HDDL Error
AustinM
I'm running openVino 2019.1.144 on an HPE Edgeline Movidius Myriad X VPU Module using HDDL and am experiencing a crash after running inference for about 10 minutes. The same code ran indefinitely on earlier versions of openVino.
The error that starts the app shutting down is:
[HDDLPlugin] [10:57:27.3385][27233]ERROR[HddlClient.cpp:728] Error: wait InferTaskSync(reqSeqNo=3 taskId=142853) result timeout failed.
Any help with the reason for this as well as a fix would be greatly appreciated.
-Austin
AustinM
Never mind, I found the problem. I was using some older libraries in my code, once I updated them to the latest ones from the OpenVino distribution the problems went away.
Shubha_R_Intel
Dear AustinM,
I'm glad you were successful. Thanks for reporting your findings to the OpenVino community !
Shubha
