Reading the network and loading it into an executable network takes from 3 to 11 seconds for me, depending on the device. But for my application, I may need to restart my program multiple times and I can't afford this much overhead.
So how can I shorten the time needed for this?
P.S: I also tested exporting the exec_net and then importing it, but importing of the network seems to take even a longer time.
Hi Hesam,
In order to shorten the load time, I would suggest you compile the IR model into blob file and then import blob file instead of IR model. Just a disclaimer that not all IR models can be compiled into blob file.
You may refer to this article:
Loading a Model on Vision Processing Unit (VPU) May take Longer than Loading on CPU
Peh
Hi Hesam,
This thread will no longer be monitored since we have provided suggestion. If you need any additional information from Intel, please submit a new question.
Peh
![](/skins/images/D2683F18326913BBA0436CB7114DD569/responsive_peak/images/icon_anonymous_message.png)
