How to create json and config file for custom model?
RAHUL
I have .pb model file, now how can I generate config and json file so that I can convert it to xml and bin file. I am using below command.
python3 mo_tf.py --input_model=model.pb --transformations_config *** --tensorflow_object_detection_api_pipeline_config **** --reverse_input_channels
Thanks in advance
SuryaPSC_Intel
Hi Rahul,
Please follow the steps for freezing the custom model and then Convert Tensorflow model to IR.
Surya
RAHUL
Hi Surya, I am already following the link you mentioned. Actually example models can be successfully converted to xml using above command but problem is with custom model for that I don't have json and config file. Without these files I cannot optimize my tf object detection model.
SuryaPSC_Intel
Hi Rahul,
OpenVINO provides .json files for some standard models which you may refer to generate your own .json file. You may find the .json files at the below directory in windows.
C:\Program Files (x86)\IntelSWTools\openvino_2020.1.033\deployment_tools\model_optimizer\extensions\front\tf
Surya
