6597 Discussions
Is the licensing folder itself redistributable?
anony
Is the following licensing folder itself redistributable?
\openvino_2021.4.752\licensing
The environment and the version of openvino you are using are windows, c++, openvino2021lts as per the question below
Re:Is there a table that summarizes these possible third party licenses? - Intel Communities
Also where is the license regarding the license file?
Munesh_Intel
Hello anony,
Thanks for your query.
We are checking with the relevant team, and will get back to you at the earliest.
Munesh
Munesh_Intel
Hello anony,
We’ve obtained reply from the relevant team.
Yes, the licensing folder is redistributable.
For your second question, the LICENSE file was provided from Intel® Distribution of OpenVINO™ toolkit version 2022.2 onwards. The contents of the LICENSE file is the same as Apache_license.txtFor Intel® Distribution of OpenVINO™ toolkit version 2021.4.752, a separate LICENSE file was not included. However, Apache_license.txt was included and is located at C:\Program Files (x86)\Intel\openvino_2021.4.752\licensing\deployment_tools .
Munesh
Munesh_Intel
Hello anony,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Munesh
