6605 Discussions
How to detect the suppored device in openvino
Yixiong__Feng
In openVINO, when create the plugin for a device like GPU, how to check the current system support it or not without loading the network?
Zhen_Z_Intel
Hello Yixiong,
You can use following command to check the type and version of your graphics in Linux:
lspci -k | grep -EA3 'VGA|3D|Display'
And in our product release note, it described that OpenVINO supports 6th - 8th Generation Intel® Core™/Xeon™ processors with Intel® Iris® Pro graphics and Intel® HD Graphics
Fiona
__om__
Hi Fiona,
is there any way to check this from C++ application without issuing system call?
E.g to check VPU (Movidius) availability it's enough to call ncDeviceCreate function of libmyriadPlugin.so.
Is there any similar way to check if existing GPU (clDNN) can be used for inferencing?
Yixiong__Feng
Hi Fiona:
how to do this check in openvino python api?
serg
Any solution?
I need to decide, while app starts, show or not some functionality depend of GPU...
