6577 Discussions
Hello, first question == how can we get the detection speed (fps)
Just received the new toy, loaded latest dev kit, plugged it in and launched d the python example :
python stream_infer.py
Are there parameters we can set to show stats about detection speed ?
It is running on a MELE PGC03 Minicomputer
Intel® Celeron(R) CPU N3450 @ 1.10GHz × 4
UBUNTU 16.04LTS
So far , so good :smiley:
Here it is , on the "defective" port:
[ 3180.618033] usb 1-7: new high-speed USB device number 27 using xhci_hcd
[ 3180.759102] usb 1-7: New USB device found, idVendor=03e7, idProduct=2150
[ 3180.759109] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3180.759114] usb 1-7: Product: Movidius MA2X5X
[ 3180.759118] usb 1-7: Manufacturer: Movidius Ltd.
[ 3180.759122] usb 1-7: SerialNumber: 03e72150
patrick@UBUNTU-MELE:~/workspace/mvncsdk/ncapi/c_examples$ ./ncs-check -1
OpenDevice 7 failed, rc=-2
patrick@UBUNTU-MELE:~/workspace/mvncsdk/ncapi/c_examples$ dmesg | tail
[ 3200.149462] usb 1-7: USB disconnect, device number 27
[ 3200.477987] usb 2-4: new SuperSpeed USB device number 8 using xhci_hcd
[ 3200.498962] usb 2-4: New USB device found, idVendor=040e, idProduct=f63b
[ 3200.498968] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3200.498972] usb 2-4: Product: USBVSC
[ 3200.498976] usb 2-4: Manufacturer: Movidius
[ 3200.498980] usb 2-4: SerialNumber: DATAC
It is doing it on just one USB3 Port, I suspect this is related to the Minicomputer
Looks like our posts crossed, I'll post my question just in case other members stop by this post:
@patrickpoirier can you please copy-paste the New USB device found and New USB device strings lines after you get the error? Also, try to unplug the NCS, re-plug, and run ncs-check again.
@patrickpoirier Are you still having issues running ./ncs-check -1?
I had the error on a USB3 port and I switched to a USB2 port and now its OK.
I have 2 other USB3 ports but the MOVIDIUS is interferencing with the antenna.. I will need an extension to check if its related to this particular port or USB3 Type.
I<ll keep you updated.
