6584 Discussions
Follow up on issue #350: Can not run ncappzoo in Raspberry Pi
KKar01
Hello, I wanted to use make run to run model in Raspberry Pi I followed instructions given on issue #350 and corrected the PYTHONPATH, Now it can find mo.py file, buy it seems it is unable to find 20180408-102900.bin, '20180408-102900.xml, which is understandable as RaspberryPI does not have model optimizer in it.  AS you can see the directory has 20180408-102900..pb,  I then took the 20180408-102900.pb file and wanted to convert using my LInux machine but found error  - which  opened up another ticket.
Can you please suggest what I am doing wrong.
CONTENT OF VIDEO_FACE_MATCHER
pi@raspberrypi:~/build/ncappzoo/apps/video_face_matcher $ ls
20180408-102900.pb Face_profile.py model-20180408-102900.ckpt-90.index My_network.py screen_shot.png
AUTHORS Makefile model-20180408-102900.meta Person_profile.py validated_faces
Face_detection_results.py model-20180408-102900.ckpt-90.data-00000-of-00001 mo.py README.md video_face_matcher.py
ERROR WHEN MAKE RUN
pi@raspberrypi:~/build/ncappzoo/apps/video_face_matcher $ sudo make run
video_face_matcher: Downloading required data for model...
mkdir -p validated_faces; \
(cd validated_faces; mkdir -p Trump; cd Trump; wget -c --no-cache -P . https://raw.githubusercontent.com/nealvis/media/master/face_pics/trump.jpg)
--2020-01-22 11:04:53-- https://raw.githubusercontent.com/nealvis/media/master/face_pics/trump.jpg
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.184.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.184.133|:443... connected.
HTTP request sent, awaiting response... 416 Range Not Satisfiable
The file is already fully retrieved; nothing to do.
video_face_matcher: Compiling the model to IR...
- Making Facenet IRs in Facenet project.
make[1]: Entering directory '/home/pi/build/ncappzoo/networks/facenet'
facenet: Making model zoo...
(cd ../../omz; make all;)
make[2]: Entering directory '/home/pi/build/ncappzoo/omz'
open_model_zoo: Checking requirements...
Checking pyyaml...
- pyyaml already installed.
open_model_zoo: Making dependencies...
open_model_zoo: Downloading required data...
Open model zoo already exists. No need to clone.
make[2]: Leaving directory '/home/pi/build/ncappzoo/omz'
facenet: Checking zoo model files...
- Model files already exists.
facenet: Compiling model to IR...
Checking OpenVINO environment...
Please initiate the Intel OpenVINO environment by going to the installation directory for openvino and running the setupvars.sh file in the bin folder.
make[1]: *** [Makefile:68: compile_model] Error 1
make[1]: Leaving directory '/home/pi/build/ncappzoo/networks/facenet'
- Copying IRs to project folder...
cp: cannot stat '20180408-102900.bin': No such file or directory
cp: cannot stat '20180408-102900.xml': No such file or directory
make: *** [Makefile:40: compile_default_model] Error 1
RandallMan_B_Intel
Thank you for reaching out.
We recommend you look at this section and follow the steps to add the Model Optimizer to Raspberry Pi. Also, we recommend you to check the Model Downloader that is already included in OpenVINO.
As another step, please run the following script to temporarily set the environment variables:
source /opt/intel/openvino/bin/setupvars.sh
Randall B.
