Have video output open in full screen
JVond
I'd like the video output for a script to appear full screen with no manipulation upon opening.  How do I modify the command to make this happen.
This is on a raspberry pi running buster.
SIRIGIRI_V_Intel
Hi James,
To display the video output in full screen mode, Use the following commands
For C++:
cv::namedWindow("Detection results", cv::WND_PROP_FULLSCREEN);
cv::setWindowProperty("Detection results", cv::WND_PROP_FULLSCREEN, cv::WINDOW_FULLSCREEN);
cv::imshow("Detection results", frame);
For Python:
cv2.namedWindow("Detection results", cv2.WND_PROP_FULLSCREEN)
cv2.setWindowProperty("Detection results", cv2.WND_PROP_FULLSCREEN, cv2.WINDOW_FULLSCREEN)
cv2.imshow("Detection results", frame)
Hope this helps.
Ram prasad
JVond
Where does that go for the C++ script?  I can't edit it in the text editor...
Luis_at_Intel
Hi Vondale, James,
May I ask which C++ script are you modifying?
It could be that you need Administrator (or sudo access in Linux) to make changes to the script.
Luis
JVond
security_barrier_camera_demo.
It's not an admin issue.   It shows a bunch of gibberish characters in the text editor.
I don't usually use c++ so perhaps I'm missing a required step.
Luis_at_Intel
Please share the path and file extension of the script you are modifying. Since you are using the Raspberry Pi, the actual sample code should be under "<path-to>/open_model_zoo/demos/security_barrier_camera_demo".
Once you edit and add your changes to main.cpp, you may need to re-build the sample (under "<path-to>/open_model_zoo/demos/build" run "make security_barrier_camera_demo").
Luis
JVond
I run it from~/open_model_zoo/demos/build/armv7l/Release
I'll mess with the main.cpp file where you suggeted...
JVond
Your code didn't work, but I did find where the size is determined and matched it to my screen resolution.  Now comes out well.
I did not find the same spot in the crossroad demo, however..
Luis_at_Intel
Hi Vondale, James,
Edit the main.cpp file under ~/open_model_zoo/demos/crossroad_camera_demo and include these lines code after line #817:
Don't forget to rebuilt the sample for changes to take effect, as previously mentioned, under "~/open_model_zoo/demos/build" run "make crossroad_camera_demo"). I have tested this and seems to be working fine, please give it a try.
Luis
