Hi ,
I was trying to run the yolox build for openvino.
https://github.com/Megvii-BaseDetection/YOLOX/blob/main/demo/OpenVINO/cpp/yolox_openvino.cpp
The build was completed and tried to infer the model in GPU of the device. Getting error in this stage.
Was compiled in openvino - 2022.3.1-9227-cf2c7da5689-releases/2022/3
both CPU and GPU inferencing was fine.
Build system info:
Processor 13th Gen Intel(R) Core(TM) i7-13800H, 2500 Mhz, 14 Core(s), 20 Logical Processor(s)
Intel UHD graphics
when I try to run the windows application in the system with processor Intel(R) Core(TM) i3-6100U CPU @ 2.30GHz, 2304 Mhz, 2 Core(s), 4 Logical Processor(s) with Intel HD graphics, GPU inferencing is not possible stating the following error:
| 1 error generated. |
| 8:3274:2: error: implicit declaration of function 'intel_sub_group_block_write_us' is invalid in OpenCL |
| 8:3205:46: note: expanded from macro 'OUTPUT_BLOCK_WRITE' |
| 8:290:2: note: expanded from macro 'BLOCK_WRITEN' |
| 8:284:2: note: expanded from macro 'BLOCK_WRITEN_RAW' |
The openvino version in the run system - 2022.3.0-9052-9752fafe8eb-releases/2022/3
Hi Gayathri_Sankar an,
Thanks for reaching out.
The error is related to OpenCL kernel. The Intel® Core™ i3-6100U Processor GPU does not support OpenCL. Meanwhile, Intel® Core™ i7-13800H Processor GPU supporting OpenCL.
Aznie
Hi Gayathri_Sankaran,
This thread will no longer be monitored since we have provided information. If you need any additional information from Intel, please submit a new question.
Aznie
