 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,192 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,192 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_9/begin
[ 2019-08-21 15:11:17,192 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,192 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,192 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,192 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 9]
[ 2019-08-21 15:11:17,193 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,193 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_9/1
[ 2019-08-21 15:11:17,193 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,193 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,193 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,193 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,193 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_9/ExpandDims_1180712784
[ 2019-08-21 15:11:17,193 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,194 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,194 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,194 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,194 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,195 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,195 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,195 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_8/shape
[ 2019-08-21 15:11:17,195 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,195 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,195 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,195 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,196 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_8/begin
[ 2019-08-21 15:11:17,196 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,196 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,196 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,196 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 8]
[ 2019-08-21 15:11:17,196 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,196 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_8/1
[ 2019-08-21 15:11:17,197 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,197 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,197 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,197 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,197 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_8/ExpandDims_1167712592
[ 2019-08-21 15:11:17,197 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,198 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,198 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,198 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,198 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,198 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,198 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,198 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_7/shape
[ 2019-08-21 15:11:17,198 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,199 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,199 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,199 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,199 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_7/begin
[ 2019-08-21 15:11:17,199 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,199 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,200 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 7]
[ 2019-08-21 15:11:17,202 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,203 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_7/1
[ 2019-08-21 15:11:17,203 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,203 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,203 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,203 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,203 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,204 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_7/ExpandDims_1187612888
[ 2019-08-21 15:11:17,204 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,204 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,205 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,205 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,205 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,205 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,205 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,205 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_6/shape
[ 2019-08-21 15:11:17,206 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,206 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,206 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,206 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,206 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,206 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_6/begin
[ 2019-08-21 15:11:17,207 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 6]
[ 2019-08-21 15:11:17,207 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,207 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_6/1
[ 2019-08-21 15:11:17,207 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,207 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,207 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,207 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,207 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_6/ExpandDims_1213113272
[ 2019-08-21 15:11:17,207 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,208 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,208 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,208 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,208 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,208 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,209 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,209 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_5/shape
[ 2019-08-21 15:11:17,209 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,209 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,209 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,209 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,209 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_5/begin
[ 2019-08-21 15:11:17,210 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,210 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 5]
[ 2019-08-21 15:11:17,210 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,210 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_5/1
[ 2019-08-21 15:11:17,210 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,210 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,210 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,210 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_5/ExpandDims_1188912908
[ 2019-08-21 15:11:17,211 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,214 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,214 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,215 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,215 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,215 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,215 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,215 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_4/shape
[ 2019-08-21 15:11:17,216 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,216 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,216 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,216 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,217 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,217 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_4/begin
[ 2019-08-21 15:11:17,217 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,217 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,217 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,217 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 4]
[ 2019-08-21 15:11:17,218 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,218 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_4/1
[ 2019-08-21 15:11:17,218 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,218 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,218 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,218 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,218 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_4/ExpandDims_1227613490
[ 2019-08-21 15:11:17,218 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,219 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,219 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,219 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,219 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,220 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,220 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,220 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_3/shape
[ 2019-08-21 15:11:17,220 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,220 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,220 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,220 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,221 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,221 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_3/begin
[ 2019-08-21 15:11:17,221 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,221 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,221 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,221 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 3]
[ 2019-08-21 15:11:17,221 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_3/1
[ 2019-08-21 15:11:17,222 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,225 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,225 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_3/ExpandDims_1175012698
[ 2019-08-21 15:11:17,225 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,226 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,226 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,226 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,226 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,226 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,227 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,227 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_2/shape
[ 2019-08-21 15:11:17,227 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,227 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,227 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,227 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,228 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,228 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_2/begin
[ 2019-08-21 15:11:17,228 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,228 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,228 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,228 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 2]
[ 2019-08-21 15:11:17,229 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_2/1
[ 2019-08-21 15:11:17,229 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,229 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,229 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,229 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,229 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,229 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_2/ExpandDims_1215813312
[ 2019-08-21 15:11:17,229 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,230 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,230 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,230 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,230 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,230 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,231 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,231 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape_1/shape
[ 2019-08-21 15:11:17,231 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,231 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,231 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,231 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,231 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice_1/begin
[ 2019-08-21 15:11:17,232 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,232 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,232 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,232 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 1]
[ 2019-08-21 15:11:17,232 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,232 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_1/1
[ 2019-08-21 15:11:17,233 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,236 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,236 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack_1/ExpandDims_1208813210
[ 2019-08-21 15:11:17,236 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,236 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,237 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,237 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,237 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,237 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,238 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,238 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape/shape
[ 2019-08-21 15:11:17,238 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,238 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,238 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,238 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,239 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,239 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice/begin
[ 2019-08-21 15:11:17,239 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,239 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,239 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,239 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 0]
[ 2019-08-21 15:11:17,240 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,240 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack/1
[ 2019-08-21 15:11:17,240 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,240 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,240 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,240 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,240 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack/ExpandDims_1194512992
[ 2019-08-21 15:11:17,240 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,241 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,241 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,241 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,242 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,242 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,242 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,242 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/Const
[ 2019-08-21 15:11:17,242 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,242 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,243 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,243 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,243 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/Enter
[ 2019-08-21 15:11:17,243 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:17,243 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,243 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,243 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,244 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/Merge
[ 2019-08-21 15:11:17,244 ] [ DEBUG ] [ infer:131 ]  Op: Merge
[ 2019-08-21 15:11:17,244 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,244 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,244 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = <UNKNOWN>, value = <UNKNOWN>
[ 2019-08-21 15:11:17,244 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,244 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:17,244 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,244 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_4/range/delta
[ 2019-08-21 15:11:17,244 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,245 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,248 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,248 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,248 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_4/range/start
[ 2019-08-21 15:11:17,248 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,248 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,249 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,249 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,249 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,249 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_4/strided_slice/stack_2
[ 2019-08-21 15:11:17,249 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,250 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,250 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,250 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,250 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,250 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_4/strided_slice/stack_1
[ 2019-08-21 15:11:17,250 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,251 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,251 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,251 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,251 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,251 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_4/strided_slice/stack
[ 2019-08-21 15:11:17,251 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,252 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,252 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,252 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,252 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/range/delta
[ 2019-08-21 15:11:17,252 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,252 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,253 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,253 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,253 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/range/start
[ 2019-08-21 15:11:17,253 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,253 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,253 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,253 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,253 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/strided_slice/stack_2
[ 2019-08-21 15:11:17,254 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,254 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,254 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,254 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,254 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/strided_slice/stack_1
[ 2019-08-21 15:11:17,254 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,255 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,255 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/strided_slice/stack
[ 2019-08-21 15:11:17,255 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,255 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,255 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,255 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,255 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/range/delta
[ 2019-08-21 15:11:17,256 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,256 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,256 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/range/start
[ 2019-08-21 15:11:17,256 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,256 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,256 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,256 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,256 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/strided_slice/stack_2
[ 2019-08-21 15:11:17,259 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,260 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,260 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/strided_slice/stack_1
[ 2019-08-21 15:11:17,260 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,260 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,260 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,260 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,261 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,261 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/strided_slice/stack
[ 2019-08-21 15:11:17,261 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,261 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,261 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,261 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,262 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,262 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/range/delta
[ 2019-08-21 15:11:17,262 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,262 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,262 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,262 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,262 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/range/start
[ 2019-08-21 15:11:17,263 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,263 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,263 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,263 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,263 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/strided_slice/stack_2
[ 2019-08-21 15:11:17,263 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,264 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,264 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,264 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/strided_slice/stack_1
[ 2019-08-21 15:11:17,264 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,264 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,264 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,265 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/strided_slice/stack
[ 2019-08-21 15:11:17,265 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,265 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,265 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,265 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,265 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,265 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/strided_slice/stack_2
[ 2019-08-21 15:11:17,266 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,266 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,266 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/strided_slice/stack_1
[ 2019-08-21 15:11:17,266 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,266 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,266 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,267 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,267 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,267 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/strided_slice/stack
[ 2019-08-21 15:11:17,267 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,267 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,267 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,268 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,271 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,271 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/strided_slice_2/stack_2
[ 2019-08-21 15:11:17,271 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,272 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,272 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,272 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [1 1]
[ 2019-08-21 15:11:17,273 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,273 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/strided_slice_2/stack_1
[ 2019-08-21 15:11:17,273 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,273 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,273 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,273 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 2]
[ 2019-08-21 15:11:17,274 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,274 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/strided_slice_2/stack
[ 2019-08-21 15:11:17,274 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,274 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,274 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,274 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 1]
[ 2019-08-21 15:11:17,275 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/strided_slice_1/stack_2
[ 2019-08-21 15:11:17,275 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,275 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,275 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,275 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [1 1]
[ 2019-08-21 15:11:17,275 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,275 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/strided_slice_1/stack_1
[ 2019-08-21 15:11:17,276 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,276 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 1]
[ 2019-08-21 15:11:17,276 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,276 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/strided_slice_1/stack
[ 2019-08-21 15:11:17,276 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,276 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,276 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 0]
[ 2019-08-21 15:11:17,277 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Reshape_6/shape
[ 2019-08-21 15:11:17,277 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,277 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,277 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,277 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [ -1 100  90]
[ 2019-08-21 15:11:17,277 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,277 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Slice_1/size
[ 2019-08-21 15:11:17,278 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [-1 -1 -1]
[ 2019-08-21 15:11:17,278 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,278 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Slice_1/begin
[ 2019-08-21 15:11:17,278 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,278 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,278 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,278 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [0 0 1]
[ 2019-08-21 15:11:17,278 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/concat/axis
[ 2019-08-21 15:11:17,279 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,279 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,279 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,279 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,279 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/concat/values_0
[ 2019-08-21 15:11:17,279 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,279 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,283 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Slice/size
[ 2019-08-21 15:11:17,283 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,283 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,283 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,283 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,284 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,284 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/scale_logits/y
[ 2019-08-21 15:11:17,284 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,284 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,284 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,284 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1.0
[ 2019-08-21 15:11:17,285 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/scale_logits/reciprocal_
[ 2019-08-21 15:11:17,285 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,285 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,285 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1.0
[ 2019-08-21 15:11:17,285 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,285 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,285 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1.0
[ 2019-08-21 15:11:17,286 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,286 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/stack/3
[ 2019-08-21 15:11:17,286 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,286 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,286 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,286 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 4
[ 2019-08-21 15:11:17,286 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/stack/ExpandDims_1226013466
[ 2019-08-21 15:11:17,286 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,287 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,287 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 4
[ 2019-08-21 15:11:17,287 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,287 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,288 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [4]
[ 2019-08-21 15:11:17,288 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,288 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/stack/2
[ 2019-08-21 15:11:17,288 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,288 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,288 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,288 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 90
[ 2019-08-21 15:11:17,288 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/stack/ExpandDims_1225913464
[ 2019-08-21 15:11:17,288 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,289 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,289 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 90
[ 2019-08-21 15:11:17,289 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,289 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,289 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [90]
[ 2019-08-21 15:11:17,290 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,290 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/stack/1
[ 2019-08-21 15:11:17,290 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,290 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,290 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,290 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 100
[ 2019-08-21 15:11:17,290 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/stack/ExpandDims_1225813462
[ 2019-08-21 15:11:17,290 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,291 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,294 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 100
[ 2019-08-21 15:11:17,294 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,294 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,294 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [100]
[ 2019-08-21 15:11:17,295 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,295 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_7/y
[ 2019-08-21 15:11:17,295 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,295 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,295 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,295 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,295 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_7/reciprocal_
[ 2019-08-21 15:11:17,295 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,296 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,296 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,296 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,296 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,296 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,296 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,296 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_6/y
[ 2019-08-21 15:11:17,296 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,297 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,297 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,297 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_6/reciprocal_
[ 2019-08-21 15:11:17,297 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,297 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,297 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,297 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,297 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,297 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,297 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_5/y
[ 2019-08-21 15:11:17,298 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,298 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,298 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,298 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,298 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,298 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_5/reciprocal_
[ 2019-08-21 15:11:17,298 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,298 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,298 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,299 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,299 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,299 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,299 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_4/y
[ 2019-08-21 15:11:17,299 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,299 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,300 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,300 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,300 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_4/reciprocal_
[ 2019-08-21 15:11:17,300 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,300 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,301 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,301 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,301 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,301 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,301 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,301 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_3/y
[ 2019-08-21 15:11:17,301 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,301 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,301 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 5.0
[ 2019-08-21 15:11:17,302 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,302 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_3/reciprocal_
[ 2019-08-21 15:11:17,302 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,302 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,302 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 5.0
[ 2019-08-21 15:11:17,302 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,302 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,302 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.2
[ 2019-08-21 15:11:17,302 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_2/y
[ 2019-08-21 15:11:17,302 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,303 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,305 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,306 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 5.0
[ 2019-08-21 15:11:17,306 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,306 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_2/reciprocal_
[ 2019-08-21 15:11:17,306 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,306 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,306 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 5.0
[ 2019-08-21 15:11:17,307 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,307 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,307 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.2
[ 2019-08-21 15:11:17,307 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,307 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_1/y
[ 2019-08-21 15:11:17,307 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,308 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,308 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,308 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 10.0
[ 2019-08-21 15:11:17,308 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,308 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div_1/reciprocal_
[ 2019-08-21 15:11:17,308 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,308 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 10.0
[ 2019-08-21 15:11:17,309 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,309 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,309 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.1
[ 2019-08-21 15:11:17,309 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,309 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div/y
[ 2019-08-21 15:11:17,309 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,309 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,309 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 10.0
[ 2019-08-21 15:11:17,309 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/div/reciprocal_
[ 2019-08-21 15:11:17,310 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,310 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,310 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 10.0
[ 2019-08-21 15:11:17,310 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,310 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,310 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.1
[ 2019-08-21 15:11:17,310 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,310 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/get_center_coordinates_and_sizes/div_1/y
[ 2019-08-21 15:11:17,310 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,311 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,311 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,311 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,311 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,311 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/get_center_coordinates_and_sizes/div_1/reciprocal_
[ 2019-08-21 15:11:17,311 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,311 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,311 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,312 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,312 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,312 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/get_center_coordinates_and_sizes/div/y
[ 2019-08-21 15:11:17,312 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,312 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,312 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,312 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,312 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Decode/get_center_coordinates_and_sizes/div/reciprocal_
[ 2019-08-21 15:11:17,312 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,313 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,313 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,313 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,313 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,313 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,313 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Reshape_3/shape
[ 2019-08-21 15:11:17,313 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,313 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,313 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [-1  4]
[ 2019-08-21 15:11:17,317 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,317 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Reshape_2/shape
[ 2019-08-21 15:11:17,318 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,318 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,318 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,318 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [-1  4]
[ 2019-08-21 15:11:17,318 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,318 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Tile/multiples
[ 2019-08-21 15:11:17,319 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,319 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,319 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [4], value = [ 1  1 90  1]
[ 2019-08-21 15:11:17,319 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,319 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/ExpandDims/dim
[ 2019-08-21 15:11:17,319 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,320 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,320 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,320 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2
[ 2019-08-21 15:11:17,320 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,320 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/strided_slice/stack_2
[ 2019-08-21 15:11:17,320 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,321 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,321 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,321 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/strided_slice/stack_1
[ 2019-08-21 15:11:17,321 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,321 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,321 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,322 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,322 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/strided_slice/stack
[ 2019-08-21 15:11:17,322 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,322 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,322 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,322 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,322 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Reshape_1/shape
[ 2019-08-21 15:11:17,323 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,323 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,323 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,323 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [ -1 100  91]
[ 2019-08-21 15:11:17,323 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,323 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Reshape/shape
[ 2019-08-21 15:11:17,324 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [4], value = [ -1 100  90   4]
[ 2019-08-21 15:11:17,324 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,324 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/TensorArrayStack/range/delta
[ 2019-08-21 15:11:17,324 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,324 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,324 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,324 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,324 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/TensorArrayStack/range/start
[ 2019-08-21 15:11:17,325 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,325 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,325 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,325 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,325 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/Const
[ 2019-08-21 15:11:17,325 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,326 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,329 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/while/Enter
[ 2019-08-21 15:11:17,329 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:17,329 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,329 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,329 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,329 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,330 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,330 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/while/Merge
[ 2019-08-21 15:11:17,330 ] [ DEBUG ] [ infer:131 ]  Op: Merge
[ 2019-08-21 15:11:17,330 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,330 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,330 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = <UNKNOWN>, value = <UNKNOWN>
[ 2019-08-21 15:11:17,330 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,330 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:17,331 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,331 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/TensorArrayUnstack/range/delta
[ 2019-08-21 15:11:17,331 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,331 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,331 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,332 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,332 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,332 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/TensorArrayUnstack/range/start
[ 2019-08-21 15:11:17,332 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,332 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,332 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,332 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,333 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,333 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/TensorArrayUnstack/strided_slice/stack_2
[ 2019-08-21 15:11:17,333 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,333 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,333 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,333 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,334 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/TensorArrayUnstack/strided_slice/stack_1
[ 2019-08-21 15:11:17,334 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,334 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,334 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,334 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,334 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,335 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,335 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,335 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/strided_slice/stack_2
[ 2019-08-21 15:11:17,335 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,335 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,335 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,335 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,335 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/strided_slice/stack_1
[ 2019-08-21 15:11:17,336 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,336 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,336 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,336 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,336 ] [ DEBUG ] [ infer:130 ]  Partial infer for map_1/strided_slice/stack
[ 2019-08-21 15:11:17,336 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,336 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,337 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,339 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageBoxPredictor/Reshape_1/shape
[ 2019-08-21 15:11:17,339 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,340 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,340 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,340 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [-1  1 91]
[ 2019-08-21 15:11:17,340 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,340 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageBoxPredictor/Reshape/shape
[ 2019-08-21 15:11:17,340 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,341 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [4], value = [-1  1 90  4]
[ 2019-08-21 15:11:17,341 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,341 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageBoxPredictor/AvgPool/reduction_indices
[ 2019-08-21 15:11:17,341 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,341 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,341 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,342 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [1 2]
[ 2019-08-21 15:11:17,342 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,342 ] [ DEBUG ] [ infer:130 ]  Partial infer for CropAndResize/crop_size
[ 2019-08-21 15:11:17,342 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,342 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,343 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,343 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [14 14]
[ 2019-08-21 15:11:17,343 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,343 ] [ DEBUG ] [ infer:130 ]  Partial infer for Reshape_6/shape
[ 2019-08-21 15:11:17,343 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,343 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,344 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,344 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,344 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,344 ] [ DEBUG ] [ infer:130 ]  Partial infer for ExpandDims_6/dim
[ 2019-08-21 15:11:17,344 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,344 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,344 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,345 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,345 ] [ DEBUG ] [ infer:130 ]  Partial infer for range/delta
[ 2019-08-21 15:11:17,345 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,345 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,345 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,345 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,345 ] [ DEBUG ] [ infer:130 ]  Partial infer for range/start
[ 2019-08-21 15:11:17,346 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,346 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,346 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_15/stack_2
[ 2019-08-21 15:11:17,346 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,346 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,346 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,346 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,346 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_15/stack_1
[ 2019-08-21 15:11:17,347 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,347 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,347 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,347 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,347 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_15/stack
[ 2019-08-21 15:11:17,347 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,347 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,348 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,351 ] [ DEBUG ] [ infer:130 ]  Partial infer for ones/Const
[ 2019-08-21 15:11:17,351 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,351 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,351 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,351 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,352 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,352 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_14/stack_2
[ 2019-08-21 15:11:17,352 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,352 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,352 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,353 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,353 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,353 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_14/stack_1
[ 2019-08-21 15:11:17,353 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,353 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,353 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,353 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:17,354 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,354 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_14/stack
[ 2019-08-21 15:11:17,354 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,354 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,354 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,354 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,354 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack_3/1
[ 2019-08-21 15:11:17,355 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,355 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,355 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 4
[ 2019-08-21 15:11:17,355 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,355 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack_3/ExpandDims_1154412394
[ 2019-08-21 15:11:17,355 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,356 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,356 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 4
[ 2019-08-21 15:11:17,356 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,357 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,357 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [4]
[ 2019-08-21 15:11:17,357 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,357 ] [ DEBUG ] [ infer:130 ]  Partial infer for mul/y
[ 2019-08-21 15:11:17,357 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,357 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,358 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,358 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 100
[ 2019-08-21 15:11:17,358 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,358 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_13/stack_2
[ 2019-08-21 15:11:17,358 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,358 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,359 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,359 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,359 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_13/stack_1
[ 2019-08-21 15:11:17,359 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,359 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,359 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,360 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_13/stack
[ 2019-08-21 15:11:17,363 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,363 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,363 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,363 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,363 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,363 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayStack/range/delta
[ 2019-08-21 15:11:17,364 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,364 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,364 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,364 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,364 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,364 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayStack/range/start
[ 2019-08-21 15:11:17,365 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,365 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,365 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,365 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,365 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,365 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/Const
[ 2019-08-21 15:11:17,366 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,366 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,366 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,366 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,366 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,366 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/while/Enter
[ 2019-08-21 15:11:17,366 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:17,367 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,367 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,367 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,367 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,367 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,367 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/while/Merge
[ 2019-08-21 15:11:17,367 ] [ DEBUG ] [ infer:131 ]  Op: Merge
[ 2019-08-21 15:11:17,368 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,368 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = <UNKNOWN>, value = <UNKNOWN>
[ 2019-08-21 15:11:17,368 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,368 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:17,368 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,368 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayUnstack_1/range/delta
[ 2019-08-21 15:11:17,368 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,368 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,369 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,369 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,369 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,369 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayUnstack_1/range/start
[ 2019-08-21 15:11:17,369 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,369 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,369 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,369 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayUnstack_1/strided_slice/stack_2
[ 2019-08-21 15:11:17,370 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,370 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,370 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,370 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,370 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayUnstack_1/strided_slice/stack_1
[ 2019-08-21 15:11:17,370 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,371 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,371 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayUnstack_1/strided_slice/stack
[ 2019-08-21 15:11:17,371 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,371 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,371 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,371 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,371 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayUnstack/range/delta
[ 2019-08-21 15:11:17,372 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,374 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,375 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayUnstack/range/start
[ 2019-08-21 15:11:17,375 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,375 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,375 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,375 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,375 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,375 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayUnstack/strided_slice/stack_2
[ 2019-08-21 15:11:17,376 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,376 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,376 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,376 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,376 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,377 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayUnstack/strided_slice/stack_1
[ 2019-08-21 15:11:17,377 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,377 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,377 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,377 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,377 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,378 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/TensorArrayUnstack/strided_slice/stack
[ 2019-08-21 15:11:17,378 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,378 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,378 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,378 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,378 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,379 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/strided_slice/stack_2
[ 2019-08-21 15:11:17,379 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,379 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,379 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,379 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,379 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,379 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/strided_slice/stack_1
[ 2019-08-21 15:11:17,380 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,380 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,380 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,380 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,380 ] [ DEBUG ] [ infer:130 ]  Partial infer for map/strided_slice/stack
[ 2019-08-21 15:11:17,380 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,381 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,381 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,381 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayStack_4/range/delta
[ 2019-08-21 15:11:17,381 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,381 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,381 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,381 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,381 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayStack_4/range/start
[ 2019-08-21 15:11:17,382 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,382 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,382 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,382 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,382 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayStack/range/delta
[ 2019-08-21 15:11:17,382 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,382 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,383 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,386 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayStack/range/start
[ 2019-08-21 15:11:17,386 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,386 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,386 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,387 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,387 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,387 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Reshape/shape
[ 2019-08-21 15:11:17,387 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,387 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,387 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,388 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,388 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,388 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Slice/begin
[ 2019-08-21 15:11:17,388 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,388 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,388 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,389 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 0]
[ 2019-08-21 15:11:17,389 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,389 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack/1
[ 2019-08-21 15:11:17,389 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,389 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,389 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,389 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,390 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/stack/ExpandDims_1220913388
[ 2019-08-21 15:11:17,390 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,390 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,390 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,391 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,391 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,391 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,391 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,391 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/Const
[ 2019-08-21 15:11:17,391 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,391 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,392 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,392 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,392 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,392 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/while/Enter
[ 2019-08-21 15:11:17,392 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:17,392 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,392 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,393 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,393 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/while/Merge
[ 2019-08-21 15:11:17,393 ] [ DEBUG ] [ infer:131 ]  Op: Merge
[ 2019-08-21 15:11:17,393 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,393 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,393 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = <UNKNOWN>, value = <UNKNOWN>
[ 2019-08-21 15:11:17,393 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,393 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:17,394 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_4/range/delta
[ 2019-08-21 15:11:17,394 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,394 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,394 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,394 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,394 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,394 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_4/range/start
[ 2019-08-21 15:11:17,394 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,395 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,398 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_4/strided_slice/stack_2
[ 2019-08-21 15:11:17,398 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,398 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,398 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,399 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,399 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,399 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_4/strided_slice/stack_1
[ 2019-08-21 15:11:17,399 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,399 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,400 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,400 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,400 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,400 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_4/strided_slice/stack
[ 2019-08-21 15:11:17,400 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,400 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,401 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,401 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,401 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/range/delta
[ 2019-08-21 15:11:17,401 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,401 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,401 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,401 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,401 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/range/start
[ 2019-08-21 15:11:17,402 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,402 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,402 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,402 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,402 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,402 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/strided_slice/stack_2
[ 2019-08-21 15:11:17,402 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,403 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,403 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_3/strided_slice/stack_1
[ 2019-08-21 15:11:17,403 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,403 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,403 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,403 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,404 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,404 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,404 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,404 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/range/delta
[ 2019-08-21 15:11:17,404 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,404 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,404 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,404 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/range/start
[ 2019-08-21 15:11:17,405 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,405 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,405 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,405 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,405 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/strided_slice/stack_2
[ 2019-08-21 15:11:17,405 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,406 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,406 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,406 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,406 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,406 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/strided_slice/stack_1
[ 2019-08-21 15:11:17,407 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,410 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,410 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,410 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,410 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,410 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack_1/strided_slice/stack
[ 2019-08-21 15:11:17,410 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,411 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,411 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,411 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,411 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,411 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/range/delta
[ 2019-08-21 15:11:17,411 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,412 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,412 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,412 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,412 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/range/start
[ 2019-08-21 15:11:17,412 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,412 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,412 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,413 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/strided_slice/stack_2
[ 2019-08-21 15:11:17,413 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,413 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,413 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,413 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,413 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,413 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/strided_slice/stack_1
[ 2019-08-21 15:11:17,414 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,414 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,414 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/TensorArrayUnstack/strided_slice/stack
[ 2019-08-21 15:11:17,414 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,414 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,414 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,414 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,414 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/strided_slice/stack_2
[ 2019-08-21 15:11:17,415 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,415 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,415 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,415 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,415 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/strided_slice/stack_1
[ 2019-08-21 15:11:17,415 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,416 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,416 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/map/strided_slice/stack
[ 2019-08-21 15:11:17,416 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,416 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,416 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,416 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,417 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/ones/Const
[ 2019-08-21 15:11:17,417 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,417 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,417 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,417 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,417 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,417 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/strided_slice_1/stack_2
[ 2019-08-21 15:11:17,420 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,420 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,421 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,421 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,421 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,421 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/strided_slice_1/stack_1
[ 2019-08-21 15:11:17,421 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,421 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,421 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:17,422 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,422 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/strided_slice_1/stack
[ 2019-08-21 15:11:17,422 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,422 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,422 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,422 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,423 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,423 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/strided_slice/stack_2
[ 2019-08-21 15:11:17,423 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,423 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,423 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,423 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,424 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,424 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/strided_slice/stack_1
[ 2019-08-21 15:11:17,424 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,424 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,424 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,424 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,425 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,425 ] [ DEBUG ] [ infer:130 ]  Partial infer for BatchMultiClassNonMaxSuppression/strided_slice/stack
[ 2019-08-21 15:11:17,425 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,425 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,425 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,425 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,425 ] [ DEBUG ] [ infer:130 ]  Partial infer for ExpandDims_5/dim
[ 2019-08-21 15:11:17,426 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,426 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,426 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2
[ 2019-08-21 15:11:17,426 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,426 ] [ DEBUG ] [ infer:130 ]  Partial infer for ExpandDims_4/dim
[ 2019-08-21 15:11:17,426 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,426 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_12/stack_2
[ 2019-08-21 15:11:17,427 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,427 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,427 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [1 1]
[ 2019-08-21 15:11:17,427 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,427 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_12/stack_1
[ 2019-08-21 15:11:17,427 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,428 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 2]
[ 2019-08-21 15:11:17,428 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,428 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_12/stack
[ 2019-08-21 15:11:17,428 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,428 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,428 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,428 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 1]
[ 2019-08-21 15:11:17,428 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_11/stack_2
[ 2019-08-21 15:11:17,431 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,431 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,432 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,432 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [1 1]
[ 2019-08-21 15:11:17,432 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,432 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_11/stack_1
[ 2019-08-21 15:11:17,432 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,433 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,433 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,433 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 1]
[ 2019-08-21 15:11:17,433 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,433 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_11/stack
[ 2019-08-21 15:11:17,434 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,434 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,434 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,434 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [0 0]
[ 2019-08-21 15:11:17,434 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,434 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_10/stack_2
[ 2019-08-21 15:11:17,435 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [1 1 1]
[ 2019-08-21 15:11:17,435 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,435 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_10/stack_1
[ 2019-08-21 15:11:17,435 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,435 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,435 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,435 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [0 0 2]
[ 2019-08-21 15:11:17,436 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,436 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,436 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,436 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [0 0 1]
[ 2019-08-21 15:11:17,436 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,436 ] [ DEBUG ] [ infer:130 ]  Partial infer for concat/axis
[ 2019-08-21 15:11:17,436 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,437 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,437 ] [ DEBUG ] [ infer:130 ]  Partial infer for concat/values_0
[ 2019-08-21 15:11:17,437 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,437 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,437 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,437 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,437 ] [ DEBUG ] [ infer:130 ]  Partial infer for Slice/size
[ 2019-08-21 15:11:17,438 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,438 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,438 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,438 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack_1/3
[ 2019-08-21 15:11:17,438 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,438 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,438 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 4
[ 2019-08-21 15:11:17,438 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack_1/ExpandDims_1172412662
[ 2019-08-21 15:11:17,438 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,439 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,439 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 4
[ 2019-08-21 15:11:17,440 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,442 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,443 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [4]
[ 2019-08-21 15:11:17,443 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,443 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack_1/2
[ 2019-08-21 15:11:17,443 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,443 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,443 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,443 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,444 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,444 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack_1/ExpandDims_1172312660
[ 2019-08-21 15:11:17,444 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,445 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,445 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,445 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,445 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,445 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,446 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,446 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_7/y
[ 2019-08-21 15:11:17,446 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,446 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,446 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,446 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,447 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,447 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_7/reciprocal_
[ 2019-08-21 15:11:17,447 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,447 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,447 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,448 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,448 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,448 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,448 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,448 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_6/y
[ 2019-08-21 15:11:17,448 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,448 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,448 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,449 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,449 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_6/reciprocal_
[ 2019-08-21 15:11:17,449 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,449 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,449 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,449 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,449 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,450 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,450 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,450 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_5/y
[ 2019-08-21 15:11:17,450 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,450 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,450 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,450 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,451 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,453 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_5/reciprocal_
[ 2019-08-21 15:11:17,454 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,454 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,454 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,454 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,454 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,454 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,455 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,455 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_4/y
[ 2019-08-21 15:11:17,455 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,455 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,455 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,456 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,456 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,456 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_4/reciprocal_
[ 2019-08-21 15:11:17,456 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,456 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,456 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,456 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,457 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,457 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,457 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,457 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_3/y
[ 2019-08-21 15:11:17,457 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,457 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,457 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 5.0
[ 2019-08-21 15:11:17,458 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,458 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_3/reciprocal_
[ 2019-08-21 15:11:17,458 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,458 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,458 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 5.0
[ 2019-08-21 15:11:17,458 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,458 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,458 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.2
[ 2019-08-21 15:11:17,458 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_2/y
[ 2019-08-21 15:11:17,459 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,459 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,459 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,459 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 5.0
[ 2019-08-21 15:11:17,459 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,459 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_2/reciprocal_
[ 2019-08-21 15:11:17,459 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,459 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 5.0
[ 2019-08-21 15:11:17,459 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,460 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.2
[ 2019-08-21 15:11:17,460 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,460 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_1/y
[ 2019-08-21 15:11:17,460 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,460 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,460 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,460 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 10.0
[ 2019-08-21 15:11:17,460 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div_1/reciprocal_
[ 2019-08-21 15:11:17,460 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,461 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,461 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 10.0
[ 2019-08-21 15:11:17,461 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,461 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,461 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.1
[ 2019-08-21 15:11:17,461 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,461 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div/y
[ 2019-08-21 15:11:17,461 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,461 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 10.0
[ 2019-08-21 15:11:17,462 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,465 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/div/reciprocal_
[ 2019-08-21 15:11:17,465 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,465 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,465 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 10.0
[ 2019-08-21 15:11:17,466 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,466 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,466 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.1
[ 2019-08-21 15:11:17,466 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,466 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/get_center_coordinates_and_sizes/div_1/y
[ 2019-08-21 15:11:17,466 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,467 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,467 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,467 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,467 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,467 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/get_center_coordinates_and_sizes/div_1/reciprocal_
[ 2019-08-21 15:11:17,467 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,468 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,468 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,468 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,468 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,468 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,468 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,468 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/get_center_coordinates_and_sizes/div/y
[ 2019-08-21 15:11:17,468 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,469 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,469 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,469 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,469 ] [ DEBUG ] [ infer:130 ]  Partial infer for Decode/get_center_coordinates_and_sizes/div/reciprocal_
[ 2019-08-21 15:11:17,469 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:17,469 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,469 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2.0
[ 2019-08-21 15:11:17,469 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:17,469 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,470 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,470 ] [ DEBUG ] [ infer:130 ]  Partial infer for Reshape_1/shape
[ 2019-08-21 15:11:17,470 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,470 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,470 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,470 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [-1  4]
[ 2019-08-21 15:11:17,470 ] [ DEBUG ] [ infer:130 ]  Partial infer for Reshape/shape
[ 2019-08-21 15:11:17,471 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,471 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,471 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,471 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [-1  4]
[ 2019-08-21 15:11:17,471 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,471 ] [ DEBUG ] [ infer:130 ]  Partial infer for Tile_2/multiples
[ 2019-08-21 15:11:17,471 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [4], value = [1 1 1 1]
[ 2019-08-21 15:11:17,472 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,472 ] [ DEBUG ] [ infer:130 ]  Partial infer for ExpandDims_3/dim
[ 2019-08-21 15:11:17,472 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,472 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,472 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,472 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2
[ 2019-08-21 15:11:17,472 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_9/stack_2
[ 2019-08-21 15:11:17,473 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,473 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,473 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_9/stack_1
[ 2019-08-21 15:11:17,473 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,473 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,473 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,473 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:17,474 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,476 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,477 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,477 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,477 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_8/stack_2
[ 2019-08-21 15:11:17,477 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,477 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,477 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,477 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_8/stack_1
[ 2019-08-21 15:11:17,478 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,478 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,478 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,478 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,478 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,478 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_8/stack
[ 2019-08-21 15:11:17,479 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,479 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,479 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,479 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,479 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,479 ] [ DEBUG ] [ infer:130 ]  Partial infer for Tile_1/multiples/2
[ 2019-08-21 15:11:17,480 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,480 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,480 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,480 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,480 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,480 ] [ DEBUG ] [ infer:130 ]  Partial infer for Tile_1/multiples/ExpandDims_1209713224
[ 2019-08-21 15:11:17,480 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,481 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,481 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,481 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,481 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,482 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,482 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,482 ] [ DEBUG ] [ infer:130 ]  Partial infer for Tile_1/multiples/1
[ 2019-08-21 15:11:17,482 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,482 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,482 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,482 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,482 ] [ DEBUG ] [ infer:130 ]  Partial infer for Tile_1/multiples/ExpandDims_1209613222
[ 2019-08-21 15:11:17,482 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,483 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,483 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,483 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,484 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,484 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,484 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,484 ] [ DEBUG ] [ infer:130 ]  Partial infer for ExpandDims_2/dim
[ 2019-08-21 15:11:17,484 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,484 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,484 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,484 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_6/stack_2
[ 2019-08-21 15:11:17,485 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,488 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,488 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,488 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,488 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,488 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_6/stack_1
[ 2019-08-21 15:11:17,488 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,489 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,489 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,489 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_6/stack
[ 2019-08-21 15:11:17,489 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,489 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,489 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,490 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,490 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,490 ] [ DEBUG ] [ infer:130 ]  Partial infer for ExpandDims_1/dim
[ 2019-08-21 15:11:17,490 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,490 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,490 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,491 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2
[ 2019-08-21 15:11:17,491 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,491 ] [ DEBUG ] [ infer:130 ]  Partial infer for Tile/multiples/1
[ 2019-08-21 15:11:17,491 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,491 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,491 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,491 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,492 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,492 ] [ DEBUG ] [ infer:130 ]  Partial infer for Tile/multiples/ExpandDims_1181012788
[ 2019-08-21 15:11:17,492 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,492 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,492 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,493 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,493 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,493 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,493 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,493 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_5/stack_2
[ 2019-08-21 15:11:17,493 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,493 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,494 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,494 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_5/stack_1
[ 2019-08-21 15:11:17,494 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,494 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,494 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,494 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,495 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,495 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,495 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,495 ] [ DEBUG ] [ infer:130 ]  Partial infer for ExpandDims/dim
[ 2019-08-21 15:11:17,495 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,495 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,495 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,496 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_4/stack_2
[ 2019-08-21 15:11:17,496 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,496 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,496 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,496 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,496 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,496 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_4/stack_1
[ 2019-08-21 15:11:17,497 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,499 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,500 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,500 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,500 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_4/stack
[ 2019-08-21 15:11:17,500 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,500 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,501 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,501 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,501 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,501 ] [ DEBUG ] [ infer:130 ]  Partial infer for ClipToWindow/Reshape/shape
[ 2019-08-21 15:11:17,501 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,501 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,502 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,502 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,502 ] [ DEBUG ] [ infer:130 ]  Partial infer for ClipToWindow/Greater/y
[ 2019-08-21 15:11:17,502 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,502 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,502 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,502 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.0
[ 2019-08-21 15:11:17,502 ] [ DEBUG ] [ infer:130 ]  Partial infer for ClipToWindow/Area/split/split_dim
[ 2019-08-21 15:11:17,503 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,503 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,503 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,503 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,503 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,503 ] [ DEBUG ] [ infer:130 ]  Partial infer for ClipToWindow/concat/axis
[ 2019-08-21 15:11:17,504 ] [ DEBUG ] [ infer:130 ]  Partial infer for ClipToWindow/split/split_dim
[ 2019-08-21 15:11:17,504 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,504 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,504 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,504 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,504 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,504 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack/1
[ 2019-08-21 15:11:17,504 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,505 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,505 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack/ExpandDims_1225313454
[ 2019-08-21 15:11:17,505 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,505 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,505 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,506 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,506 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,506 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,506 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,506 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack/0
[ 2019-08-21 15:11:17,506 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,506 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,506 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,507 ] [ DEBUG ] [ infer:130 ]  Partial infer for stack/ExpandDims_13452
[ 2019-08-21 15:11:17,507 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,507 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,507 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,511 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,511 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,511 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,511 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,511 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_3/stack_2
[ 2019-08-21 15:11:17,511 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,512 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,512 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,512 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,512 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,512 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_3/stack_1
[ 2019-08-21 15:11:17,512 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,513 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,513 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,513 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [3]
[ 2019-08-21 15:11:17,513 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,513 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_3/stack
[ 2019-08-21 15:11:17,513 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,514 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,514 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:17,514 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,514 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_2/stack_2
[ 2019-08-21 15:11:17,514 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,514 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,514 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,515 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_2/stack_1
[ 2019-08-21 15:11:17,515 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,515 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,515 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,515 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:17,515 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,516 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,516 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,516 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/stack_1/2
[ 2019-08-21 15:11:17,516 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,516 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,516 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,516 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 2
[ 2019-08-21 15:11:17,517 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/stack_1/ExpandDims_1177012728
[ 2019-08-21 15:11:17,517 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,517 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,517 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 2
[ 2019-08-21 15:11:17,518 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,518 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,518 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:17,518 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,518 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/mul_3/y
[ 2019-08-21 15:11:17,518 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,518 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,519 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 12
[ 2019-08-21 15:11:17,521 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,521 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/stack/3
[ 2019-08-21 15:11:17,521 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,522 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,522 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,522 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 4
[ 2019-08-21 15:11:17,522 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,522 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/stack/ExpandDims_1167412588
[ 2019-08-21 15:11:17,522 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,523 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,523 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 4
[ 2019-08-21 15:11:17,523 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,523 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,524 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [4]
[ 2019-08-21 15:11:17,524 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,524 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/stack/2
[ 2019-08-21 15:11:17,524 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,524 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,524 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,525 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,525 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,525 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/stack/ExpandDims_1167312586
[ 2019-08-21 15:11:17,525 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:17,526 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,526 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,526 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,526 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,526 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,526 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,526 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/mul_1/y
[ 2019-08-21 15:11:17,527 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,527 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,527 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,527 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 12
[ 2019-08-21 15:11:17,527 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,527 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/strided_slice_2/stack_2
[ 2019-08-21 15:11:17,528 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,528 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,528 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/strided_slice_2/stack_1
[ 2019-08-21 15:11:17,528 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,528 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,528 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,528 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [3]
[ 2019-08-21 15:11:17,529 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,529 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,529 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:17,529 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,529 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/strided_slice_1/stack_2
[ 2019-08-21 15:11:17,529 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,529 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,533 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/strided_slice_1/stack_1
[ 2019-08-21 15:11:17,533 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,533 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,533 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,533 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:17,533 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,534 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,534 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,534 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,534 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/strided_slice/stack_2
[ 2019-08-21 15:11:17,534 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,535 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,535 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,535 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,535 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,535 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/strided_slice/stack_1
[ 2019-08-21 15:11:17,535 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,536 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,536 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,536 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,536 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,536 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/strided_slice/stack
[ 2019-08-21 15:11:17,536 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,538 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,538 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,538 ] [ DEBUG ] [ infer:130 ]  Partial infer for Conv/weights
[ 2019-08-21 15:11:17,538 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,538 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,538 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,539 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   3    3 1024  512], value = [[[[ 2.99645518e-03  1.42790871e-02 -9.73897986e-04 ...  5.27989957e-03
     1.17567473e-03 -5.48...
[ 2019-08-21 15:11:17,540 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,540 ] [ DEBUG ] [ infer:130 ]  Partial infer for Conv/weights/read
[ 2019-08-21 15:11:17,540 ] [ DEBUG ] [ infer:131 ]  Op: Identity
[ 2019-08-21 15:11:17,540 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,543 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [   3    3 1024  512], value = [[[[ 2.99645518e-03  1.42790871e-02 -9.73897986e-04 ...  5.27989957e-03
[ 2019-08-21 15:11:17,544 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,546 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   3    3 1024  512], value = [[[[ 2.99645518e-03  1.42790871e-02 -9.73897986e-04 ...  5.27989957e-03
[ 2019-08-21 15:11:17,546 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,546 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/concat/axis
[ 2019-08-21 15:11:17,546 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,547 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,547 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,547 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,547 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,547 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/mul_6/x
[ 2019-08-21 15:11:17,547 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,548 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,548 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,548 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,548 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,548 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/mul_5/x
[ 2019-08-21 15:11:17,548 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,549 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,549 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,549 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.5
[ 2019-08-21 15:11:17,549 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,549 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Reshape_3/shape
[ 2019-08-21 15:11:17,549 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,550 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,550 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2], value = [-1  2]
[ 2019-08-21 15:11:17,550 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,550 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Reshape_2/shape
[ 2019-08-21 15:11:17,550 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,550 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,551 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,551 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_3/ExpandedShape_1/concat/axis
[ 2019-08-21 15:11:17,551 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,551 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,551 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,551 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,551 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_3/ExpandedShape_1/Slice_1/size
[ 2019-08-21 15:11:17,552 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,552 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,552 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_3/ExpandedShape_1/Slice/begin
[ 2019-08-21 15:11:17,552 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,552 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,552 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,552 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,552 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_2/ExpandedShape_1/concat/axis
[ 2019-08-21 15:11:17,553 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,555 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,556 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,556 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,556 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_2/ExpandedShape_1/Slice_1/size
[ 2019-08-21 15:11:17,556 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,556 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,556 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,557 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,557 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,557 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_2/ExpandedShape_1/Slice/begin
[ 2019-08-21 15:11:17,557 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,557 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,557 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,558 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,558 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,558 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_1/ExpandedShape_1/concat/axis
[ 2019-08-21 15:11:17,558 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,558 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,558 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,558 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,558 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_1/ExpandedShape_1/Slice_1/size
[ 2019-08-21 15:11:17,559 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,559 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,559 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,559 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,559 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_1/ExpandedShape_1/Slice/begin
[ 2019-08-21 15:11:17,559 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,559 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,560 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_1/ExpandedShape/concat/axis
[ 2019-08-21 15:11:17,560 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,560 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,560 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,560 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,560 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,560 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_1/ExpandedShape/Slice_1/size
[ 2019-08-21 15:11:17,561 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:17,561 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,561 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_1/ExpandedShape/Slice/begin
[ 2019-08-21 15:11:17,561 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,561 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,561 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,561 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,561 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/range_1/delta
[ 2019-08-21 15:11:17,562 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,562 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,562 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,562 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,562 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,562 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/range_1/start
[ 2019-08-21 15:11:17,562 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,563 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/range/delta
[ 2019-08-21 15:11:17,563 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,563 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,563 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,563 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,563 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,563 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/range/start
[ 2019-08-21 15:11:17,563 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,564 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,567 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_1/stack_2
[ 2019-08-21 15:11:17,567 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,567 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,567 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,568 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,568 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,568 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_1/stack_1
[ 2019-08-21 15:11:17,568 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,568 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,568 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,569 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [3]
[ 2019-08-21 15:11:17,569 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,569 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice_1/stack
[ 2019-08-21 15:11:17,569 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,569 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,569 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,569 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:17,570 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,570 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice/stack_2
[ 2019-08-21 15:11:17,570 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,570 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,570 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,570 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,570 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice/stack_1
[ 2019-08-21 15:11:17,571 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,571 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:17,571 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,571 ] [ DEBUG ] [ infer:130 ]  Partial infer for strided_slice/stack
[ 2019-08-21 15:11:17,571 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,571 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,571 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,571 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_4/bottleneck_v1/Pad/paddings
[ 2019-08-21 15:11:17,572 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,572 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,572 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,572 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [4 2], value = [[0 0]
 [1 1]
 [1 1]
 [0 0]]
[ 2019-08-21 15:11:17,572 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,572 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_3/bottleneck_v1/Pad/paddings
[ 2019-08-21 15:11:17,573 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [4 2], value = [[0 0]
 [1 1]
 [1 1]
 [0 0]]
[ 2019-08-21 15:11:17,573 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,573 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/Pad/paddings
[ 2019-08-21 15:11:17,573 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,573 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,573 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,574 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [4 2], value = [[0 0]
 [3 3]
 [3 3]
 [0 0]]
[ 2019-08-21 15:11:17,574 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,574 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/sub/y
[ 2019-08-21 15:11:17,574 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,574 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,574 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,575 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1 1 3], value = [[[123.68  116.779 103.939]]]
[ 2019-08-21 15:11:17,575 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,575 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/sub/negate_
[ 2019-08-21 15:11:17,575 ] [ DEBUG ] [ infer:131 ]  Op: Mul
[ 2019-08-21 15:11:17,575 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,575 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [1 1 3], value = [[[123.68  116.779 103.939]]]
[ 2019-08-21 15:11:17,575 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1
[ 2019-08-21 15:11:17,576 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,579 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1 1 3], value = [[[-123.68  -116.779 -103.939]]]
[ 2019-08-21 15:11:17,579 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,579 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayStack_1/range/delta
[ 2019-08-21 15:11:17,580 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,580 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,580 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,580 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,580 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,580 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayStack_1/range/start
[ 2019-08-21 15:11:17,581 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,581 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,581 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,581 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,581 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayStack/range/delta
[ 2019-08-21 15:11:17,581 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,582 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,582 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,582 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,582 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,582 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayStack/range/start
[ 2019-08-21 15:11:17,582 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,583 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,583 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,583 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/Const
[ 2019-08-21 15:11:17,583 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,583 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,583 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,583 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Enter
[ 2019-08-21 15:11:17,583 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:17,584 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,584 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,584 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,584 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,584 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,584 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Merge
[ 2019-08-21 15:11:17,584 ] [ DEBUG ] [ infer:131 ]  Op: Merge
[ 2019-08-21 15:11:17,584 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = <UNKNOWN>, value = <UNKNOWN>
[ 2019-08-21 15:11:17,585 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:17,585 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,585 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayUnstack/range/delta
[ 2019-08-21 15:11:17,585 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,585 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,585 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,585 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:17,585 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayUnstack/range/start
[ 2019-08-21 15:11:17,586 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,586 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:17,586 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,586 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayUnstack/strided_slice/stack_2
[ 2019-08-21 15:11:17,586 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,586 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,586 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,587 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayUnstack/strided_slice/stack_1
[ 2019-08-21 15:11:17,587 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,587 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,587 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,587 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,587 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,588 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,591 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,591 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/strided_slice/stack_2
[ 2019-08-21 15:11:17,591 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,591 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,591 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,591 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,591 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/strided_slice/stack_1
[ 2019-08-21 15:11:17,592 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,592 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,592 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,592 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:17,593 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,593 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/strided_slice/stack
[ 2019-08-21 15:11:17,593 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,593 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,593 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,593 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:17,594 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,594 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/conv1/weights/read/_502__cf__508
[ 2019-08-21 15:11:17,594 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,594 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,594 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,599 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [ 7  7  3 64], value = [[[[ 4.64108249e-04 -1.74941553e-04 -1.95158224e-04 ...  1.61375152e-04
     4.36045288e-04 -2.63...
[ 2019-08-21 15:11:17,599 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,600 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,603 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,603 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,603 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,604 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [64], value = [ 1.3811203   1.0502448  -1.540443    5.452084    3.9308462   3.6434348
  2.334713   -1.9265155  ...
[ 2019-08-21 15:11:17,604 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,604 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block1/unit_1/bottleneck_v1/conv1/weights/read/_497__cf__503
[ 2019-08-21 15:11:17,604 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,604 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,604 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,605 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [ 1  1 64 64], value = [[[[ 0.00031623 -0.01128012  0.01996796 ...  0.05222897  0.00173036
    -0.05491556]
   [ 0.05375...
[ 2019-08-21 15:11:17,605 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,605 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_1/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,606 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,606 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,606 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,606 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [64], value = [-2.4751043e+00  3.9588630e-02 -1.8484299e+00  3.5001514e+00
 -1.5810425e+00  5.3505678e+00  3.14...
[ 2019-08-21 15:11:17,607 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,607 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block1/unit_1/bottleneck_v1/conv2/weights/read/_492__cf__498
[ 2019-08-21 15:11:17,607 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,607 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,607 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,609 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [ 3  3 64 64], value = [[[[-3.55904340e-05 -5.05569438e-03  9.64875612e-03 ... -2.76672356e-02
     6.59038022e-04 -5.97...
[ 2019-08-21 15:11:17,610 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,610 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_1/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,610 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,610 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,610 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,611 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [64], value = [-0.7343422   0.8418256   3.7955399   0.900686    2.051835    2.3549833
 -0.88262045 -1.578823   ...
[ 2019-08-21 15:11:17,614 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,614 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block1/unit_1/bottleneck_v1/conv3/weights/read/_487__cf__493
[ 2019-08-21 15:11:17,614 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,615 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,615 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,616 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1  64 256], value = [[[[ 4.30948194e-06 -1.33537435e-06  2.20004907e-07 ... -1.22277243e-06
     2.51581191e-08  1.48...
[ 2019-08-21 15:11:17,616 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,616 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_1/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,616 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,616 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,616 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,618 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [  0.424349    -1.972537     1.3978754   -0.7982131    2.4827313
  -0.15707403  -0.74834514   2.0...
[ 2019-08-21 15:11:17,619 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,619 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block1/unit_1/bottleneck_v1/shortcut/weights/read/_507__cf__513
[ 2019-08-21 15:11:17,619 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,619 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,619 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,620 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1  64 256], value = [[[[-0.0224003  -0.01278749 -0.01815509 ... -0.03889255  0.03967233
    -0.0447415 ]
   [-0.01585...
[ 2019-08-21 15:11:17,620 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,620 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_1/bottleneck_v1/shortcut/Conv2D_bn_offset
[ 2019-08-21 15:11:17,620 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,620 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,621 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,622 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 8.59432817e-02  1.44665825e+00  3.55349970e+00 -1.94488358e+00
  4.73191977e+00  2.60677481e+00...
[ 2019-08-21 15:11:17,622 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,623 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block1/unit_2/bottleneck_v1/conv1/weights/read/_482__cf__488
[ 2019-08-21 15:11:17,625 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,626 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,626 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,626 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 256  64], value = [[[[ 4.63978686e-05 -4.76801688e-05  6.97050473e-06 ...  9.23398966e-06
     1.11675663e-05  5.53...
[ 2019-08-21 15:11:17,627 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,627 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_2/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,627 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,627 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,627 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,628 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [64], value = [-1.9465362e+00 -2.3402996e+00  5.8809769e-01  7.2492504e-01
 -5.4025662e-01  5.2374399e-01 -6.46...
[ 2019-08-21 15:11:17,628 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,628 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block1/unit_2/bottleneck_v1/conv2/weights/read/_477__cf__483
[ 2019-08-21 15:11:17,628 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,628 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,628 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,631 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [ 3  3 64 64], value = [[[[ 4.45543565e-02 -2.64205672e-02  2.18123924e-02 ... -6.17487682e-03
     1.30373263e-03  1.34...
[ 2019-08-21 15:11:17,631 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,631 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_2/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,631 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,631 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,632 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,632 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [64], value = [-0.5421555  -0.77099836  2.6010833   0.95333755 -1.5628878   2.0529711
 -0.21615231 -1.7814732  ...
[ 2019-08-21 15:11:17,632 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,633 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block1/unit_2/bottleneck_v1/conv3/weights/read/_472__cf__478
[ 2019-08-21 15:11:17,633 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,633 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,633 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,634 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1  64 256], value = [[[[-0.00893994 -0.03818517 -0.01459556 ... -0.00323571  0.15353067
     0.08434541]
   [-0.00432...
[ 2019-08-21 15:11:17,636 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,637 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_2/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,637 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,637 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,637 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,639 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-2.56972611e-01  3.90341222e-01 -1.99360085e+00 -3.62123370e-01
 -7.77979493e-02  1.80408776e-01...
[ 2019-08-21 15:11:17,639 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,639 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block1/unit_3/bottleneck_v1/conv1/weights/read/_467__cf__473
[ 2019-08-21 15:11:17,639 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,640 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,640 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,640 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 256  64], value = [[[[ 5.0230687e-05 -7.3706848e-05  1.3710212e-04 ...  9.9079574e-05
    -5.8603277e-05 -8.5390806...
[ 2019-08-21 15:11:17,641 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,641 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_3/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,641 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,641 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,641 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,642 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [64], value = [-1.3790115   0.7470263  -0.16422507 -0.27383205 -1.6613547  -0.05829925
  0.06354634  1.0735474 ...
[ 2019-08-21 15:11:17,642 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,642 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block1/unit_3/bottleneck_v1/conv2/weights/read/_462__cf__468
[ 2019-08-21 15:11:17,642 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,642 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,642 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,645 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [ 3  3 64 64], value = [[[[-1.27601977e-02 -3.24738733e-02  5.49894981e-02 ... -2.21614763e-02
     3.83016057e-02 -4.01...
[ 2019-08-21 15:11:17,648 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,648 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_3/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,648 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,648 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,649 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,650 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [64], value = [-2.08606929e-01 -1.90749019e-01 -5.89796126e-01  8.77718925e-02
 -4.78530601e-02  1.27046812e+00...
[ 2019-08-21 15:11:17,650 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,650 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block1/unit_3/bottleneck_v1/conv3/weights/read/_457__cf__463
[ 2019-08-21 15:11:17,650 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,650 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,650 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,651 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1  64 256], value = [[[[-3.1780124e-01 -4.9120084e-05  3.8937628e-02 ...  1.7965302e-01
     9.4941501e-03 -2.2689693...
[ 2019-08-21 15:11:17,651 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,651 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block1/unit_3/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,651 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,652 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,652 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,653 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 2.93428206e+00 -4.96919407e-03 -1.60695672e+00  2.57921720e+00
  2.69810051e-01 -1.83299184e-04...
[ 2019-08-21 15:11:17,654 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,654 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_1/bottleneck_v1/conv1/weights/read/_452__cf__458
[ 2019-08-21 15:11:17,654 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,654 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,654 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,655 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 256 128], value = [[[[ 0.01242925 -0.01617105  0.01928404 ... -0.03529073  0.12490322
     0.01086236]
   [ 0.00119...
[ 2019-08-21 15:11:17,655 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,655 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_1/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,655 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,655 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,655 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,656 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [128], value = [ 5.9609628e-01  9.8397374e-01  2.4939221e-01 -1.0748929e+00
 -2.2251666e+00  2.3392036e+00 -2.45...
[ 2019-08-21 15:11:17,656 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,656 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_1/bottleneck_v1/conv2/weights/read/_447__cf__453
[ 2019-08-21 15:11:17,657 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,659 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,660 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,662 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 128 128], value = [[[[-6.27585053e-02 -2.27093901e-02 -7.22831255e-03 ...  2.15149907e-04
    -5.87685313e-03 -1.02...
[ 2019-08-21 15:11:17,662 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,662 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_1/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,662 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,663 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,663 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,664 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [128], value = [-2.437534    0.03366986  0.8704955  -0.13714042  1.1917963   0.15543246
  3.3507264  -2.0535135 ...
[ 2019-08-21 15:11:17,664 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,664 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_1/bottleneck_v1/conv3/weights/read/_442__cf__448
[ 2019-08-21 15:11:17,664 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,664 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,665 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,665 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 128 512], value = [[[[ 3.3026312e-02  9.4565272e-02 -7.8057669e-02 ... -1.8512672e-05
     7.0298538e-03  9.1885731...
[ 2019-08-21 15:11:17,665 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,665 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_1/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,666 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,666 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,666 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,669 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [ 1.26984537e-01  2.55484033e+00 -7.68113285e-02  1.21026313e+00
 -1.31856978e+00  1.44113564e+00...
[ 2019-08-21 15:11:17,671 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,671 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_1/bottleneck_v1/shortcut/weights/read/_512__cf__518
[ 2019-08-21 15:11:17,671 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,671 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,671 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,672 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 256 512], value = [[[[-0.06350439 -0.00074033  0.19874777 ... -0.07117056 -0.08085252
     0.00090254]
   [-0.02478...
[ 2019-08-21 15:11:17,672 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,672 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_1/bottleneck_v1/shortcut/Conv2D_bn_offset
[ 2019-08-21 15:11:17,672 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,673 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,673 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,676 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [-4.80958641e-01  2.01284215e-01 -3.37211967e+00  2.26378369e+00
  2.90555656e-01  2.42487955e+00...
[ 2019-08-21 15:11:17,676 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,676 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_2/bottleneck_v1/conv1/weights/read/_437__cf__443
[ 2019-08-21 15:11:17,676 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,677 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,677 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,677 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 512 128], value = [[[[ 0.03788782 -0.00450122  0.01117337 ... -0.00831605  0.01049219
     0.00545716]
   [-0.01825...
[ 2019-08-21 15:11:17,678 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,678 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_2/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,678 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,678 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,678 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,680 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [128], value = [-2.3570065e+00  8.2345062e-01  6.6208571e-01 -8.1076598e-01
 -1.2077824e-01  4.1758227e-01 -1.35...
[ 2019-08-21 15:11:17,682 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,682 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_2/bottleneck_v1/conv2/weights/read/_432__cf__438
[ 2019-08-21 15:11:17,682 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,683 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,683 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,685 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 128 128], value = [[[[ 0.00942923 -0.0267888  -0.02339642 ... -0.02133972  0.00591949
    -0.00099709]
   [-0.03661...
[ 2019-08-21 15:11:17,686 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,686 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_2/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,686 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,686 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,686 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,687 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [128], value = [ 4.88662124e-02 -4.10541564e-01 -5.56426644e-02  2.37432480e+00
 -8.22197914e-01 -6.81068778e-01...
[ 2019-08-21 15:11:17,688 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,688 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_2/bottleneck_v1/conv3/weights/read/_427__cf__433
[ 2019-08-21 15:11:17,688 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,688 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,688 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,689 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 128 512], value = [[[[-0.17786048  0.00280232 -0.00139161 ...  0.06216362  0.02002652
     0.01175307]
   [-0.10157...
[ 2019-08-21 15:11:17,689 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,689 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_2/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,689 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,690 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,690 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,693 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [-4.40973341e-02 -5.95078051e-01 -1.18573380e+00 -1.42431101e-02
 -4.23805594e-01  3.00072134e-01...
[ 2019-08-21 15:11:17,694 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,694 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_3/bottleneck_v1/conv1/weights/read/_422__cf__428
[ 2019-08-21 15:11:17,694 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,694 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,694 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,695 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 512 128], value = [[[[-0.00987589 -0.00400306 -0.02098291 ... -0.0148908  -0.00690196
     0.01284756]
   [-0.07214...
[ 2019-08-21 15:11:17,695 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,695 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_3/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,695 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,695 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,696 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,697 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [128], value = [ 7.81671226e-01 -4.98379827e-01  4.89879012e-01 -9.48889554e-02
  5.06000161e-01  5.66401958e-01...
[ 2019-08-21 15:11:17,697 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,697 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_3/bottleneck_v1/conv2/weights/read/_417__cf__423
[ 2019-08-21 15:11:17,697 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,697 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,698 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,700 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 128 128], value = [[[[-0.03417458  0.00853314  0.01176196 ... -0.05733049 -0.0343987
    -0.03268218]
   [-0.019002...
[ 2019-08-21 15:11:17,701 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,701 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_3/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,701 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,701 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,701 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,702 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [128], value = [-1.21702516e+00 -2.01508045e-01  3.36793423e-01  7.92401135e-02
  4.78265882e-02 -3.93141359e-01...
[ 2019-08-21 15:11:17,705 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,705 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_3/bottleneck_v1/conv3/weights/read/_412__cf__418
[ 2019-08-21 15:11:17,705 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,705 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,705 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,706 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 128 512], value = [[[[-0.06310017 -0.01471212  0.00044062 ... -0.01175126 -0.11508672
    -0.03335478]
   [-0.03131...
[ 2019-08-21 15:11:17,706 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,706 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_3/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,706 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,707 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,707 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,710 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [-2.85549760e-01 -2.64841616e-01 -1.58844978e-01 -1.66807985e+00
  2.51951635e-01  2.97003746e-01...
[ 2019-08-21 15:11:17,710 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,710 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_4/bottleneck_v1/conv1/weights/read/_407__cf__413
[ 2019-08-21 15:11:17,710 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,711 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,711 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,711 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 512 128], value = [[[[ 0.0072258  -0.04049483  0.01404724 ... -0.04347908 -0.02087065
    -0.01399305]
   [-0.02546...
[ 2019-08-21 15:11:17,712 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,712 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_4/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,712 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,712 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,712 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,713 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [128], value = [-9.17880535e-02  5.25092483e-01 -6.40227735e-01 -2.38739252e-01
  3.06392312e-01 -1.48420990e-01...
[ 2019-08-21 15:11:17,714 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,717 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_4/bottleneck_v1/conv2/weights/read/_402__cf__408
[ 2019-08-21 15:11:17,717 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,718 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,718 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,720 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 128 128], value = [[[[ 1.90913733e-02  3.55658531e-02  3.88441086e-02 ... -3.77886333e-02
     1.56798551e-03 -1.27...
[ 2019-08-21 15:11:17,721 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,721 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_4/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,721 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,721 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,721 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,722 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [128], value = [ 0.09800774  0.03799695  0.4950545   0.28906214 -0.11270463  0.3860771
 -0.66385466 -0.24618977 ...
[ 2019-08-21 15:11:17,722 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,722 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block2/unit_4/bottleneck_v1/conv3/weights/read/_397__cf__403
[ 2019-08-21 15:11:17,723 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,723 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,723 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,723 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 128 512], value = [[[[-1.6549410e-02 -6.4734765e-03 -3.2181110e-02 ...  6.6934258e-04
     1.2504861e-01 -6.3026050...
[ 2019-08-21 15:11:17,724 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,724 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block2/unit_4/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,724 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,724 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,724 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,728 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [ 2.69558239e+00  1.63806483e-01 -2.18443608e+00  2.31741357e+00
  1.21764183e-01 -2.39354954e-03...
[ 2019-08-21 15:11:17,729 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,729 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_1/bottleneck_v1/conv1/weights/read/_392__cf__398
[ 2019-08-21 15:11:17,729 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,730 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,730 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,730 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 512 256], value = [[[[-0.00405173 -0.01054402 -0.03977202 ... -0.00359251 -0.00125046
    -0.02903028]
   [ 0.01140...
[ 2019-08-21 15:11:17,731 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,731 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_1/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,731 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,731 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,731 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,733 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 0.7113526   1.0857633   0.8299122  -1.1718578   0.11896931 -0.2419886
 -1.0371301  -0.7652793  ...
[ 2019-08-21 15:11:17,734 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,734 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_1/bottleneck_v1/conv2/weights/read/_387__cf__393
[ 2019-08-21 15:11:17,734 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,734 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,734 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,737 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-8.71284679e-03  1.81176271e-02 -1.65016558e-02 ...  7.90401921e-03
     2.51549971e-03 -6.15...
[ 2019-08-21 15:11:17,737 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,737 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_1/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,738 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,740 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,741 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,742 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.40119505 -0.691105   -0.3883029   1.274854    0.38154036  0.2032451
  0.5815004  -0.9339087  ...
[ 2019-08-21 15:11:17,743 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,743 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_1/bottleneck_v1/conv3/weights/read/_382__cf__388
[ 2019-08-21 15:11:17,743 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,743 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,743 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,744 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-0.01777647 -0.05629966 -0.00290748 ... -0.05425401  0.03030267
     0.02421303]
   [-0.61191...
[ 2019-08-21 15:11:17,744 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,744 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_1/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,744 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,744 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,744 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,745 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.22093366  1.5324203   0.53350055 ... -0.25482124 -0.24413952
 -0.41256803]
[ 2019-08-21 15:11:17,745 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,745 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_1/bottleneck_v1/shortcut/weights/read/_517__cf__523
[ 2019-08-21 15:11:17,745 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,745 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,745 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,746 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  512 1024], value = [[[[-0.11115226 -0.00698497 -0.04536846 ... -0.07111143 -0.06974979
     0.03325446]
   [-0.05400...
[ 2019-08-21 15:11:17,746 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,746 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_1/bottleneck_v1/shortcut/Conv2D_bn_offset
[ 2019-08-21 15:11:17,746 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,746 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,746 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,747 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.79828227  4.239912   -0.2516005  ...  0.48758242 -0.53584623
  1.6774969 ]
[ 2019-08-21 15:11:17,747 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,747 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_2/bottleneck_v1/conv1/weights/read/_377__cf__383
[ 2019-08-21 15:11:17,747 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,747 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,747 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,748 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[-0.01133961  0.01263868 -0.00534887 ... -0.00451139 -0.00263864
     0.00249622]
   [ 0.00207...
[ 2019-08-21 15:11:17,748 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,748 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_2/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,748 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,748 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,748 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,750 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.35520422 -0.7842494  -0.83296835 -0.5839054  -0.43344134  0.1874555
  0.98109436 -0.40291536 ...
[ 2019-08-21 15:11:17,752 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,752 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_2/bottleneck_v1/conv2/weights/read/_372__cf__378
[ 2019-08-21 15:11:17,752 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,752 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,752 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,755 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-2.19557507e-04 -3.01199791e-04 -8.69192928e-03 ... -6.53646048e-03
     6.96349237e-03 -1.71...
[ 2019-08-21 15:11:17,755 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,755 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_2/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,756 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,756 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,756 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,758 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 0.3826265  -0.29609573 -0.44054222 -0.67305017  0.4246816  -0.8633474
 -0.58027685  1.346803   ...
[ 2019-08-21 15:11:17,758 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,758 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_2/bottleneck_v1/conv3/weights/read/_367__cf__373
[ 2019-08-21 15:11:17,758 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,758 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,759 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,759 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-2.30304687e-03  9.70856100e-03 -1.32876486e-01 ...  3.93917114e-02
     4.69251722e-03  7.28...
[ 2019-08-21 15:11:17,760 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,760 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_2/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,760 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,760 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,760 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,760 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.1793291   0.09759636  0.9659663  ...  0.08486253 -0.9534179
  0.07942396]
[ 2019-08-21 15:11:17,764 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,764 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_3/bottleneck_v1/conv1/weights/read/_362__cf__368
[ 2019-08-21 15:11:17,764 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,764 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,764 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,765 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 0.00382992  0.00216053 -0.0116993  ... -0.01373266 -0.00308101
    -0.00765375]
   [ 0.00565...
[ 2019-08-21 15:11:17,765 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,765 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_3/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,765 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,765 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,766 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,768 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 7.03340530e-01  1.59973216e+00  3.34033310e-01 -3.61618936e-01
 -1.82068157e+00 -6.56980753e-01...
[ 2019-08-21 15:11:17,768 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,768 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_3/bottleneck_v1/conv2/weights/read/_357__cf__363
[ 2019-08-21 15:11:17,768 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,768 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,769 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,771 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[ 1.03563378e-02  1.18010370e-02 -4.12396118e-02 ...  1.58134114e-03
    -1.23850713e-02 -4.21...
[ 2019-08-21 15:11:17,771 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,771 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_3/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,771 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,772 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,774 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,776 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 5.79534888e-01 -1.36327744e-02 -5.69676757e-02  2.23652482e-01
 -6.97614253e-01 -3.15594077e-01...
[ 2019-08-21 15:11:17,776 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,777 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_3/bottleneck_v1/conv3/weights/read/_352__cf__358
[ 2019-08-21 15:11:17,777 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,777 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,777 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,777 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 0.02069903 -0.00116222 -0.04376029 ...  0.0524575  -0.0655622
    -0.01419311]
   [ 0.030328...
[ 2019-08-21 15:11:17,778 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,778 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_3/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,778 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,778 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,778 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,778 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.05567572 -0.17946015  0.47063375 ...  0.22522157 -0.5962442
 -0.3664487 ]
[ 2019-08-21 15:11:17,779 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,779 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_4/bottleneck_v1/conv1/weights/read/_347__cf__353
[ 2019-08-21 15:11:17,779 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,779 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,779 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,779 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 1.0596439e-02  1.0093055e-02 -5.8755130e-03 ... -6.3341069e-03
    -7.4430043e-03  5.9202602...
[ 2019-08-21 15:11:17,780 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,780 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_4/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,780 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,780 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,780 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,782 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-8.16664100e-01 -7.59975672e-01 -6.10798597e-04 -1.46581173e-01
 -1.36470631e-01 -2.92771578e-01...
[ 2019-08-21 15:11:17,782 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,782 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_4/bottleneck_v1/conv2/weights/read/_342__cf__348
[ 2019-08-21 15:11:17,782 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,782 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,782 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,785 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[ 0.02423852 -0.01132412  0.03339144 ... -0.0004745   0.02629062
    -0.00981945]
   [-0.00411...
[ 2019-08-21 15:11:17,786 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,786 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_4/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,786 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,786 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,786 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,788 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 1.11297297e+00  5.41678667e-02  1.95151865e-01 -9.17464972e-01
 -1.41584456e-01  3.94261926e-01...
[ 2019-08-21 15:11:17,788 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,788 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_4/bottleneck_v1/conv3/weights/read/_337__cf__343
[ 2019-08-21 15:11:17,788 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,788 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,789 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,789 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-0.03947022  0.06245787 -0.03144765 ... -0.06009795 -0.01443091
     0.03650019]
   [ 0.00913...
[ 2019-08-21 15:11:17,789 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,789 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_4/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,789 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,789 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,790 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,790 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.0762777  -0.55019695  0.60213864 ... -0.09102306 -0.5356765
 -0.3146617 ]
[ 2019-08-21 15:11:17,790 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,790 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_5/bottleneck_v1/conv1/weights/read/_332__cf__338
[ 2019-08-21 15:11:17,790 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,790 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,791 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,791 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 2.8684628e-03 -4.5896890e-03 -4.5487178e-03 ...  9.4198771e-03
    -1.0981573e-05 -2.7068988...
[ 2019-08-21 15:11:17,791 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,791 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_5/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,791 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,792 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,792 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,793 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-2.8838623   0.5314789  -0.16913846 -1.2915249  -0.17988437 -0.62399304
 -0.29771698 -0.16374615...
[ 2019-08-21 15:11:17,794 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,794 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_5/bottleneck_v1/conv2/weights/read/_327__cf__333
[ 2019-08-21 15:11:17,794 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,794 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,794 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,797 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-3.74361016e-02 -5.09657757e-03 -9.95790397e-05 ...  8.48262198e-03
    -2.95320264e-04  2.10...
[ 2019-08-21 15:11:17,798 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,798 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_5/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,798 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,798 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,798 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,800 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.118797   -1.0454847   0.49328157 -0.1204524  -0.8885338  -0.1215387
  0.19107527 -0.23166981 ...
[ 2019-08-21 15:11:17,801 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,801 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_5/bottleneck_v1/conv3/weights/read/_322__cf__328
[ 2019-08-21 15:11:17,801 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,801 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,801 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,802 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 0.00342742  0.14500782 -0.01213852 ... -0.36036238  0.17305407
    -0.00149647]
   [ 0.01594...
[ 2019-08-21 15:11:17,802 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,802 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_5/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,802 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,802 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,802 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,803 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.10354734  0.00079679  0.44429773 ...  0.12962627 -0.41226017
 -0.5313784 ]
[ 2019-08-21 15:11:17,803 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,803 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_6/bottleneck_v1/conv1/weights/read/_317__cf__323
[ 2019-08-21 15:11:17,803 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,803 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,803 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,804 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 0.00443793 -0.01845037 -0.0061293  ...  0.0058228   0.00357379
     0.00678192]
   [ 0.00046...
[ 2019-08-21 15:11:17,804 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,804 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_6/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,804 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,804 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,804 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,806 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-1.7205193   0.42818356 -0.9767865   0.32112375 -1.1003852  -0.15591028
  0.07104766 -1.3628464 ...
[ 2019-08-21 15:11:17,806 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,806 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_6/bottleneck_v1/conv2/weights/read/_312__cf__318
[ 2019-08-21 15:11:17,806 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,806 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,806 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,811 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[ 0.00986296 -0.00553223  0.02304729 ... -0.01467825 -0.00067494
    -0.01051523]
   [-0.00607...
[ 2019-08-21 15:11:17,812 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,812 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_6/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,812 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,812 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,812 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,814 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.28737706  0.02091849  0.13317609 -0.50066096  0.05553234 -0.30614182
  0.23491505 -0.05276984...
[ 2019-08-21 15:11:17,814 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,815 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_6/bottleneck_v1/conv3/weights/read/_307__cf__313
[ 2019-08-21 15:11:17,815 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,815 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,815 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,816 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 0.05125834 -0.06581296 -0.11316475 ... -0.27769384  0.20829429
     0.04256414]
   [ 0.17945...
[ 2019-08-21 15:11:17,816 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,816 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_6/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,816 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,816 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,816 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,817 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.24281871 -0.22264242  0.22961232 ...  0.20283046 -0.21185799
 -0.73926973]
[ 2019-08-21 15:11:17,817 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,817 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_7/bottleneck_v1/conv1/weights/read/_302__cf__308
[ 2019-08-21 15:11:17,817 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,820 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,821 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,821 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[-0.01858268  0.00715097 -0.0063538  ...  0.00998313  0.00643032
     0.00846394]
   [ 0.00264...
[ 2019-08-21 15:11:17,821 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,821 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_7/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,822 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,822 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,822 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,824 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.16669732  0.7776865  -0.79015565 -1.0900884   0.21281198  0.25894648
 -0.00528789 -1.1452413 ...
[ 2019-08-21 15:11:17,824 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,824 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_7/bottleneck_v1/conv2/weights/read/_297__cf__303
[ 2019-08-21 15:11:17,824 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,824 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,824 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,827 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-2.31164340e-02  2.31752335e-03  3.25918086e-02 ...  1.54007487e-02
     2.68840939e-02  5.78...
[ 2019-08-21 15:11:17,827 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,827 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_7/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,827 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,827 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,827 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,829 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 4.45931256e-01 -4.08496857e-02  2.47798562e-02 -2.44028389e-01
  2.18019307e-01  4.32908535e-02...
[ 2019-08-21 15:11:17,832 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,832 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_7/bottleneck_v1/conv3/weights/read/_292__cf__298
[ 2019-08-21 15:11:17,832 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,832 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,832 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,833 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 0.0195188   0.02067995 -0.00068872 ...  0.52524984  0.26216403
     0.03104902]
   [-0.03791...
[ 2019-08-21 15:11:17,834 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,834 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_7/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,834 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,834 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,834 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,835 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.3774263  -0.3761122  -0.08942723 ...  0.61681014  0.41731378
 -0.47806782]
[ 2019-08-21 15:11:17,835 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,835 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_8/bottleneck_v1/conv1/weights/read/_287__cf__293
[ 2019-08-21 15:11:17,835 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,835 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,835 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,836 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[-0.02978607  0.00581992 -0.00705271 ... -0.00622403  0.00590882
     0.00348403]
   [-0.00958...
[ 2019-08-21 15:11:17,836 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,836 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_8/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,836 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,837 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,837 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,839 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-5.8433825e-01 -9.5147640e-01 -9.5011216e-01 -2.6720712e-01
 -2.9048467e-01  2.6145089e-01 -3.14...
[ 2019-08-21 15:11:17,839 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,839 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_8/bottleneck_v1/conv2/weights/read/_282__cf__288
[ 2019-08-21 15:11:17,839 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,839 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,839 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,842 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[ 2.08052378e-02  3.60903516e-02  3.89397033e-02 ... -5.07981554e-02
     8.71954020e-04  3.86...
[ 2019-08-21 15:11:17,843 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,844 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_8/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,844 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,844 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,844 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,846 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.4175248  -0.16458601 -0.7466825  -0.22808975  0.18114522 -0.22137505
  0.22076625  0.29203224...
[ 2019-08-21 15:11:17,846 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,846 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_8/bottleneck_v1/conv3/weights/read/_277__cf__283
[ 2019-08-21 15:11:17,846 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,846 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,846 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,847 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-0.22957745 -0.0885928   0.08172584 ... -0.06124607  0.13293473
    -0.00105588]
   [ 0.04487...
[ 2019-08-21 15:11:17,847 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,847 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_8/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,847 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,848 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,848 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,848 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.6739772  -0.39573833 -0.14817068 ... -0.4774291  -0.26073232
 -0.32155573]
[ 2019-08-21 15:11:17,848 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,848 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_9/bottleneck_v1/conv1/weights/read/_272__cf__278
[ 2019-08-21 15:11:17,849 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,849 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,849 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,849 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 0.00343918  0.00661883 -0.0056509  ... -0.00288614 -0.00336998
     0.00236383]
   [-0.02325...
[ 2019-08-21 15:11:17,850 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,850 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_9/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,850 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,850 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,850 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,852 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.9138236  -0.63814276 -0.5391281  -0.97924423 -0.08791906 -0.7286261
 -1.2555107  -0.59011626 ...
[ 2019-08-21 15:11:17,855 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,855 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_9/bottleneck_v1/conv2/weights/read/_267__cf__273
[ 2019-08-21 15:11:17,855 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,855 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,855 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,858 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[ 1.49458703e-02  7.21594021e-02 -9.10941660e-02 ... -4.49147224e-02
     2.67457832e-02  9.79...
[ 2019-08-21 15:11:17,858 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,858 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_9/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,858 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,858 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,858 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,860 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 5.32522678e-01 -2.80919909e-01 -5.60434222e-01  1.71560645e-02
  1.38803571e-01  4.22450304e-01...
[ 2019-08-21 15:11:17,861 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,861 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_9/bottleneck_v1/conv3/weights/read/_262__cf__268
[ 2019-08-21 15:11:17,861 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,861 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,861 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,862 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-0.0480752   0.02153455 -0.07169733 ... -0.08926089  0.03374584
    -0.16050044]
   [-0.01334...
[ 2019-08-21 15:11:17,862 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,862 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_9/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,866 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,866 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,866 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,867 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [0.01975647 0.37272942 0.14801654 ... 0.16525522 0.2137172  3.2086868 ]
[ 2019-08-21 15:11:17,867 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,867 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_10/bottleneck_v1/conv1/weights/read/_257__cf__263
[ 2019-08-21 15:11:17,867 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,868 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,868 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,868 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[-0.00581512 -0.00726025 -0.01454726 ... -0.01057408 -0.01523411
    -0.01083865]
   [ 0.01108...
[ 2019-08-21 15:11:17,869 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,869 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_10/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,869 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,869 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,869 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,871 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 0.00437874 -1.0407349  -0.20897731  0.8353066   0.00382417 -0.01226807
 -0.1483759  -0.09940428...
[ 2019-08-21 15:11:17,871 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,872 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_10/bottleneck_v1/conv2/weights/read/_252__cf__258
[ 2019-08-21 15:11:17,872 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,872 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,872 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,874 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-5.26833646e-02  3.81134520e-03  2.28320677e-02 ... -2.53645405e-02
     7.87444972e-03 -8.55...
[ 2019-08-21 15:11:17,876 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,877 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_10/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,877 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,877 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,877 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,879 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-2.7658075e-01  2.5479272e-01 -9.8050284e-01  4.0418875e-01
 -1.3318160e-01  4.6557549e-01 -1.86...
[ 2019-08-21 15:11:17,879 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,879 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_10/bottleneck_v1/conv3/weights/read/_247__cf__253
[ 2019-08-21 15:11:17,879 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,879 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,879 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,880 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 2.07422599e-01 -1.02116644e-01  6.27835169e-02 ...  1.18874684e-01
     1.24141447e-01 -1.45...
[ 2019-08-21 15:11:17,880 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,880 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_10/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,880 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,880 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,880 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,881 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.1289697   0.08561569  0.21018787 ... -0.3687311  -0.13785255
 -0.05144531]
[ 2019-08-21 15:11:17,881 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,881 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_11/bottleneck_v1/conv1/weights/read/_242__cf__248
[ 2019-08-21 15:11:17,881 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,881 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,881 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,882 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 0.01112397 -0.01631949 -0.00930312 ... -0.0264788  -0.00584631
     0.01867755]
   [-0.00139...
[ 2019-08-21 15:11:17,882 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,882 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_11/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,882 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,882 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,882 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,884 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-5.23794234e-01 -6.30773067e-01 -1.31218582e-01 -4.51147020e-01
  8.33667815e-04  3.95931005e-02...
[ 2019-08-21 15:11:17,884 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,887 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_11/bottleneck_v1/conv2/weights/read/_237__cf__243
[ 2019-08-21 15:11:17,887 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,888 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,888 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,890 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-0.02066823 -0.01819543 -0.00598208 ... -0.02192373  0.02425792
     0.01738521]
   [-0.00142...
[ 2019-08-21 15:11:17,890 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,891 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_11/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,891 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,891 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,891 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,893 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-2.40241766e-01  1.06453419e-01  1.78684413e-01  2.21279114e-01
  6.02098703e-02 -4.06702161e-01...
[ 2019-08-21 15:11:17,893 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,893 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_11/bottleneck_v1/conv3/weights/read/_232__cf__238
[ 2019-08-21 15:11:17,893 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,894 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,894 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,894 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 0.06340767 -0.08853634  0.24140546 ...  0.00620968 -0.06282786
    -0.01075423]
   [-0.00112...
[ 2019-08-21 15:11:17,894 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,895 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_11/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,895 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,895 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,895 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,895 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.13077869 -0.0710028   0.4475705  ... -0.32948688  0.23885196
  0.07583773]
[ 2019-08-21 15:11:17,896 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,899 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_12/bottleneck_v1/conv1/weights/read/_227__cf__233
[ 2019-08-21 15:11:17,899 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,899 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,899 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,900 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[-0.0130918   0.00776875  0.00526549 ... -0.01739492 -0.00882907
    -0.02217237]
   [ 0.00756...
[ 2019-08-21 15:11:17,900 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,900 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_12/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,901 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,901 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,901 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,903 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.80954725 -0.39100164 -0.66784585 -0.6013833  -0.8866539  -0.5866025
 -0.55701005 -1.3769547  ...
[ 2019-08-21 15:11:17,903 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,903 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_12/bottleneck_v1/conv2/weights/read/_222__cf__228
[ 2019-08-21 15:11:17,904 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,904 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,904 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,906 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[ 2.93080211e-02  6.12828089e-03  3.82028669e-02 ... -7.63920275e-03
     4.74995710e-02  6.96...
[ 2019-08-21 15:11:17,906 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,906 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_12/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,908 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,909 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,909 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,911 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.14419913 -0.30514467 -0.19178951  0.19376618  0.48141885 -0.08922195
  0.8209733  -1.1228702 ...
[ 2019-08-21 15:11:17,911 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,911 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_12/bottleneck_v1/conv3/weights/read/_217__cf__223
[ 2019-08-21 15:11:17,911 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,911 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,911 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,912 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-1.15616526e-02  2.74158359e-01  5.86961722e-03 ... -9.00606588e-02
     1.95284367e-01 -4.03...
[ 2019-08-21 15:11:17,912 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,912 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_12/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,912 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,913 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,913 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,913 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.09588763  0.4233136   0.3496337  ...  0.14031777 -0.45476997
 -0.15886222]
[ 2019-08-21 15:11:17,913 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,913 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_13/bottleneck_v1/conv1/weights/read/_212__cf__218
[ 2019-08-21 15:11:17,914 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,914 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,914 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,914 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[-0.00725111  0.01212684  0.01876062 ... -0.00231433  0.00179822
     0.00180749]
   [ 0.00745...
[ 2019-08-21 15:11:17,915 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,915 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_13/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,915 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,915 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,915 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,917 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-7.75056303e-01 -6.57834649e-01 -1.25451535e-01 -4.09150094e-01
  1.49536908e-01  3.16332787e-01...
[ 2019-08-21 15:11:17,920 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,920 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_13/bottleneck_v1/conv2/weights/read/_207__cf__213
[ 2019-08-21 15:11:17,920 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,920 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,920 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,922 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-1.15350876e-02 -1.97521187e-02  3.16374213e-03 ...  1.72976013e-02
    -6.88625187e-06  1.49...
[ 2019-08-21 15:11:17,923 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,923 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_13/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,923 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,923 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,923 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,925 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-1.38262022e+00  1.88896060e-02  1.07554626e+00  5.34664094e-01
  4.64452147e-01 -3.98691595e-01...
[ 2019-08-21 15:11:17,925 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,925 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_13/bottleneck_v1/conv3/weights/read/_202__cf__208
[ 2019-08-21 15:11:17,925 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,925 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,925 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,926 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 0.00175914  0.07438327 -0.00630371 ... -0.1765044  -0.04310325
     0.01758979]
   [ 0.09180...
[ 2019-08-21 15:11:17,926 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,926 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_13/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,926 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,927 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,927 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,927 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.047244    0.09320438  0.53586257 ...  0.16003078  0.22417682
 -0.1630114 ]
[ 2019-08-21 15:11:17,927 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,927 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_14/bottleneck_v1/conv1/weights/read/_197__cf__203
[ 2019-08-21 15:11:17,928 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,930 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,931 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,931 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 7.7334982e-03 -1.5297175e-02 -1.0391486e-02 ...  4.3668561e-03
     1.3524702e-02 -1.3250215...
[ 2019-08-21 15:11:17,931 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,932 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_14/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,932 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,932 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,932 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,934 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.3307007  -0.5042166   0.19714135 -0.34478956 -0.45056477 -0.3563705
 -1.0150865  -0.08122861 ...
[ 2019-08-21 15:11:17,934 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,934 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_14/bottleneck_v1/conv2/weights/read/_192__cf__198
[ 2019-08-21 15:11:17,935 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,935 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,935 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,937 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-9.41939279e-02 -1.79741029e-02 -4.52345386e-02 ...  2.45908350e-01
    -4.40380275e-02 -7.73...
[ 2019-08-21 15:11:17,937 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,938 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_14/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,938 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,938 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,938 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,940 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.4842568   0.55843544  0.3400754   0.5067639  -0.8318213  -0.2961461
 -0.6402489   0.31525642 ...
[ 2019-08-21 15:11:17,942 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,942 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_14/bottleneck_v1/conv3/weights/read/_187__cf__193
[ 2019-08-21 15:11:17,942 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,942 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,942 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,943 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-0.00720567 -0.00200151  0.01015673 ...  0.03668773 -0.05951352
    -0.02205336]
   [-0.05897...
[ 2019-08-21 15:11:17,943 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,943 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_14/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,943 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,943 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,943 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,944 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.4529221   0.4557873   0.32937253 ...  0.4998069  -0.11963736
  0.20405117]
[ 2019-08-21 15:11:17,944 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,944 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_15/bottleneck_v1/conv1/weights/read/_182__cf__188
[ 2019-08-21 15:11:17,944 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,944 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,944 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,945 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 2.2569809e-02 -1.5708400e-03  2.3117068e-03 ...  2.7447097e-02
    -9.8316157e-03 -6.8231276...
[ 2019-08-21 15:11:17,945 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,945 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_15/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,945 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,945 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,945 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,947 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.651842   -1.0716193  -0.8554064  -0.96792185 -0.72640264 -0.19798249
 -0.5830505  -1.0988182 ...
[ 2019-08-21 15:11:17,947 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,947 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_15/bottleneck_v1/conv2/weights/read/_177__cf__183
[ 2019-08-21 15:11:17,947 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,948 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,948 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,950 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-2.49345670e-03 -3.35693844e-02  1.25841210e-02 ... -3.97911072e-02
     2.43474878e-02 -5.07...
[ 2019-08-21 15:11:17,950 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,950 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_15/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,950 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,951 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,954 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,955 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 2.86961615e-01 -4.18123126e-01  4.00913477e-01  2.48694718e-01
 -1.38688028e-01 -5.70992410e-01...
[ 2019-08-21 15:11:17,956 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,956 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_15/bottleneck_v1/conv3/weights/read/_172__cf__178
[ 2019-08-21 15:11:17,956 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,956 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,956 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,957 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 0.0052174  -0.28927442 -0.18738721 ... -0.00996497  0.09861473
    -0.08105125]
   [ 0.05080...
[ 2019-08-21 15:11:17,957 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,957 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_15/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,957 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,957 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,958 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,958 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.15233228  0.25657028  0.61837655 ... -0.4418515  -0.01153734
 -0.19461437]
[ 2019-08-21 15:11:17,958 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,958 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_16/bottleneck_v1/conv1/weights/read/_167__cf__173
[ 2019-08-21 15:11:17,958 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,959 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,959 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,959 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 7.49659305e-03  2.17450550e-03  3.50223482e-03 ... -1.70154292e-02
    -2.89016636e-03 -4.81...
[ 2019-08-21 15:11:17,959 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,959 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_16/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,959 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,960 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,960 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,962 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.773336   -0.9121206  -0.5324215   0.03277653  0.3271107  -0.41582346
 -0.85520685 -0.37583843...
[ 2019-08-21 15:11:17,965 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,965 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_16/bottleneck_v1/conv2/weights/read/_162__cf__168
[ 2019-08-21 15:11:17,965 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,965 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,965 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,968 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-4.23654467e-02 -1.37500875e-02 -1.26220295e-02 ... -1.54328598e-02
     2.07913648e-02  6.50...
[ 2019-08-21 15:11:17,968 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,968 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_16/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,969 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,969 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,969 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,971 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-1.67092705e+00 -8.37914884e-01  5.02655327e-01  3.25867951e-01
  1.10877812e-01  1.95431113e-01...
[ 2019-08-21 15:11:17,971 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,971 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_16/bottleneck_v1/conv3/weights/read/_157__cf__163
[ 2019-08-21 15:11:17,971 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,971 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,972 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,972 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 0.0392926  -0.07441221 -0.06941497 ...  0.18499678  0.02093794
    -0.02630121]
   [-0.04745...
[ 2019-08-21 15:11:17,972 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,975 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_16/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,976 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,976 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,976 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,976 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.01531142  0.24804622 -0.21581566 ...  0.08206142 -0.2972537
 -0.05831825]
[ 2019-08-21 15:11:17,976 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,977 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_17/bottleneck_v1/conv1/weights/read/_152__cf__158
[ 2019-08-21 15:11:17,977 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,977 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,977 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,978 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[-0.00850539  0.00483116 -0.00337729 ...  0.00013587 -0.00885906
    -0.00064291]
   [ 0.01913...
[ 2019-08-21 15:11:17,978 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,978 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_17/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,978 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,978 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,978 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,980 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-2.0334977e-01 -4.9929121e-01 -7.7418441e-01 -2.4290439e-01
 -5.9077466e-01 -1.2013925e+00 -1.27...
[ 2019-08-21 15:11:17,980 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,980 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_17/bottleneck_v1/conv2/weights/read/_147__cf__153
[ 2019-08-21 15:11:17,981 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,981 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,981 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,983 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-6.49647638e-02  5.54414019e-02  2.09154356e-02 ... -6.04901426e-02
    -3.09483930e-02  2.07...
[ 2019-08-21 15:11:17,983 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,983 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_17/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:17,983 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,986 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,987 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,988 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-3.46656591e-02  2.62327522e-01  7.10912108e-01  4.22393501e-01
 -2.08011478e-01 -3.57801527e-01...
[ 2019-08-21 15:11:17,989 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,989 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_17/bottleneck_v1/conv3/weights/read/_142__cf__148
[ 2019-08-21 15:11:17,989 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,989 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,989 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,990 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-0.04878529 -0.16419953  0.03232806 ... -0.1233708   0.10814972
    -0.06757636]
   [-0.00175...
[ 2019-08-21 15:11:17,990 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,990 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_17/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:17,990 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,991 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,991 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,991 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.5527916   0.02878508  0.15311736 ...  0.17362443 -0.0481334
  0.5754384 ]
[ 2019-08-21 15:11:17,991 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,992 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_18/bottleneck_v1/conv1/weights/read/_137__cf__143
[ 2019-08-21 15:11:17,992 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,992 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,992 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,992 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[-0.01140081  0.01438149  0.00570319 ... -0.00556249  0.00248343
    -0.00492338]
   [-0.01723...
[ 2019-08-21 15:11:17,993 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,993 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_18/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:17,993 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,993 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,993 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:17,995 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-8.7760466e-01 -4.4335994e-01  3.0702287e-01 -2.5431961e-01
 -5.0035447e-02 -3.6621061e-01 -7.49...
[ 2019-08-21 15:11:17,998 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:17,999 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_18/bottleneck_v1/conv2/weights/read/_132__cf__138
[ 2019-08-21 15:11:17,999 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:17,999 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:17,999 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,002 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-0.01315852 -0.03900222 -0.09242561 ... -0.01338235  0.02814335
     0.02464122]
   [-0.00348...
[ 2019-08-21 15:11:18,002 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,002 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_18/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:18,002 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,002 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,003 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,004 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 9.10504460e-02 -3.99172306e-03 -8.52792203e-01 -4.89658117e-02
 -2.79446274e-01  4.77437884e-01...
[ 2019-08-21 15:11:18,005 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,005 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_18/bottleneck_v1/conv3/weights/read/_127__cf__133
[ 2019-08-21 15:11:18,005 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,005 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,005 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,006 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 3.38195823e-03 -9.25072879e-02  2.59109020e-01 ...  2.10712291e-02
     7.75615126e-02 -5.57...
[ 2019-08-21 15:11:18,006 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,007 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_18/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:18,009 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,009 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,010 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,010 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.23102246  0.08541796 -0.11555821 ... -0.002507    0.30109262
  0.38856566]
[ 2019-08-21 15:11:18,010 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,010 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_19/bottleneck_v1/conv1/weights/read/_122__cf__128
[ 2019-08-21 15:11:18,011 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,011 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,011 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,011 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 0.0061114   0.00753611 -0.00185965 ... -0.0090142  -0.01231551
     0.00830988]
   [ 0.00415...
[ 2019-08-21 15:11:18,012 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,012 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_19/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:18,012 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,012 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,012 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,014 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-1.51426113e+00  2.73546070e-01 -2.24737763e-01 -1.25644183e+00
 -2.72004426e-01  1.39551073e-01...
[ 2019-08-21 15:11:18,014 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,014 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_19/bottleneck_v1/conv2/weights/read/_117__cf__123
[ 2019-08-21 15:11:18,015 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,015 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,015 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,017 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-5.09289689e-02  1.07865809e-02 -3.13787581e-03 ... -4.40243594e-02
     1.76549125e-02 -2.60...
[ 2019-08-21 15:11:18,021 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,021 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_19/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:18,021 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,021 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,021 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,023 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.06277347  0.41370326 -0.39819002  1.1824706  -0.2500946  -0.6068819
  0.28107706 -0.05790341 ...
[ 2019-08-21 15:11:18,024 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,024 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_19/bottleneck_v1/conv3/weights/read/_112__cf__118
[ 2019-08-21 15:11:18,024 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,024 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,024 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,025 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-0.07311298 -0.05345644 -0.03690312 ...  0.12087156  0.11378829
    -0.02274548]
   [-0.00154...
[ 2019-08-21 15:11:18,025 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,025 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_19/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:18,025 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,025 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,026 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,026 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.17188254 -0.00495738 -0.67005384 ...  0.33126044  0.42149287
 -0.0539325 ]
[ 2019-08-21 15:11:18,026 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,026 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_20/bottleneck_v1/conv1/weights/read/_107__cf__113
[ 2019-08-21 15:11:18,026 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,026 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,027 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,027 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 3.09416908e-04 -1.87135395e-03 -2.97271907e-02 ... -5.38478186e-03
    -1.72796920e-02 -1.06...
[ 2019-08-21 15:11:18,027 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,027 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_20/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:18,028 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,028 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,028 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,029 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 8.14093053e-01 -1.01544037e-01 -3.43402445e-01 -5.67211151e-01
 -1.51276648e+00 -1.59439039e+00...
[ 2019-08-21 15:11:18,033 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,033 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_20/bottleneck_v1/conv2/weights/read/_102__cf__108
[ 2019-08-21 15:11:18,033 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,034 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,034 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,036 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[ 0.02033925 -0.05619948  0.02766515 ... -0.03943604 -0.02397275
     0.04895049]
   [-0.01205...
[ 2019-08-21 15:11:18,036 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,037 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_20/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:18,037 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,037 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,037 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,039 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 3.93973291e-01  6.75818443e-01  5.68278611e-01  4.82069731e-01
 -4.50898260e-01  2.63237834e-01...
[ 2019-08-21 15:11:18,039 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,039 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_20/bottleneck_v1/conv3/weights/read/_97__cf__103
[ 2019-08-21 15:11:18,039 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,040 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,040 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,040 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-0.08231747  0.02115379 -0.2575433  ... -0.06801777 -0.2339971
    -0.00444602]
   [ 0.180265...
[ 2019-08-21 15:11:18,041 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,041 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_20/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:18,041 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,041 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,041 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,042 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.15822881  0.21526286 -0.36310107 ...  0.14647907  0.02265519
  0.03741261]
[ 2019-08-21 15:11:18,045 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,045 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_21/bottleneck_v1/conv1/weights/read/_92__cf__98
[ 2019-08-21 15:11:18,045 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,046 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,046 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,046 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[ 1.13731390e-02 -8.37631896e-03  2.18193121e-02 ... -1.70757286e-02
    -3.48632387e-03  4.82...
[ 2019-08-21 15:11:18,047 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,047 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_21/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:18,047 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,047 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,047 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,049 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-7.42606819e-01 -8.55965793e-01 -9.54091966e-01 -1.24203396e+00
  9.21360254e-02 -8.59105825e-01...
[ 2019-08-21 15:11:18,049 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,050 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_21/bottleneck_v1/conv2/weights/read/_87__cf__93
[ 2019-08-21 15:11:18,050 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,050 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,050 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,052 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-2.01551933e-02 -5.34659764e-03 -8.06970801e-03 ...  8.18072446e-03
     5.55610226e-04 -3.48...
[ 2019-08-21 15:11:18,053 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,053 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_21/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:18,053 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,053 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,053 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,055 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-4.71896082e-01 -7.80885041e-01  4.65753019e-01 -2.56956518e-02
 -4.58646774e-01  4.05569375e-01...
[ 2019-08-21 15:11:18,057 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,057 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_21/bottleneck_v1/conv3/weights/read/_82__cf__88
[ 2019-08-21 15:11:18,057 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,057 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,057 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,058 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 0.00559025 -0.09025199  0.01876297 ...  0.05103797  0.04869816
     0.03763796]
   [-0.09497...
[ 2019-08-21 15:11:18,058 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,058 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_21/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:18,058 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,058 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,059 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,059 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.24008277  0.00148129 -0.72791934 ...  0.16210009 -0.10902369
  0.2810657 ]
[ 2019-08-21 15:11:18,059 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,059 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_22/bottleneck_v1/conv1/weights/read/_77__cf__83
[ 2019-08-21 15:11:18,059 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,059 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,060 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,060 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[-0.01313389  0.01255915 -0.00572969 ...  0.01309469  0.01282999
    -0.01747883]
   [-0.01413...
[ 2019-08-21 15:11:18,060 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,060 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_22/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:18,060 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,060 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,061 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,062 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-1.1755111  -0.5365908  -0.6500316  -1.0251931  -0.65722525  0.00882782
 -1.2013793  -0.2064715 ...
[ 2019-08-21 15:11:18,062 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,063 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_22/bottleneck_v1/conv2/weights/read/_72__cf__78
[ 2019-08-21 15:11:18,063 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,063 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,063 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,065 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[ 1.61153488e-02 -5.72048128e-02 -3.50767449e-02 ... -4.06095423e-02
     3.33643192e-03 -4.33...
[ 2019-08-21 15:11:18,068 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,068 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_22/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:18,068 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,068 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,069 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,070 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-7.92632163e-01  4.61506963e-01  2.20414937e-01  2.48360962e-01
 -1.55725062e-01  1.97303772e-01...
[ 2019-08-21 15:11:18,071 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,071 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_22/bottleneck_v1/conv3/weights/read/_67__cf__73
[ 2019-08-21 15:11:18,071 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,071 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,071 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,072 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[ 0.07055156 -0.12039565 -0.35282555 ...  0.02579648 -0.04902595
     0.04006082]
   [ 0.00324...
[ 2019-08-21 15:11:18,072 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,072 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_22/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:18,072 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,072 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,073 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,073 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [-0.2687049  -0.31173667 -0.408555   ...  0.32076246  0.6928656
  0.32638955]
[ 2019-08-21 15:11:18,073 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,073 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_23/bottleneck_v1/conv1/weights/read/_62__cf__68
[ 2019-08-21 15:11:18,073 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,074 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,074 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,074 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  256], value = [[[[-0.00247971 -0.00503684 -0.01485991 ... -0.00062311 -0.01903238
    -0.0019224 ]
   [ 0.00540...
[ 2019-08-21 15:11:18,074 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,074 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_23/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:18,075 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,075 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,075 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,077 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [-0.51112264  0.06879699 -0.13792351 -0.62954384 -1.1817067   0.62597656
 -0.5191443  -0.27764863...
[ 2019-08-21 15:11:18,080 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,080 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_23/bottleneck_v1/conv2/weights/read/_57__cf__63
[ 2019-08-21 15:11:18,080 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,080 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,080 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,083 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 256 256], value = [[[[-0.0214379   0.01323416  0.07162884 ... -0.00383878 -0.08694868
     0.04481691]
   [-0.05313...
[ 2019-08-21 15:11:18,083 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,083 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_23/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:18,084 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,084 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,084 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,086 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [256], value = [ 0.44861323  0.15291886 -0.6079556   0.37281704 -0.92528206  0.44079533
  0.00877315 -0.08752057...
[ 2019-08-21 15:11:18,086 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,086 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/block3/unit_23/bottleneck_v1/conv3/weights/read/_52__cf__58
[ 2019-08-21 15:11:18,086 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,086 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,086 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,087 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  256 1024], value = [[[[-0.0416985  -0.03404651 -0.05827026 ... -0.0467588  -0.04995513
    -0.02007625]
   [-0.01678...
[ 2019-08-21 15:11:18,087 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,087 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageFeatureExtractor/resnet_v1_101/resnet_v1_101/block3/unit_23/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:18,090 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,091 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,091 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,091 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1024], value = [ 0.7015135   0.79401284  0.58250046 ...  0.689971    0.8535386
 -0.50616866]
[ 2019-08-21 15:11:18,091 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,092 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_1/bottleneck_v1/conv1/weights/read/_46__cf__52
[ 2019-08-21 15:11:18,092 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,092 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,092 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,093 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024  512], value = [[[[-0.0100499   0.01746805  0.00606728 ... -0.01924445 -0.00484215
     0.00949551]
   [-0.00694...
[ 2019-08-21 15:11:18,093 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,093 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_1/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:18,093 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,093 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,093 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,097 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [-1.34813488e+00 -1.06322479e+00 -1.04872656e+00 -1.82214534e+00
  6.14979088e-01  4.64484334e-01...
[ 2019-08-21 15:11:18,097 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,097 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_1/bottleneck_v1/conv2/weights/read/_41__cf__47
[ 2019-08-21 15:11:18,097 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,097 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,097 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,100 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 512 512], value = [[[[ 2.55534449e-03 -4.48066220e-02 -1.98020437e-03 ...  1.18029548e-03
    -3.54787074e-02 -2.08...
[ 2019-08-21 15:11:18,102 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,102 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_1/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:18,102 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,103 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,103 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,106 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [-5.02341211e-01 -8.47730637e-02  1.24618411e-01  5.31149447e-01
  3.77969146e-02  2.97774673e-02...
[ 2019-08-21 15:11:18,106 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,107 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_1/bottleneck_v1/conv3/weights/read/_36__cf__42
[ 2019-08-21 15:11:18,107 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,107 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,107 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,108 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  512 2048], value = [[[[-1.1511395e-01  1.3495015e-01 -2.6494071e-01 ...  1.1587205e-01
    -3.2709050e-01  2.0824455...
[ 2019-08-21 15:11:18,108 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,108 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_1/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:18,108 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,108 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,109 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,109 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2048], value = [-0.04443729 -0.06957215 -0.40661395 ... -0.5239943  -0.35380042
  0.05741334]
[ 2019-08-21 15:11:18,109 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,109 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_1/bottleneck_v1/shortcut/weights/read/_549__cf__555
[ 2019-08-21 15:11:18,109 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,110 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,110 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,110 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 1024 2048], value = [[[[-0.04662284  0.10389034 -0.05344971 ... -0.00439417 -0.0560176
     0.00560989]
   [-0.095212...
[ 2019-08-21 15:11:18,110 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,111 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_1/bottleneck_v1/shortcut/Conv2D_bn_offset
[ 2019-08-21 15:11:18,114 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,114 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,115 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,115 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2048], value = [-1.0082258  -1.3967133  -0.27703083 ... -0.8050508  -1.117923
 -1.6318885 ]
[ 2019-08-21 15:11:18,115 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,115 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_2/bottleneck_v1/conv1/weights/read/_31__cf__37
[ 2019-08-21 15:11:18,115 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,116 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,116 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,116 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 2048  512], value = [[[[-0.00228747  0.00105643  0.00917423 ... -0.00156474  0.00991794
    -0.00409007]
   [-0.00853...
[ 2019-08-21 15:11:18,117 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,117 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_2/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:18,117 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,117 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,117 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,121 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [-1.98309660e-01  2.77836621e-01 -2.46522784e-01 -1.55009270e-01
  3.64018679e-01  2.51267672e-01...
[ 2019-08-21 15:11:18,121 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,121 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_2/bottleneck_v1/conv2/weights/read/_26__cf__32
[ 2019-08-21 15:11:18,121 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,122 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,122 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,124 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 512 512], value = [[[[-0.01245593 -0.02698608  0.02460378 ...  0.03418521  0.0137597
    -0.02065542]
   [-0.053296...
[ 2019-08-21 15:11:18,126 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,126 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_2/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:18,126 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,126 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,126 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,129 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [-3.63835156e-01  8.32627416e-02 -2.18970597e-01  6.34945631e-02
  1.18263602e-01  3.64442110e-01...
[ 2019-08-21 15:11:18,130 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,130 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_2/bottleneck_v1/conv3/weights/read/_21__cf__27
[ 2019-08-21 15:11:18,130 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,130 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,130 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,131 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  512 2048], value = [[[[-0.2368762  -0.4605358  -0.34834984 ... -0.03658137 -0.02586159
     0.02093196]
   [-0.28074...
[ 2019-08-21 15:11:18,131 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,131 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_2/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:18,131 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,132 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,132 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,132 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2048], value = [-1.0153909 -0.6674568 -0.875208  ... -1.103873  -1.3285267 -0.7974661]
[ 2019-08-21 15:11:18,132 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,133 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_3/bottleneck_v1/conv1/weights/read/_16__cf__22
[ 2019-08-21 15:11:18,133 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,133 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,133 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,134 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1 2048  512], value = [[[[-1.6256166e-03 -6.6833165e-03  1.7411307e-03 ... -4.5890920e-03
    -4.8535918e-03 -2.7233576...
[ 2019-08-21 15:11:18,136 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,137 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_3/bottleneck_v1/conv1/Conv2D_bn_offset
[ 2019-08-21 15:11:18,137 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,137 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,137 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,140 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [-8.50913644e-01 -9.37635899e-02 -2.53542960e-01 -3.17552984e-01
 -3.14328194e-01 -6.26975715e-01...
[ 2019-08-21 15:11:18,141 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,141 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_3/bottleneck_v1/conv2/weights/read/_11__cf__17
[ 2019-08-21 15:11:18,141 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,141 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,141 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,143 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  3   3 512 512], value = [[[[ 0.0489965  -0.01051994  0.0411143  ... -0.00541099 -0.01142978
     0.02437654]
   [ 0.09674...
[ 2019-08-21 15:11:18,144 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,144 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_3/bottleneck_v1/conv2/Conv2D_bn_offset
[ 2019-08-21 15:11:18,144 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,144 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,144 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,147 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [ 1.16400480e-01 -2.35121608e-01 -3.59815121e-01  2.66064703e-01
 -3.98253858e-01  1.24326885e-01...
[ 2019-08-21 15:11:18,148 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,148 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_3/bottleneck_v1/conv3/weights/read/_6__cf__12
[ 2019-08-21 15:11:18,148 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,148 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,148 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,149 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [   1    1  512 2048], value = [[[[ 0.02848594 -0.04761565 -0.19353807 ... -0.22083989 -0.18907347
    -0.05548693]
   [ 0.07501...
[ 2019-08-21 15:11:18,149 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,150 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageFeatureExtractor/resnet_v1_101/block4/unit_3/bottleneck_v1/conv3/Conv2D_bn_offset
[ 2019-08-21 15:11:18,150 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,150 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,150 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,150 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2048], value = [-1.1425788 -1.141293  -1.2837434 ... -1.3432276 -1.0777199 -1.3441148]
[ 2019-08-21 15:11:18,151 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,151 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageBoxPredictor/BoxEncodingPredictor/biases/read/_0__cf__6
[ 2019-08-21 15:11:18,151 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,151 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,151 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,154 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [360], value = [-7.95166474e-03  2.06766520e-02  2.64950842e-01  8.11876133e-02
  7.40765221e-03  7.21091777e-03...
[ 2019-08-21 15:11:18,154 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,154 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageBoxPredictor/BoxEncodingPredictor/weights/read/_1__cf__7
[ 2019-08-21 15:11:18,154 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,154 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,154 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,155 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2048  360], value = [[-2.3237381e-02 -2.8804217e-03  5.0827926e-03 ... -2.4562681e-02
   2.8157391e-02  5.0061975e-02...
[ 2019-08-21 15:11:18,155 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,155 ] [ DEBUG ] [ infer:130 ]  Partial infer for Conv/biases/read/_47__cf__53
[ 2019-08-21 15:11:18,155 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,155 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,155 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,159 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [512], value = [ 2.64190719e-04  1.88985479e-03  8.92485492e-04 -2.03493261e-03
 -1.33740180e-03 -2.03066436e-03...
[ 2019-08-21 15:11:18,159 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,159 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/BoxEncodingPredictor/biases/read/_518__cf__524
[ 2019-08-21 15:11:18,159 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,159 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,159 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,160 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [48], value = [ 0.03166837  0.00908974 -0.01960882 -0.02548007  0.0149476  -0.00241546
  0.00176654  0.02480716...
[ 2019-08-21 15:11:18,160 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,160 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/BoxEncodingPredictor/weights/read/_519__cf__525
[ 2019-08-21 15:11:18,160 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,160 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,161 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,161 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 512  48], value = [[[[ 0.11181056  0.00454487  0.12837438 ...  0.00214412  0.01436291
     0.02418564]
   [-0.01499...
[ 2019-08-21 15:11:18,161 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,161 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_2/ExpandedShape_1/ExpandDims/_520__cf__526
[ 2019-08-21 15:11:18,161 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,162 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,162 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,162 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:18,162 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,162 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_1/ExpandedShape_1/ExpandDims/_521__cf__527
[ 2019-08-21 15:11:18,162 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,162 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,163 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,163 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/strided_slice_3/_522__cf__528
[ 2019-08-21 15:11:18,163 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,163 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,163 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,163 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.0
[ 2019-08-21 15:11:18,163 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/strided_slice_2/_523__cf__529
[ 2019-08-21 15:11:18,164 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 16.0
[ 2019-08-21 15:11:18,164 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,164 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_1/ExpandedShape_1/ones/_524__cf__530
[ 2019-08-21 15:11:18,164 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,164 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,164 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,164 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,164 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_1/ExpandedShape/ExpandDims/_525__cf__531
[ 2019-08-21 15:11:18,165 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,165 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,165 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:18,165 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,165 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/strided_slice_5/_526__cf__532
[ 2019-08-21 15:11:18,165 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,165 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.0
[ 2019-08-21 15:11:18,166 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/strided_slice_4/_527__cf__533
[ 2019-08-21 15:11:18,166 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,166 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,166 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,166 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 16.0
[ 2019-08-21 15:11:18,166 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,166 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_1/ExpandedShape/ones/_528__cf__534
[ 2019-08-21 15:11:18,167 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,170 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,170 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,170 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_2/ExpandedShape_1/ones/_529__cf__535
[ 2019-08-21 15:11:18,170 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,170 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,170 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,171 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,171 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_2/ExpandedShape/concat/_530__cf__536
[ 2019-08-21 15:11:18,171 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,171 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,171 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,172 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [ 1  1 12]
[ 2019-08-21 15:11:18,172 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,172 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_2/Reshape/_531__cf__537
[ 2019-08-21 15:11:18,172 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,172 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,172 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,173 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [ 1  1 12], value = [[[ 45.25483   90.50966  181.01932  362.03864   63.999996 127.99999
   255.99998  511.99997   90....
[ 2019-08-21 15:11:18,173 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,173 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_3/ExpandedShape_1/ExpandDims/_532__cf__538
[ 2019-08-21 15:11:18,173 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,173 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,174 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,174 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:18,174 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,174 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_3/ExpandedShape_1/ones/_533__cf__539
[ 2019-08-21 15:11:18,174 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,174 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,175 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,175 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,175 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_3/ExpandedShape/concat/_534__cf__540
[ 2019-08-21 15:11:18,175 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,175 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,175 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,175 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [ 1  1 12]
[ 2019-08-21 15:11:18,176 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,176 ] [ DEBUG ] [ infer:130 ]  Partial infer for GridAnchorGenerator/Meshgrid_3/Reshape/_535__cf__541
[ 2019-08-21 15:11:18,176 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,176 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,176 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,176 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [ 1  1 12], value = [[[ 90.509674 181.01935  362.0387   724.0774    64.00001  128.00002
   256.00003  512.00006   45....
[ 2019-08-21 15:11:18,176 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/ClassPredictor/biases/read/_539__cf__545
[ 2019-08-21 15:11:18,177 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,177 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,177 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,177 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [24], value = [ 0.09504959 -0.09504911  0.0573867  -0.05738634  0.02511273 -0.02511258
 -0.02817237  0.02817235...
[ 2019-08-21 15:11:18,177 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,177 ] [ DEBUG ] [ infer:130 ]  Partial infer for FirstStageBoxPredictor/ClassPredictor/weights/read/_540__cf__546
[ 2019-08-21 15:11:18,180 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,181 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1   1 512  24], value = [[[[ 0.00296129 -0.02949508  0.00342768 ... -0.02782438  0.02513614
    -0.02138193]
   [-0.00872...
[ 2019-08-21 15:11:18,181 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,181 ] [ DEBUG ] [ infer:130 ]  Partial infer for Slice/begin/_541__cf__547
[ 2019-08-21 15:11:18,181 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,182 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,182 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,182 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:18,182 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,182 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageBoxPredictor/ClassPredictor/biases/read/_553__cf__559
[ 2019-08-21 15:11:18,182 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,183 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,183 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,184 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [91], value = [ 7.17917085e-01  5.80758825e-02 -9.27161542e-04  3.94133702e-02
 -8.60467833e-03 -1.22773387e-02...
[ 2019-08-21 15:11:18,184 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,184 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStageBoxPredictor/ClassPredictor/weights/read/_554__cf__560
[ 2019-08-21 15:11:18,184 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,184 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,185 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,185 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [2048   91], value = [[ 0.00950589  0.03144972 -0.06402664 ...  0.04240924  0.02076698
   0.03288592]
 [ 0.11044841 -0...
[ 2019-08-21 15:11:18,185 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,186 ] [ DEBUG ] [ infer:130 ]  Partial infer for SecondStagePostprocessor/Slice/begin/_555__cf__561
[ 2019-08-21 15:11:18,186 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,186 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,186 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,186 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:18,186 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,186 ] [ DEBUG ] [ infer:130 ]  Partial infer for image_tensor
[ 2019-08-21 15:11:18,186 ] [ DEBUG ] [ infer:131 ]  Op: Parameter
[ 2019-08-21 15:11:18,187 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,187 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,187 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [100 224 224   3], value = <UNKNOWN>
[ 2019-08-21 15:11:18,187 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,188 ] [ DEBUG ] [ infer:130 ]  Partial infer for ToFloat_3
[ 2019-08-21 15:11:18,188 ] [ DEBUG ] [ infer:131 ]  Op: Cast
[ 2019-08-21 15:11:18,188 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,188 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [100 224 224   3], value = <UNKNOWN>
[ 2019-08-21 15:11:18,188 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,188 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [100 224 224   3], value = <UNKNOWN>
[ 2019-08-21 15:11:18,188 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,191 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayUnstack/Shape
[ 2019-08-21 15:11:18,192 ] [ DEBUG ] [ infer:131 ]  Op: ShapeOf
[ 2019-08-21 15:11:18,192 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,192 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [100 224 224   3], value = <UNKNOWN>
[ 2019-08-21 15:11:18,192 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,192 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [4], value = [100 224 224   3]
[ 2019-08-21 15:11:18,193 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,193 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayUnstack/strided_slice
[ 2019-08-21 15:11:18,193 ] [ DEBUG ] [ infer:131 ]  Op: StridedSlice
[ 2019-08-21 15:11:18,194 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,194 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [4], value = [100 224 224   3]
[ 2019-08-21 15:11:18,194 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:18,194 ] [ DEBUG ] [ infer:32 ]  input[2]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,194 ] [ DEBUG ] [ infer:32 ]  input[3]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,195 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,195 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 100
[ 2019-08-21 15:11:18,195 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,195 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayUnstack/range
[ 2019-08-21 15:11:18,195 ] [ DEBUG ] [ infer:131 ]  Op: Range
[ 2019-08-21 15:11:18,195 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,196 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0
[ 2019-08-21 15:11:18,196 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = 100
[ 2019-08-21 15:11:18,196 ] [ DEBUG ] [ infer:32 ]  input[2]: shape = [], value = 1
[ 2019-08-21 15:11:18,196 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,196 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [100], value = [ 0  1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
 24 25 26 27 28 29 30 31...
[ 2019-08-21 15:11:18,196 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,197 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/Shape
[ 2019-08-21 15:11:18,197 ] [ DEBUG ] [ infer:131 ]  Op: ShapeOf
[ 2019-08-21 15:11:18,197 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,197 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [100 224 224   3], value = <UNKNOWN>
[ 2019-08-21 15:11:18,197 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,197 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [4], value = [100 224 224   3]
[ 2019-08-21 15:11:18,197 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,197 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/strided_slice
[ 2019-08-21 15:11:18,197 ] [ DEBUG ] [ infer:131 ]  Op: StridedSlice
[ 2019-08-21 15:11:18,198 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,198 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [4], value = [100 224 224   3]
[ 2019-08-21 15:11:18,199 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:18,199 ] [ DEBUG ] [ infer:32 ]  input[2]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,199 ] [ DEBUG ] [ infer:32 ]  input[3]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,199 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,199 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 100
[ 2019-08-21 15:11:18,199 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,199 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Less/Enter
[ 2019-08-21 15:11:18,199 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:18,200 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,202 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 100
[ 2019-08-21 15:11:18,202 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,203 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 100
[ 2019-08-21 15:11:18,203 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,203 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Less
[ 2019-08-21 15:11:18,203 ] [ DEBUG ] [ infer:131 ]  Op: Less
[ 2019-08-21 15:11:18,203 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,203 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,203 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = 100
[ 2019-08-21 15:11:18,203 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,203 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,204 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,204 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/LoopCond
[ 2019-08-21 15:11:18,204 ] [ DEBUG ] [ infer:131 ]  Op: LoopCond
[ 2019-08-21 15:11:18,204 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,204 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,204 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,204 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,204 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Switch
[ 2019-08-21 15:11:18,204 ] [ DEBUG ] [ infer:131 ]  Op: Switch
[ 2019-08-21 15:11:18,205 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,205 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,205 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,205 ] [ DEBUG ] [ infer:32 ]  output[1]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,205 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,205 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Identity
[ 2019-08-21 15:11:18,205 ] [ DEBUG ] [ infer:131 ]  Op: Identity
[ 2019-08-21 15:11:18,206 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,206 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,206 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,206 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,206 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,206 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/add/y
[ 2019-08-21 15:11:18,207 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,207 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,207 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,207 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1
[ 2019-08-21 15:11:18,207 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,207 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/add
[ 2019-08-21 15:11:18,207 ] [ DEBUG ] [ infer:131 ]  Op: Add
[ 2019-08-21 15:11:18,207 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,208 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = 1
[ 2019-08-21 15:11:18,208 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,208 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,208 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,208 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/NextIteration
[ 2019-08-21 15:11:18,208 ] [ DEBUG ] [ infer:131 ]  Op: NextIteration
[ 2019-08-21 15:11:18,208 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,208 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,209 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,209 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/ExpandDims/dim
[ 2019-08-21 15:11:18,209 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,209 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,209 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,209 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0
[ 2019-08-21 15:11:18,209 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice_3/stack_2
[ 2019-08-21 15:11:18,210 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,210 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,210 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice_3/stack_1
[ 2019-08-21 15:11:18,210 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,210 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,210 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,210 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [-1]
[ 2019-08-21 15:11:18,211 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,213 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,214 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:18,214 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,214 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/Const_2
[ 2019-08-21 15:11:18,214 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,214 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,214 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,215 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:18,215 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,215 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/Const_1
[ 2019-08-21 15:11:18,215 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,215 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,215 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,215 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1024.0
[ 2019-08-21 15:11:18,216 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/Const
[ 2019-08-21 15:11:18,216 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,216 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,216 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,216 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 600.0
[ 2019-08-21 15:11:18,216 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,216 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice_2/stack_2
[ 2019-08-21 15:11:18,217 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,217 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,217 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice_2/stack_1
[ 2019-08-21 15:11:18,217 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,217 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,217 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,217 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [3]
[ 2019-08-21 15:11:18,218 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,218 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,218 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:18,218 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,218 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice_1/stack_2
[ 2019-08-21 15:11:18,218 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,218 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,219 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,219 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice_1/stack_1
[ 2019-08-21 15:11:18,219 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,219 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,219 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,219 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [2]
[ 2019-08-21 15:11:18,220 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,220 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,220 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,220 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice/stack_2
[ 2019-08-21 15:11:18,220 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,220 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,221 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,221 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice/stack_1
[ 2019-08-21 15:11:18,221 ] [ DEBUG ] [ infer:131 ]  Op: Const
[ 2019-08-21 15:11:18,221 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,221 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,221 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,222 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [0]
[ 2019-08-21 15:11:18,225 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,225 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArray_2
[ 2019-08-21 15:11:18,225 ] [ DEBUG ] [ infer:131 ]  Op: TensorArrayV3
[ 2019-08-21 15:11:18,225 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,225 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 100
[ 2019-08-21 15:11:18,225 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,226 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = Preprocessor/map/TensorArray_2/Output_0/Data_
[ 2019-08-21 15:11:18,226 ] [ DEBUG ] [ infer:32 ]  output[1]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,226 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,226 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/TensorArrayWrite_1/TensorArrayWriteV3/Enter
[ 2019-08-21 15:11:18,226 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:18,226 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,227 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = Preprocessor/map/TensorArray_2/Output_0/Data_
[ 2019-08-21 15:11:18,227 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,227 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = Preprocessor/map/TensorArray_2/Output_0/Data_
[ 2019-08-21 15:11:18,227 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,227 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Enter_2
[ 2019-08-21 15:11:18,227 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:18,227 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,228 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,228 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,228 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,228 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,228 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Merge_2
[ 2019-08-21 15:11:18,228 ] [ DEBUG ] [ infer:131 ]  Op: Merge
[ 2019-08-21 15:11:18,228 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,228 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = <UNKNOWN>, value = <UNKNOWN>
[ 2019-08-21 15:11:18,229 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,229 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,229 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Switch_2
[ 2019-08-21 15:11:18,229 ] [ DEBUG ] [ infer:131 ]  Op: Switch
[ 2019-08-21 15:11:18,229 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,229 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,229 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,229 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,229 ] [ DEBUG ] [ infer:32 ]  output[1]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,230 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,230 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Identity_2
[ 2019-08-21 15:11:18,230 ] [ DEBUG ] [ infer:131 ]  Op: Identity
[ 2019-08-21 15:11:18,230 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,230 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,230 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,230 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,230 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArray_1
[ 2019-08-21 15:11:18,230 ] [ DEBUG ] [ infer:131 ]  Op: TensorArrayV3
[ 2019-08-21 15:11:18,231 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,231 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 100
[ 2019-08-21 15:11:18,231 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,231 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = Preprocessor/map/TensorArray_1/Output_0/Data_
[ 2019-08-21 15:11:18,231 ] [ DEBUG ] [ infer:32 ]  output[1]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,231 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,231 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/TensorArrayWrite/TensorArrayWriteV3/Enter
[ 2019-08-21 15:11:18,231 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:18,231 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = Preprocessor/map/TensorArray_1/Output_0/Data_
[ 2019-08-21 15:11:18,232 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,232 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = Preprocessor/map/TensorArray_1/Output_0/Data_
[ 2019-08-21 15:11:18,232 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,232 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Enter_1
[ 2019-08-21 15:11:18,232 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:18,232 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,232 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,232 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,233 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,236 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Merge_1
[ 2019-08-21 15:11:18,236 ] [ DEBUG ] [ infer:131 ]  Op: Merge
[ 2019-08-21 15:11:18,236 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,236 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,236 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = <UNKNOWN>, value = <UNKNOWN>
[ 2019-08-21 15:11:18,236 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,237 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,237 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,237 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Switch_1
[ 2019-08-21 15:11:18,237 ] [ DEBUG ] [ infer:131 ]  Op: Switch
[ 2019-08-21 15:11:18,237 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,237 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,237 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,237 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,238 ] [ DEBUG ] [ infer:32 ]  output[1]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,238 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,238 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/Identity_1
[ 2019-08-21 15:11:18,238 ] [ DEBUG ] [ infer:131 ]  Op: Identity
[ 2019-08-21 15:11:18,238 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,239 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,239 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,239 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,239 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,239 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArray
[ 2019-08-21 15:11:18,239 ] [ DEBUG ] [ infer:131 ]  Op: TensorArrayV3
[ 2019-08-21 15:11:18,239 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,240 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 100
[ 2019-08-21 15:11:18,240 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,240 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = Preprocessor/map/TensorArray/Output_0/Data_
[ 2019-08-21 15:11:18,240 ] [ DEBUG ] [ infer:32 ]  output[1]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,240 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,240 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/TensorArrayUnstack/TensorArrayScatter/TensorArrayScatterV3
[ 2019-08-21 15:11:18,240 ] [ DEBUG ] [ infer:131 ]  Op: TensorArrayScatterV3
[ 2019-08-21 15:11:18,241 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,241 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = Preprocessor/map/TensorArray/Output_0/Data_
[ 2019-08-21 15:11:18,241 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [100], value = [ 0  1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
[ 2019-08-21 15:11:18,242 ] [ DEBUG ] [ infer:32 ]  input[2]: shape = [100 224 224   3], value = <UNKNOWN>
[ 2019-08-21 15:11:18,242 ] [ DEBUG ] [ infer:32 ]  input[3]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,242 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,242 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,242 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,242 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/TensorArrayReadV3/Enter_1
[ 2019-08-21 15:11:18,242 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:18,242 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,242 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,243 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,243 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,243 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,243 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/TensorArrayReadV3/Enter
[ 2019-08-21 15:11:18,243 ] [ DEBUG ] [ infer:131 ]  Op: Enter
[ 2019-08-21 15:11:18,243 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,243 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = Preprocessor/map/TensorArray/Output_0/Data_
[ 2019-08-21 15:11:18,243 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = Preprocessor/map/TensorArray/Output_0/Data_
[ 2019-08-21 15:11:18,244 ] [ DEBUG ] [ infer:131 ]  Op: TensorArrayReadV3
[ 2019-08-21 15:11:18,244 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,244 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = Preprocessor/map/TensorArray/Output_0/Data_
[ 2019-08-21 15:11:18,244 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,244 ] [ DEBUG ] [ infer:32 ]  input[2]: shape = [], value = <UNKNOWN>
[ 2019-08-21 15:11:18,244 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,244 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [224 224   3], value = <UNKNOWN>
[ 2019-08-21 15:11:18,244 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,244 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/ExpandDims
[ 2019-08-21 15:11:18,244 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:18,248 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,248 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [224 224   3], value = <UNKNOWN>
[ 2019-08-21 15:11:18,249 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:18,249 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,249 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [  1 224 224   3], value = <UNKNOWN>
[ 2019-08-21 15:11:18,249 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,250 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/Shape
[ 2019-08-21 15:11:18,250 ] [ DEBUG ] [ infer:131 ]  Op: ShapeOf
[ 2019-08-21 15:11:18,250 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,250 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [224 224   3], value = <UNKNOWN>
[ 2019-08-21 15:11:18,250 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,251 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [3], value = [224 224   3]
[ 2019-08-21 15:11:18,251 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,251 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice_2
[ 2019-08-21 15:11:18,251 ] [ DEBUG ] [ infer:131 ]  Op: StridedSlice
[ 2019-08-21 15:11:18,252 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,252 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [3], value = [224 224   3]
[ 2019-08-21 15:11:18,252 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [2]
[ 2019-08-21 15:11:18,253 ] [ DEBUG ] [ infer:32 ]  input[2]: shape = [1], value = [3]
[ 2019-08-21 15:11:18,253 ] [ DEBUG ] [ infer:32 ]  input[3]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,253 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,253 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 3
[ 2019-08-21 15:11:18,253 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,253 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/stack_2/ExpandDims_1156412424
[ 2019-08-21 15:11:18,254 ] [ DEBUG ] [ infer:131 ]  Op: Unsqueeze
[ 2019-08-21 15:11:18,254 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,254 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 3
[ 2019-08-21 15:11:18,255 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:18,255 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,255 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [1], value = [3]
[ 2019-08-21 15:11:18,255 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,255 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice_1
[ 2019-08-21 15:11:18,255 ] [ DEBUG ] [ infer:131 ]  Op: StridedSlice
[ 2019-08-21 15:11:18,256 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,259 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [3], value = [224 224   3]
[ 2019-08-21 15:11:18,259 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,259 ] [ DEBUG ] [ infer:32 ]  input[2]: shape = [1], value = [2]
[ 2019-08-21 15:11:18,259 ] [ DEBUG ] [ infer:32 ]  input[3]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,259 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,259 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 224
[ 2019-08-21 15:11:18,260 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,260 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/ToFloat_1
[ 2019-08-21 15:11:18,260 ] [ DEBUG ] [ infer:131 ]  Op: Cast
[ 2019-08-21 15:11:18,260 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,260 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 224
[ 2019-08-21 15:11:18,261 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,261 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 224.0
[ 2019-08-21 15:11:18,261 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,261 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/strided_slice
[ 2019-08-21 15:11:18,261 ] [ DEBUG ] [ infer:131 ]  Op: StridedSlice
[ 2019-08-21 15:11:18,262 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,262 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [3], value = [224 224   3]
[ 2019-08-21 15:11:18,263 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [1], value = [0]
[ 2019-08-21 15:11:18,263 ] [ DEBUG ] [ infer:32 ]  input[2]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,263 ] [ DEBUG ] [ infer:32 ]  input[3]: shape = [1], value = [1]
[ 2019-08-21 15:11:18,263 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,263 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 224
[ 2019-08-21 15:11:18,263 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,263 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/ToFloat
[ 2019-08-21 15:11:18,264 ] [ DEBUG ] [ infer:131 ]  Op: Cast
[ 2019-08-21 15:11:18,264 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,264 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 224
[ 2019-08-21 15:11:18,264 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,264 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 224.0
[ 2019-08-21 15:11:18,264 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,264 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/Maximum
[ 2019-08-21 15:11:18,264 ] [ DEBUG ] [ infer:131 ]  Op: Maximum
[ 2019-08-21 15:11:18,265 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 224.0
[ 2019-08-21 15:11:18,265 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = 224.0
[ 2019-08-21 15:11:18,265 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,265 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 224.0
[ 2019-08-21 15:11:18,265 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,265 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/div_1/reciprocal_
[ 2019-08-21 15:11:18,265 ] [ DEBUG ] [ infer:131 ]  Op: Pow
[ 2019-08-21 15:11:18,265 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,266 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 224.0
[ 2019-08-21 15:11:18,266 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = -1.0
[ 2019-08-21 15:11:18,266 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,266 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 0.004464285714285714
[ 2019-08-21 15:11:18,266 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,266 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/div_1/mul_
[ 2019-08-21 15:11:18,266 ] [ DEBUG ] [ infer:131 ]  Op: Mul
[ 2019-08-21 15:11:18,267 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,269 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 0.004464285714285714
[ 2019-08-21 15:11:18,270 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = 1024.0
[ 2019-08-21 15:11:18,270 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,270 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 4.571428571428571
[ 2019-08-21 15:11:18,270 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,270 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/mul_3
[ 2019-08-21 15:11:18,270 ] [ DEBUG ] [ infer:131 ]  Op: Mul
[ 2019-08-21 15:11:18,270 ] [ DEBUG ] [ infer:142 ]  Inputs:
[ 2019-08-21 15:11:18,270 ] [ DEBUG ] [ infer:32 ]  input[0]: shape = [], value = 224.0
[ 2019-08-21 15:11:18,271 ] [ DEBUG ] [ infer:32 ]  input[1]: shape = [], value = 4.571428571428571
[ 2019-08-21 15:11:18,271 ] [ DEBUG ] [ infer:144 ]  Outputs:
[ 2019-08-21 15:11:18,271 ] [ DEBUG ] [ infer:32 ]  output[0]: shape = [], value = 1024.0
[ 2019-08-21 15:11:18,271 ] [ DEBUG ] [ infer:129 ]  --------------------
[ 2019-08-21 15:11:18,271 ] [ DEBUG ] [ infer:130 ]  Partial infer for Preprocessor/map/while/ResizeToRange/Round_3
[ 2019-08-21 15:11:18,271 ] [ DEBUG ] [ infer:131 ]  Op: Round
[ INFO ]  Called "tf_native_tf_node_infer" for node "Preprocessor/map/while/ResizeToRange/Round_3"
[ 2019-08-21 15:11:18,273 ] [ DEBUG ] [ tf:222 ]  Added placeholder with name 'Preprocessor/map/while/ResizeToRange/mul_3_port_0_ie_placeholder'
[ 2019-08-21 15:11:18,273 ] [ DEBUG ] [ tf:235 ]  update_input_in_pbs: replace input 'Preprocessor/map/while/ResizeToRange/mul_3' with input 'Preprocessor/map/while/ResizeToRange/mul_3_port_0_ie_placeholder'
[ 2019-08-21 15:11:18,273 ] [ DEBUG ] [ tf:243 ]  Replacing input '0' of the node 'Preprocessor/map/while/ResizeToRange/Round_3' with placeholder 'Preprocessor/map/while/ResizeToRange/mul_3_port_0_ie_placeholder'
[ ERROR ]  Cannot infer shapes or values for node "Preprocessor/map/while/ResizeToRange/Round_3".
[ ERROR ]  graph_def is invalid at node 'Preprocessor/map/while/ResizeToRange/Round_3': Input tensor 'Preprocessor/map/while/ResizeToRange/mul_3_port_0_ie_placeholder:0' Cannot convert a tensor of type float64 to an input of type float32.
[ ERROR ]
[ ERROR ]  It can happen due to bug in custom shape infer function <function tf_native_tf_node_infer at 0x00000135DE6381E0>.
[ ERROR ]  Or because the node inputs have incorrect values/shapes.
[ ERROR ]  Or because input shapes are incorrect (embedded to the model or passed via --input_shape).
[ 2019-08-21 15:11:18,286 ] [ DEBUG ] [ infer:196 ]  Node "Preprocessor/map/while/ResizeToRange/Round_3" attributes: {'pb': name: "Preprocessor/map/while/ResizeToRange/Round_3"
op: "Round"
input: "Preprocessor/map/while/ResizeToRange/mul_3_port_0_ie_placeholder"
attr {
  key: "T"
  value {
    type: DT_FLOAT
, '_in_ports': {0: {'control_flow': False}}, '_out_ports': {0: {'control_flow': False}}, 'kind': 'op', 'name': 'Preprocessor/map/while/ResizeToRange/Round_3', 'op': 'Round', 'precision': 'FP32', 'infer': <function tf_native_tf_node_infer at 0x00000135DE6381E0>, 'is_output_reachable': True, 'is_undead': False, 'is_const_producer': False, 'is_partial_inferred': False}
[ ERROR ]  Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.middle.PartialInfer.PartialInfer'>): Stopped shape/value propagation at "Preprocessor/map/while/ResizeToRange/Round_3" node.
 For more information please refer to Model Optimizer FAQ (https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_Model_Optimizer_FAQ.html), question #38.
[ 2019-08-21 15:11:18,290 ] [ DEBUG ] [ main:308 ]  Traceback (most recent call last):
  File "C:\Users\GF63\.conda\envs\tf_1.14\lib\site-packages\tensorflow\python\framework\importer.py", line 402, in import_graph_def
    op._add_input(source_tensor, dtype=input_type)
  File "C:\Users\GF63\.conda\envs\tf_1.14\lib\site-packages\tensorflow\python\framework\ops.py", line 1741, in _add_input
    (tensor.dtype.name, dtype.name))
TypeError: Cannot convert a tensor of type float64 to an input of type float32
During handling of the above exception, another exception occurred:
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\middle\passes\infer.py", line 132, in partial_infer
    node.infer(node)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\front\tf\partial_infer\tf.py", line 60, in tf_native_tf_node_infer
    tf_subgraph_infer(tmp_node)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\front\tf\partial_infer\tf.py", line 135, in tf_subgraph_infer
    all_constants, output_tensors = get_subgraph_output_tensors(node)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\front\tf\partial_infer\tf.py", line 115, in get_subgraph_output_tensors
    tf.import_graph_def(graph_def, name='')
  File "C:\Users\GF63\.conda\envs\tf_1.14\lib\site-packages\tensorflow\python\framework\importer.py", line 406, in import_graph_def
    node, 'Input tensor %r %s' % (input_name, te)))
ValueError: graph_def is invalid at node 'Preprocessor/map/while/ResizeToRange/Round_3': Input tensor 'Preprocessor/map/while/ResizeToRange/mul_3_port_0_ie_placeholder:0' Cannot convert a tensor of type float64 to an input of type float32.
The above exception was the direct cause of the following exception:
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\utils\class_registration.py", line 273, in apply_replacements
    for_graph_and_each_sub_graph_recursively(graph, replacer.find_and_replace_pattern)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\middle\pattern_match.py", line 58, in for_graph_and_each_sub_graph_recursively
    func(graph)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\extensions\middle\PartialInfer.py", line 31, in find_and_replace_pattern
    partial_infer(graph)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\middle\passes\infer.py", line 198, in partial_infer
    refer_to_faq_msg(38)) from err
mo.utils.error.Error: Stopped shape/value propagation at "Preprocessor/map/while/ResizeToRange/Round_3" node.
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\main.py", line 302, in main
    return driver(argv)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\main.py", line 251, in driver
    is_binary=not argv.input_model_is_text)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\pipeline\tf.py", line 134, in tf2nx
    class_registration.apply_replacements(graph, class_registration.ClassType.MIDDLE_REPLACER)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\utils\class_registration.py", line 293, in apply_replacements
    )) from err
mo.utils.error.Error: Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.middle.PartialInfer.PartialInfer'>): Stopped shape/value propagation at "Preprocessor/map/while/ResizeToRange/Round_3" node.
(tf_1.14) C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\install_prerequisites>
Shubha_R_Intel
Dear Kulkarni, Vinay,
Glad to see that you've upgraded to OpenVino 2019R2.
Kindly choose a faster-rcnn model from the Model Optimizer Tensorflow Supported List. I can tell you that most of your errors are coming straight from Tensorflow and Model Optimizer is simply passing them along. So in other words, the below error has nothing to do with Model Optimizer:
I think the version of the model you've chosen doesn't work.
Hope it helps,
Shubha
Kulkarni__Vinay
Thanks Shubha.
I did upgrade the tensorflow version to 1.13 and got the .pb from file pointed by you.
File taken from http://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_convert_model_Convert_Model_From_TensorFlow.html:
File name :Faster R-CNN ResNet 101 COCO
.pb file :  faster_rcnn_resnet101_coco_2018_01_28.tar.gz
But still getting error as follows:
(tyqi_tf) C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\install_prerequisites>python ..\mo.py --input_model  D:\Openvino\faster_rcnn_resnet101_coco_2018_01_28\faster_rcnn_resnet101_coco_2018_01_28\frozen_inference_graph.pb --input_shape (1,224,224,3) --output_dir D:\Openvino\
Model Optimizer arguments:
Common parameters:
        - Path to the Input Model:      D:\Openvino\faster_rcnn_resnet101_coco_2018_01_28\faster_rcnn_resnet101_coco_2018_01_28\frozen_inference_graph.pb
        - Path for generated IR:        D:\Openvino\
        - IR output name:       frozen_inference_graph
        - Log level:    ERROR
        - Batch:        Not specified, inherited from the model
        - Input layers:         Not specified, inherited from the model
        - Output layers:        Not specified, inherited from the model
        - Input shapes:         (1,224,224,3)
        - Mean values:  Not specified
        - Scale values:         Not specified
        - Scale factor:         Not specified
        - Precision of IR:      FP32
        - Enable fusing:        True
        - Enable grouped convolutions fusing:   True
        - Move mean values to preprocess section:       False
        - Reverse input channels:       False
TensorFlow specific parameters:
        - Input model in text protobuf format:  False
        - Path to model dump for TensorBoard:   None
        - List of shared libraries with TensorFlow custom layers implementation:        None
        - Update the configuration file with input/output node names:   None
        - Use configuration file used to generate the model with Object Detection API:  None
        - Operations to offload:        None
        - Patterns to offload:  None
        - Use the config file:  None
Model Optimizer version:        2019.2.0-436-gf5827d4
[ ERROR ]  Input 0 of node Preprocessor/map/while/ResizeToRange/Round_3 was passed double from Preprocessor/map/while/ResizeToRange/mul_3_port_0_ie_placeholder:0 incompatible with expected float.
[ ERROR ]
[ ERROR ]  It can happen due to bug in custom shape infer function <function tf_native_tf_node_infer at 0x000002D11B07BEA0>.
[ ERROR ]  Run Model Optimizer with --log_level=DEBUG for more information.
Shubha_R_Intel
The error is because you're not quite passing in the right command-line arguments to mo_tf.py. The below document will tell you how to do it correctly.
MO converting Tensorflow Object Detection API
Hope it helps,
Shubha
