'Graph' object has no attribute 'node'
VBura
 Hi, Someone please help. Every time I am trying to run model optimizer to create .xml and .bin files I keep getting the same error.
Command used :
python3 ./mo_tf.py --input_model /home/venku/movidius/facenet/20180408-102900/20180408-102900.pb --freeze_placeholder_with_value "phase_train->False"
   - IR output name:   20180408-102900
   - Log level:   ERROR
   - Batch:   Not specified, inherited from the model
   - Input layers:   Not specified, inherited from the model
   - Output layers:   Not specified, inherited from the model
   - Input shapes:   Not specified, inherited from the model
   - Mean values:   Not specified
   - Scale values:   Not specified
   - Scale factor:   Not specified
   - Precision of IR:   FP32
   - Enable fusing:   True
   - Enable grouped convolutions fusing:   True
   - Move mean values to preprocess section:   False
   - Reverse input channels:   False
TensorFlow specific parameters:
   - Input model in text protobuf format:   False
   - Path to model dump for TensorBoard:   None
   - List of shared libraries with TensorFlow custom layers implementation:   None
   - Update the configuration file with input/output node names:   None
   - Use configuration file used to generate the model with Object Detection API:   None
   - Operations to offload:   None
   - Patterns to offload:   None
   - Use the config file:   None
Model Optimizer version:   2019.3.0-375-g332562022
/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/dtypes.py:516: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
 _np_qint8 = np.dtype([("qint8", np.int8, 1)])
/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/dtypes.py:517: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
 _np_quint8 = np.dtype([("quint8", np.uint8, 1)])
/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/dtypes.py:518: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
 _np_qint16 = np.dtype([("qint16", np.int16, 1)])
/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/dtypes.py:519: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
 _np_quint16 = np.dtype([("quint16", np.uint16, 1)])
/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/dtypes.py:520: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
 _np_qint32 = np.dtype([("qint32", np.int32, 1)])
/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/dtypes.py:525: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
 np_resource = np.dtype([("resource", np.ubyte, 1)])
/usr/local/lib/python3.5/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:541: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.5/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:542: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.5/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:543: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.5/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:544: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.5/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:545: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.5/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:550: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
[ ERROR ] 'Graph' object has no attribute 'node'
Cannot pre-process TensorFlow graph after reading from model file "/home/venku/movidius/facenet/20180408-102900/20180408-102900.pb". File is corrupt or has unsupported format. Details: 'Graph' object has no attribute 'node'.
 For more information please refer to Model Optimizer FAQ (https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_Model_Optimizer_FAQ.html), question #44.
JAVIERJOSE_A_Intel
Hi VBura,
There may be a compatibility issue with the networkx package. Could you try and install version 2.3 using the command "pip3 install networkx==2.3". Try to run the demo again and let me know if it works.
Javier A.
Intel Customer Support Technician
A Contingent Worker at Intel
VBura
Hi Javier, yes that was the issue. After downgrading netwokx to 2.3 I am able move forward without any issues. Thank you Javier.
Venku
JAVIERJOSE_A_Intel
I am glad that it solved your issue, I am going to proceed to close this thread.
Javier A.
