6584 Discussions
How can I use the output from Graph.GetResult() in order to show image with all detections boxes?
As you can see in the attached screen shot the output from this function (GetResuls) is an array with length 5070 . Please if someone can help me understand what is the meaning of this output and how can I use those points to show the detection bounding boxes. thanks for all :)
@veredpoz, I am guessing you are working with either TinyYOLO or MobileNet SSD. The output array format depends on which of the two networks you are using. You can see a description of the format here:
MobileNet SSD: https://github.com/movidius/ncappzoo/blob/master/caffe/SSD_MobileNet/run.py#L50
TinyYOLO: https://github.com/movidius/ncappzoo/blob/master/caffe/TinyYolo/run.py#L22
If you are working on MobileNet SSD, I have created a utility wrapper that formats the output array into a Python dictionary. Try it out and let me know if it helps.
Sample app: https://github.com/ashwinvijayakumar/ncappzoo/tree/detector-template/apps/ssd-object-detector
Utility wrapper: https://github.com/ashwinvijayakumar/ncappzoo/blob/detector-template/apps/ssd-object-detector/utils/deserialize_output.py
@AshwinVijayakumar Thanks Ashwin,
  1. I am using Tiny-Yolo V2 through darkflow transform written in tensorflow. I trained it to detect a single object class. How to change the example given in
    TinyYOLO: https://github.com/movidius/ncappzoo/blob/master/caffe/TinyYolo/run.py#L22 to work with a single class?
  2.
  3. Is it possible to compile Mobilenet-SSD written in tensorflow?
  4.
@veredpoz For our version of Tiny Yolo, the inference result can be interpreted as in my post https://ncsforum.movidius.com/discussion/comment/2172/#Comment_2172.
@Tome_at_Intel
  1. Thank you for your response. my problam is that I get much more outputs, so that output[1078:] contains 4802 parameters and it can't be converted the shape of (7,7,2,4).
  2.
  3. How can I use the code you have attached for one class only? I get output of 5880 length.
  4.
@veredpoz Where did you get this model from? The size of the output can vary depending on how many anchor/prior boxes you specify and how many grid cells you have. I believe ours is a 7x7 grid with 2 bounding boxes per grid cell.
Yes, I took the same model, but I trained it on my own dataset and I only have one class so I changed the amount of filters in the final layer to 30
