6605 Discussions
How can I download older openvino versions?
emregun
I want to install an older version of openvino(2020.1,2019_R3.1 etc.) as a workaround for a bug which I found in a forum, but unfortunately even all older version links (like https://docs.openvinotoolkit.org/2020.3/index.html,)
links me back to main installation:
https://software.intel.com/content/www/us/en/develop/tools/openvino-toolkit/download.html
I would be grateful for a reply.
Thanks a lot in advance.
Munesh_Intel
Hi Emregun,
Thank you for contacting us.
Intel® Distribution of OpenVINO™ Toolkit is available for download at the following page:
Fill in the options for Operating System (OS), Distribution, and Installer Type. Clicking the Register & Download button will bring you to the next page, given here:
https://software.seek.intel.com/openvino-toolkit?os=windows
Please fill in the required details. Clicking Submit button will bring you to the Download page, where you'll be given your serial number. You can choose the required version from the “Choose a Version” dropdown menu. You can also select the download option in this page.
Please get back to us should you face any difficulty in downloading Intel® Distribution of OpenVINO™ Toolkit.
Munesh
sphrz
If I remember correctly if you download the SDK online as a .tar file right before you download 2021.x you can specify which version you want to download instead (this is after the registration), it is a drop down. Just a side note, I am unsure if I was doing something wrong but I also wanted to download an older version too some time ago. When you do, the Inference Engine is gone from the download from pervious versions. Not sure if that is still the case but depending on what you are trying to do it could hinder your progress if you find yourself needing it. You can try and see if it is also missing when you try and install the SDK through the GUI.
Munesh_Intel
Hi Emregun,
Munesh
Munesh_Intel
Hi Emregun,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Munesh
