6594 Discussions
Having different calculation result between cpu and npu with nan, inf op.
WilsonChen0723
Hi.
I'm having different results for the same calculation with different processing units.
And it will result in precision error in the final.
Result using NPU
-- out_0132__model_dep_encoder_Resize_NPU.npy
(0,1, 8, 0) [ nan, inf, 0.206299, 0.40625,
(0,1,11, 0) [ -inf, nan, 0.136963, 0.171631,
Result using CPU
-- out_0132__model_dep_encoder_Resize_CPU.npy
(0,1, 8, 0) [ 0.313762, 0.260029, 0.206297, 0.406028,
(0,1,11, 0) [ 0.005915, 0.0714487, 0.136982, 0.171628,
Attached files :
- model_input_n_output.zip : models, input npy, the output npy for the CPU, NPU.
- openvino_benchmark_app_src.zip : In order to save the result into npy, we made some changes to the benchmark_app source code(0_before : origin file、1_after : with fix)
- benchmark_app_custom_result_log.txt : The executing log for benchmark_app
Please help, thank you.
Hairul_Intel
Hi WilsonChen0723,
We noticed from your log text file that you're using OpenVINO version 2023.1.0.
As such, please install the latest OpenVINO 2023.2 version through the OpenVINO archives on the download page and see if the issue is resolved.
Furthermore, please do share your device information (CPU, Operating System, etc.) with us.
Hairul
Hairul_Intel
Hi WilsonChen0723,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Hairul
WilsonChen0723
CPU : Intel® Core™ Ultra 5 processor 135H
OS : Windows 11 enterprise.
■ 2023.2
(0,1, 8, 0)    [          nan,       -273.75,      0.206299,       0.40625,
(0,1,11, 0)    [          inf,           nan,      0.136963,      0.171631,
■ 2023.1
