6594 Discussions
Guidance for Compiling TensorFlow Model Zoo Networks
hello
in another discussion ,i know that if i want to infer a image and get the num of item in this image,i need ssd or yolo model,so i go to TensorFlow ,and then i got a ssd_mobilenet_v1_coco_2018_01_28.tar.gz , i need to compile it to graph file for my movidius,I'm successful , i got graph and labels file, but when i use these files to my program , it always get error back : output ,userobj = fifoout.read_elem() ,output[0] is 0 . i think this graph only result one item like inception_v1
so i want to know , did i use right model? if not ,can you show me how to get it?
is there anyone have same problem? how you fix it?
this is where model from
https://github.com/tensorflow/models/blob/master/research/object_detection/g3doc/detection_model_zoo.md
this is how to compile
https://movidius.github.io/ncsdk/tf_modelzoo.html
thank you
i checked api again , and i found movidius can not use TensorFlow ssd_mobilenet , i'm going to try make TensorFlow model to caffe model…
