Here is the error that I hit when trying to use any of the TF slim model to get the frozen .pb model. This timeout error is seen for any model in Slim that is suggested in OpenVino documentation. Any clue why this timeout been hit?
(C:\Anaconda3) C:\Intel\computer_vision_sdk_2018.2.299\temp\TF_SlimLibrary\models\research\slim>python export_inference_graph.py --alsologtostderr --model_name=VGG_16 --image_size=224 --output_file=/tmp/VGG_16.pb
File "C:\Anaconda3\lib\urllib\request.py", line 1318, in do_open
encode_chunked=req.has_header('Transfer-encoding'))
File "C:\Anaconda3\lib\http\client.py", line 1239, in request
self._send_request(method, url, body, headers, encode_chunked)
File "C:\Anaconda3\lib\http\client.py", line 1285, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "C:\Anaconda3\lib\http\client.py", line 1234, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "C:\Anaconda3\lib\http\client.py", line 1026, in _send_output
self.send(msg)
File "C:\Anaconda3\lib\http\client.py", line 964, in send
self.connect()
File "C:\Anaconda3\lib\http\client.py", line 1392, in connect
super().connect()
File "C:\Anaconda3\lib\http\client.py", line 936, in connect
(self.host,self.port), self.timeout, self.source_address)
File "C:\Anaconda3\lib\socket.py", line 722, in create_connection
raise err
File "C:\Anaconda3\lib\socket.py", line 713, in create_connection
sock.connect(sa)
TimeoutError: [WinError 10060] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond
During handling of the above exception, another exception occurred:
File "export_inference_graph.py", line 124, in <module>
tf.app.run()
File "C:\Anaconda3\lib\site-packages\tensorflow\python\platform\app.py", line 48, in run
_sys.exit(main(_sys.argv[:1] + flags_passthrough))
File "export_inference_graph.py", line 108, in main
FLAGS.dataset_dir)
File "C:\Intel\computer_vision_sdk_2018.2.299\temp\TF_SlimLibrary\models\research\slim\datasets\dataset_factory.py", line 57, in get_dataset
reader)
File "C:\Intel\computer_vision_sdk_2018.2.299\temp\TF_SlimLibrary\models\research\slim\datasets\imagenet.py", line 188, in get_split
labels_to_names = create_readable_names_for_imagenet_labels()
File "C:\Intel\computer_vision_sdk_2018.2.299\temp\TF_SlimLibrary\models\research\slim\datasets\imagenet.py", line 94, in create_readable_names_for_imagenet_labels
filename, _ = urllib.request.urlretrieve(synset_url)
File "C:\Anaconda3\lib\urllib\request.py", line 248, in urlretrieve
with contextlib.closing(urlopen(url, data)) as fp:
File "C:\Anaconda3\lib\urllib\request.py", line 223, in urlopen
return opener.open(url, data, timeout)
File "C:\Anaconda3\lib\urllib\request.py", line 526, in open
response = self._open(req, data)
File "C:\Anaconda3\lib\urllib\request.py", line 544, in _open
'_open', req)
File "C:\Anaconda3\lib\urllib\request.py", line 504, in _call_chain
result = func(*args)
File "C:\Anaconda3\lib\urllib\request.py", line 1361, in https_open
context=self._context, check_hostname=self._check_hostname)
File "C:\Anaconda3\lib\urllib\request.py", line 1320, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [WinError 10060] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond>
Hi Mariam,
this is an issue with your proxy. You should use on Windows before calling the script:
set https_proxy=yourproxyhere:port
set http_proxy=yourproxyhere:port
Best,
Severine
Topic Options
