6597 Discussions
Gvametapublish with mqtt causing pytho error segmentation fault
KarthickM
DLStreamer version : dlstreamer:2022.3.0-ubuntu22-gpu555
Inferencing device - CPU only
We have been facing a Fatal Python error: Segmentation fault crash issue when gvametapublish with the following parameters in our pipeline while trying to start and stop multiple pipelines.
gvametapublish address=localhost:1883 topic=inferenceEvent method=mqtt
Please note that the crash backtrace does not give current-thread trace which makes it difficult to debug the issue.
We tried only gvametapublish without the mqtt method and did not see the above crash.
Have me missed any parameters or any suggestions to resolve the issue.
Warm Regards,
Karthick
Iffa_Intel
Hi, could you share your use case details for us to replicate?:
  1. Steps that you did to infer/etc till the point of error
  2. Relevant neural network model files
  3. Relevant custom code (if any)
Cordially,
Iffa
KarthickM
Hi Iffa,
We are working on the custom code where we can reproduce the issue. I will share it with you ASAP.
Warm Regards,
Karthick
Iffa_Intel
Noted, looking forward to it.
Cordially,
Iffa
Iffa_Intel
do you still need help regarding this issue?, else I'll proceed for closure.
Cordially,
Iffa
KarthickM
Hi Iffa,
So far we have not been able to reproduce the issue in our custom code. We can close it for now, and I will re-open when I have the code ready.
Thank you.
Warm Regards,
Karthick
Iffa_Intel
I'll proceed to closure then.
Thank you for your question. If you need any additional information from Intel, please submit a new question as Intel is no longer monitoring this thread.
Cordially,
Iffa
