6605 Discussions
How to attach iGPU into OVMS service in docker-compose configuration file
Aqil-ITXOTIC
I try to run OVMS as a service in docker-compose, but i don't know how to attach iGPU. So far i run OVMS as a separate service outside from docker-compose. It would be great if my docker-compose can start all its service without need to run one specific server outside from it.
Here is the screenshot of the OVMS part in my docker-compose file configuration.
Wan_Intel
Hi Aqil-ITXOTIC,
Are you trying to attach iGPU into OpenVINO™ Model Server in docker-compose configuration file on Windows?
On another note, if you are trying to attach iGPU into OpenVINO™ Model Server in docker-compose configuration file on Ubuntu, please use the following command:
devices:
  - "/dev/dri"
Wan
Aqil-ITXOTIC
Hi Wan,
Thank you for your response. Unfortunately i tried what you said, and it doesn't work. That's why it was commented out in my screenshot. I don't know what happen, the OVMS doesn't detect my iGPU, only CPU and GNA, when i enable OVMS inside docker-compose.yaml file.
Hence this force me to disable it from my docker-compose and run it separately.
Here is the information showed when OVMS is integrated in docker-compose (ofc by putting what you said, attach dev/dri) :
And this is the separate script i wrote to up OVMS (and put it in same network of other containers i'm running) :
By running this way, it does detect iGPU.
For your further information, i am running Ubuntu 22.04 with Kernel 5.17-oem (with latest Intel Graphic Driver), processor Intel® Core™ i5-1135G7.
The models i'm running, i run it on target-device "AUTO" mode, so that Openvino will pick the best devices for inferencing a video stream that i feed into.
For me, it just an inconvenient way to run my application with this way, docker-compose up for all containers necessary except OVMS, which have to run separately.
Looking forward for your response and your assistance.
Wan_Intel
Hi Aqil-ITXOTIC,
Thanks for your information.
For your information, I've validated the command above as shown as follows:
We regret that the command above doesn't work on your machine. I've escalated this to our next level and we'll update you as soon as possible.
Wan
Wan_Intel
Hi Aqil-ITXOTIC,
Thanks for your patience.
We regret to inform you that we're unable to replicate your issue because we're able to attach iGPU in OpenVINO™ Model Server with configuration file via docker compose. Sorry for the inconvenience.
Wan
Wan_Intel
Hi Aqil-ITXOTIC,
If you need additional information from Intel, please submit a new question as this thread will no longer be monitored.
Wan
