6605 Discussions
How to setup prepostprocessor if input tensor more than 4 dimensions in c++?
AlloyHsu
I have a model with input dimensions [1,1,224,224,3].
represents
[batch, frames, height, weight, channel]
How do I set the layout of my PrePostProcessor? Is the following correct?
// Try fill cv::Mat (BGR format to input tensor
ov::preprocess::PrePostProcessor ppp(model);
ppp.input("image").tensor().set_element_type(ov::element::u8).set_color_format(ov::preprocess::ColorFormat::BGR).set_layout("N?HWC");
ppp.input().preprocess().convert_element_type(ov::element::f32);
ppp.input().preprocess().scale({ 255.0, 255.0, 255.0 });
ppp.input().preprocess().convert_layout("NCHW");
ppp.input().preprocess().convert_color(ov::preprocess::ColorFormat::RGB);
model = ppp.build();
Vipin_S_Intel
Hi Alloy, could you please provide us with the following details?
  • The exact name and build version of the Intel® Toolkit you’re using.
  • The operating system and its build version.
  • Whether the product has been installed.
  • A detailed explanation of your query, along with a screenshot if possible.
To assist you further, we would require these details.
AlloyHsu
    w_openvino_toolkit_windows_2024.2.0.15519.5c0f38f83f6_x86_64
    WIN10 22H2
    Yes
    As above
Witold_Intel
Hi AlloyHsu,
we have a comment from the OpenVino developers. They ask "Why do you need "frames" dimension? can it be merged with "batch"?" Could you elaborate on that please? Thanks in advance.
AlloyHsu
I just want porting MoViNet Video Action Recognition which create by google.
MoViNet input dimensions are as follows: [batch_size, number_of_frames, height, width, channels]
Vipin_S_Intel
Hi Alloy, thank you for sharing the required information. We would like to inform you that we are routing your query to the dedicated team for further assistance.
Witold_Intel
@AloyHsu thank you for explaining the dimensions. I will share this information with the developers.
Witold_Intel
Hi @AloyHsu, there is a suggestion from the devs:
 Maybe you can try ppp.input().preprocess().convert_layout("N?CHW") ? OpenVINO does not know how to convert N?HWC to NCHW, because "?" dimension is unknown. Would this be a valid solution for you?
AlloyHsu
ppp.input().preprocess().convert_layout("N?HWC") work for me
Witold_Intel
Hi Alloy, this is great news. Do you need further support from us or can we close this case?
Witold_Intel
Hi Alloy, do you need further support from us? I will have to close this case if there is no response for 7 business days.
Zulkifli_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
