6605 Discussions
libcpu_extension_avx2.so No such file or directory Error
Jeff__Liao
Hi everyone,
I try to run sample code with AVX2, but I cannot find any "libcpu_extension_avx2.so" file
Intel OpenVINO Tutorial Videos ( https://www.youtube.com/watch?v=fPPcYeFbmiA&list=PLDKCjIU5YH6jMzcTV5_cxX9aPHsborbXQ&index=43 ) 4:38
  • OS : Windows 10 home
  • OpenVINO : 2019.3.379
AVX2, SSE4.2 and AVX512 are supported on my CPU.
How can I get the 'libcpu_extension_avx2.so' file?
or how to use it ?
Thanks!!!
JAIVIN_J_Intel
Hi Liao,
Since you are using Windows, you can find the cpu extension dll file from:
openvino_2019.3.379\deployment_tools\inference_engine\bin\intel64\Release\cpu_extension_avx2.dll
The OpenVINO Tutorial Video is demonstrated on Linux OS.
Also, you can install the latest version of OpenVINO (2020.1) where CPU extensions library was removed as they were moved into the plugin.
Jaivin
JAIVIN_J_Intel
Hi Liao,
Jaivin
DarkHorse
Hello Liao,
I come across this topic, I need to run a face detection model from github and it needs to have this cpu_extension_avx2.dll. I am using OpenVINO 2020 R4, can you show me the path where is this file located in?
Thanks for the help.
