How to package openvio into exe
GangXiong
openvino version:2020.4.287
device: GPU
When I executed the exe file packaged by pyinstaller, the following errors occurred:
Traceback (most recent call last):
File "main.py", line 8, in from DeepLearningDetection import DeepLearingDetection
File "d:\python3.6.5\lib\site-packages\PyInstaller\loader\pyimod03_importers.py", line 493, in exec_module exec(bytecode, module.__dict__)
File "DeepLearningDetection.py", line 5, in from openvino.inference_engine import IECore
File "openvino\inference_engine\__init__.py", line 1, in File "ie_api.pyx", line 24, in init openvino.inference_engine.ie_api
ModuleNotFoundError: No module named 'openvino.inference_engine.constants'
[18212] Failed to execute script main
To trace the problem, I used to following sample program (test.py) to test:
def load():
    ie = IECore()
    model_bin = "E:\\TrainFasterRCNNResnet50_V2\\OpenvinoModel\\frozen_inference_graph.bin"
    model_xml = "E:\\TrainFasterRCNNResnet50_V2\\OpenvinoModel\\frozen_inference_graph.xml"
    net = ie.read_network(model=model_xml, weights=model_bin)
    print("Device info: CPU")
    device="CPU"
    print("Loading model to the device")
    exec_net = ie.load_network(network=net, device_name=device)
    print(exec_net)
    print("model loaded")
load()
And then :
pyinstaller -F -add-data --add-data "C:\Program Files (x86)\IntelSWTools\openvino_2020.4.287\deployment_tools\inference_engine\bin\intel64\Release\plugins.xml;." test.py
However, when I executed the exe file, another errors came:
E:\PythonProgram\Openvino2Exe\dist>TestOpenvino.exe Traceback (most recent call last):
File "TestOpenvino.py", line 2, in File "d:\python3.6.5\lib\site-packages\PyInstaller\loader\pyimod03_importers.py", line 493, in exec_module exec(bytecode, module.__dict__)
File "openvino\inference_engine\__init__.py", line 1, in File "ie_api.pyx", line 16, in init openvino.inference_engine.ie_api
ModuleNotFoundError: No module named 'pathlib'
[12704] Failed to execute script TestOpenvino
Note that I have already installed the pathlib package and the it went fine when I execute test.py via python. I don't know why. Are there any instructions on how to package an openvino application into exe by pyinstaller?
