6587 Discussions
Unable to upload dataset on intel DL workbench
SakshamSharma__2
I'm uploading pascalVOC2008 dataset, but I'm unable to fully upload it, it keeps failing before upload is able to complete
Also, The filesize is 550mb
Labels (3)
Aznie_Intel
Hi SakshamSharma__2,
Thanks for reaching out.
For your information, DL Workbench supports only the format of the VOC validation datasets published in 2007, 2010, and 2012. Moreover, if the dataset size is big, you have to cut the dataset when loading it into the DL Workbench.
You may refer to this Pascal Visual Object Classes (Pascal VOC) from OpenVINO documentation.
Aznie
Aznie_Intel
Aznie
Aznie_Intel
Hi ShakShamSharma__2,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Aznie
