while installing openvinotoolkit, I encounter so many problems. I am trying to install openvinotoolkit for the past week, but I couldn't able to install the .system requirement I followed all the prerequisites procedures but I still couldn't, and showing a dll load error, please solve this issue.
Hi Mukesh2,
We noticed that you've created a virtual environment.
May I know which version of the OpenVINO™ toolkit have you installed on the machine?
Wan
openvino 2022.3, As Guidelines mentioned in intell I did everything ad even I contacted one of the AI developers in intel, she simply told had some issues. I try for a week, I am so passionate to work with the Openvino toolkit so please give me the solution
Hi Mukesh2,
Thanks for your information.
Please follow the steps as follow to install Intel® Distribution of OpenVINO™ Toolkit.
- Uninstall existing Intel® Distribution of OpenVINO™ Toolkit runtime package via Uninstalling the Intel® Distribution of OpenVINO™ Toolkit.
- Remove existing Intel® Distribution of OpenVINO™ Toolkit Development Tools virtual environment.
- Follow Install OpenVINO™ Runtime on Windows from an Archive File.
Please get back to us if you faced any issues.
Wan
yeah I tried to install openvino from archieve file, I installed file in a specific directory but while configuring the environment I encounters errors like setupvars.bat I can't able to run it and open vino 2022 is not opening.I shared following errors i faced below
Hi Mukesh2,
Referring to the screenshots, could you please check the article here and re-install OpenVINO™ Toolkit?
Next, could you please share your environment details with us?
- Operating System
- Python version
Wan
Hi Mukesh2,
Thanks for your question.
Please submit a new question if additional information is needed as this thread will no longer be monitored.
Wan
Intel Customer Support
