HRNetV2C1 Conversion from .pth to IR
Norrie
Hello, I am using the HRNetV2C1 model for inference on a ROS2 Humble AMR with Intel NUC13 (OS: Ubuntu 22.04).
I am using ROS2 Openvino Toolkit (-b ros2) to load the model in the .xml format, and it has been working without errors.
However, after training the model on Google Colab in the PyTorch framework and converting the trained model, A) directly into the IR format, or B) first into ONNX and then into the IR format, I get the same error when loading the model (conversion process itself completes without errors):
[pipeline_with_params-5] [ ERROR ] Exception from src/inference/src/core.cpp:99:
[pipeline_with_params-5] Check '(axis_range_min <= axis) && (axis <= axis_range_max)' failed at src/core/src/validation_util.cpp:1121:
[pipeline_with_params-5] Gather Parameter axis -6260240599907491525 out of the tensor rank range [-1, 0].
Given that this error appears in both A) and B) scenarios, I suspect that the conversion process from .pth to .onnx has some flaws.
Could you identify potential causes for this in the following script?
Thank you very much!
A) Direct conversion:
from google.colab import drive
drive.mount('/content/drive')
# Install openvino package
%pip install -q "openvino>=2023.3.0" onnx
import torch
import sys
import openvino as ov
from pathlib import Path
# Adjust sys.path to include the path to your HRNetV2C1 model implementation
sys.path.append('/content/drive/Shareddrives/PSOL/open_model_zoo/models/public/hrnet-v2-c1-segmentation')
sys.path.append('/content/drive/Shareddrives/PSOL/hrnet-models/hrnet-v2-c1-segmentation')
sys.path.append('/content/drive/Shareddrives/PSOL/hrnet-models/hrnet-v2-c1-segmentation/mit_semseg')
from model import HrnetV2C1
# Initialize the model
model = HrnetV2C1(encoder_weights='/content/drive/Shareddrives/PSOL/hrnet-models/hrnet-v2-c1-segmentation/ckpt/encoder_epoch_30.pth',
decoder_weights='/content/drive/Shareddrives/PSOL/hrnet-models/hrnet-v2-c1-segmentation/ckpt/decoder_epoch_30.pth')
# Load the trained weights
weights_path = "/content/drive/Shareddrives/PSOL/preprocessed/best_model_weights.pth"
model.load_state_dict(torch.load(weights_path, map_location=torch.device('cpu')))
# Set the model to evaluation mode
model.eval()
# Define a dummy input tensor. The size might need to be adjusted based on your model's input.
example_input = torch.randn(1, 3, 320, 320)
ov_model = ov.convert_model(model, example_input=example_input)
ov_ir_path = Path("/content/drive/Shareddrives/PSOL/preprocessed/")
ov_ir_path.mkdir(parents=True, exist_ok=True)
# Save the OpenVINO model
ov.save_model(ov_model, ov_ir_path / "hrnet-v2-c1.xml")
print(f"OpenVINO model was saved successfully to {ov_ir_path}")
B) Into ONNX, then into IR:
import time
import os
import sys
import warnings
import cv2
import numpy as np
import torch
import onnx
IMAGE_WIDTH = 320
IMAGE_HEIGHT = 320
# Paths where ONNX and OpenVINO IR models will be stored.
onnx_path = '/content/drive/Shareddrives/PSOL/preprocessed/model.onnx'
ir_path = "/content/drive/Shareddrives/PSOL/preprocessed/hrnet-v2-c1-segmentation.xml"
# Model weights
# Model network
# Load the trained weights into the model
# Move the model to the GPU if available
model.eval()
with warnings.catch_warnings():
    warnings.filterwarnings("ignore")
    dummy_input = torch.randn(1, 3, IMAGE_HEIGHT, IMAGE_WIDTH)
    torch.onnx.export(
    model,
    dummy_input,
    onnx_path,
    print(f"ONNX model exported to {onnx_path}.")
# Load the ONNX model
onnx_model = onnx.load(onnx_path)
# Check the model
onnx.checker.check_model(onnx_model)
print("The model is checked and valid.")
if os.path.exists(onnx_path) and os.path.getsize(onnx_path) > 0:
    print("ONNX model file exists and is not empty.")
else:
    print("ONNX model file does not exist or is empty.")
ov_model = ov.convert_model(onnx_path)
ov.save_model(ov_model, ir_path)
Wan_Intel
Hi Norrie,
Could you please share the custom HRNetV2C1 model with us so that we can further investigate the issue from our end?
Wan
Norrie
Hello Wan,
Sorry, it was my fundamental mistake.
In the param file of ROS2 OpenVINO Toolkit, the model file is specified by referring only to the .xml file.
That is why I kept updating only the .xml file and caused mismatch between that and the .bin file in the same folder, which is apparently automatically found and read by the ROS2 node.
After replacing both the .xml and .bin files, the trained model was normally loaded without any error.
Please close the issue, and I'm sorry for disturbing you with such a blunder.
Norrie
Wan_Intel
Hi Norrie,
Thanks for the information.
We're glad to know that you have solved the issue. If you need additional information from Intel, please submit a new question and we'll be happy to help.
Wan
Hance
In Ubuntu22.04, how can ROS2 Humble be connected to OpenVINO so that ROS2 can be used to call the motion model
Hance
