6577 Discussions
Graph contains a cycle. Can not proceed. Version. [2019.2.0-436-gf5827d4]
Anjam__Khayam
Hi, I came across this error while trying to optimize a frozen model using OpenVINO,
Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.middle.CheckForCycle.CheckForCycle'>): Graph contains a cycle. Can not proceed.
 For more information please refer to Model Optimizer FAQ (https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_Model_Optimizer_FAQ.html), question #97.
I tested my .pb model with tensorboard and they are no cycles. My model is as following,
model.add(tf.keras.layers.LSTM(units=50,  input_shape=(X.shape[1],2)))
model.add(tf.keras.layers.Dense(units=1))
model.compile(optimizer='adam', loss='mean_squared_error', metrics=['accuracy'])
model.summary()
history = model.fit(X, y, epochs=500, batch_size=32, verbose=1)
 This is how I am running the optimizer
!python3 {mo_tf_path} --input_model {pb_file} --output_dir {output_dir} --input_shape {input_shape_str} --data_type FP32
What could be wrong here? I came across this which points to a bug in mo_tf utility. Is this issue related to that?
Any help is much appreciated. I have also attached the .pb file in a compressed zip file.
Shubha_R_Intel
Dearest Anjam, Khayam,
According to what I saw in Tensorboard (see attached *.png) I definitely see a cycle. Look at the far right side of the graph starting with strided_slice. I see a closed loop.
Let me know your thoughts,
Shubha
Anjam__Khayam
Thanks for the response but I dont think that is a cycle. Isn't a cycle means if we start from strided_slice, there is a way to get back to it? I don't see loops or bidirectional links here. Can you elaborateit a bit more?
Shubha_R_Intel
Maybe in the strictest sense that is not a real directed graph cycle. But it does form a closed loop. Let me ask you this, please do a --log_level DEBUG. What node does Model Optimizer complain about with "Graph contains a cycle. Can not proceed. " ? If it is the same node as what I posted above in the tensorboard snippet, then you have your answer. If it's some other node which it complains about we can fire up Tensorboard and investigate further.
Let me know,
Shubha
