6614 Discussions
The reason why the first interference time is slow
darkpilia
Hello.
When I measure the inference time of the model I am testing, the first inference time is measured very slowly, and this measurement does not seem to be included in the latency value.
I wonder why the first inference time is slow and why this value is not included in the mean value of latency value.
The test log is as follows.
Thank you.
(python_310) css@sapphire:~/workspace/Resnet/src$ benchmark_app -m model.xml -d CPU -shape [2,2,100,32] -ip f16 -nthreads 1 -hint none
[Step 1/11] Parsing and validating input arguments
[ INFO ] Parsing input parameters
[Step 2/11] Loading OpenVINO Runtime
[ INFO ] OpenVINO:
[ INFO ] Build ................................. 2024.3.0-16041-1e3b88e4e3f-releases/2024/3
[ INFO ]
[ INFO ] Device info:
[ INFO ] CPU
[ INFO ]
[ INFO ]
[Step 3/11] Setting device configuration
[Step 4/11] Reading model files
[ INFO ] Loading model files
[ INFO ] Read model took 5.64 ms
[ INFO ] Original model I/O parameters:
[ INFO ] Model inputs:
[ INFO ] input (node: input) : bf16 / [...] / [?,2,100,32]
[ INFO ] Model outputs:
[ INFO ] output (node: output) : bf16 / [...] / [?,2,100,32]
[Step 5/11] Resizing model to match image sizes and given batch
[ INFO ] Model batch size: 2
[ INFO ] Reshaping model: 'input': [2,2,100,32]
[ INFO ] Reshape model took 0.57 ms
[Step 6/11] Configuring input of the model
[ INFO ] input (node: input) : f16 / [N,C,H,W] / [2,2,100,32]
[ INFO ] output (node: output) : bf16 / [...] / [2,2,100,32]
[Step 7/11] Loading the model to the device
[ INFO ] Compile model took 33.16 ms
[Step 8/11] Querying optimal runtime parameters
[ INFO ] Model:
[ INFO ] NETWORK_NAME: main_graph
[ INFO ] OPTIMAL_NUMBER_OF_INFER_REQUESTS: 1
[ INFO ] NUM_STREAMS: 1
[ INFO ] INFERENCE_NUM_THREADS: 1
[ INFO ] PERF_COUNT: NO
[ INFO ] INFERENCE_PRECISION_HINT: <Type: 'bfloat16'>
[ INFO ] PERFORMANCE_HINT: LATENCY
[ INFO ] EXECUTION_MODE_HINT: ExecutionMode.PERFORMANCE
[ INFO ] PERFORMANCE_HINT_NUM_REQUESTS: 0
[ INFO ] ENABLE_CPU_PINNING: True
[ INFO ] SCHEDULING_CORE_TYPE: SchedulingCoreType.ANY_CORE
[ INFO ] MODEL_DISTRIBUTION_POLICY: set()
[ INFO ] ENABLE_HYPER_THREADING: False
[ INFO ] EXECUTION_DEVICES: ['CPU']
[ INFO ] CPU_DENORMALS_OPTIMIZATION: False
[ INFO ] LOG_LEVEL: Level.NO
[ INFO ] CPU_SPARSE_WEIGHTS_DECOMPRESSION_RATE: 1.0
[ INFO ] DYNAMIC_QUANTIZATION_GROUP_SIZE: 32
[ INFO ] KV_CACHE_PRECISION: <Type: 'float16'>
[ INFO ] AFFINITY: Affinity.CORE
[Step 9/11] Creating infer requests and preparing input tensors
[ WARNING ] No input files were given for input 'input'!. This input will be filled with random values!
[ INFO ] Fill input 'input' with random values
[Step 10/11] Measuring performance (Start inference asynchronously, 1 inference requests, limits: 60000 ms duration)
[ INFO ] Benchmarking in inference only mode (inputs filling are not included in measurement loop).
[ INFO ] First inference took 2.07 ms
[Step 11/11] Dumping statistics report
[ INFO ] Execution Devices:['CPU']
[ INFO ] Count: 109716 iterations
[ INFO ] Duration: 60000.89 ms
[ INFO ] Latency:
[ INFO ] Median: 0.53 ms
[ INFO ] Average: 0.53 ms
[ INFO ] Min: 0.52 ms
[ INFO ] Max: 1.39 ms
[ INFO ] Throughput: 3657.15 FPS
Peh_Intel
Hi darkpilia,
I tried running benchmark_app with two Intel Pre-trained models, face-detection-0200 and age-gender-recognition-retail-0013 models as the testing purpose. From both results, the first inference time is in the range of minimum and maximum value.
As such, could you try running the benchmark_app again with your custom model?
Peh
Peh_Intel
Hi darkpilia,
We have not heard back from you. Thank you for your question. If you need any additional information from Intel, please submit a new question as Intel is no longer monitoring this thread.
Peh
