6574 Discussions
How to use pyinstaller packaging to a exe
niuwj
openvino version:2020.4.287
device:MYRIAD、 HDDL
How to use pyinstaller packaging to a exe with openvino.
there is the error:
File "test.py", line 12, in <module>
File "c:\users\niuwj\appdata\local\programs\python\python36\lib\site-packages\PyInstaller\loader\pyimod03_importers.py", line 493, in exec_module
exec(bytecode, module.__dict__)
File "openvino\inference_engine\__init__.py", line 1, in <module>
File "ie_api.pyx", line 24, in init openvino.inference_engine.ie_api
ModuleNotFoundError: No module named 'openvino.inference_engine.constants'
[2536] Failed to execute script test
there is the script:
import numpy
import logging as log
from openvino.inference_engine import IECore, IENetwork
def load():
ie = IECore()
model_bin = "result_yolov4_fp16/frozen_darknet_yolov4_model.bin"
model_xml = "result_yolov4_fp16/frozen_darknet_yolov4_model.xml"
net = ie.read_network(model=model_xml, weights=model_bin)
log.info("Device info: CPU")
device="MYRIAD"
log.info("Loading model to the device")
print("Loading model to the device")
exec_net = ie.load_network(network=net, device_name=device)
print(exec_net)
print("model loaded")
load()
and i can successfully run it by python test.py
<openvino.inference_engine.ie_api.ExecutableNetwork object at 0x000002239AD439A0>
model loaded
there is the command
pyinstaller -F --add-data "C:\Program Files (x86)\IntelSWTools\openvino_2020.4.287\deployment_tools\inference_engine\bin\intel64\Release\plugins.xml;." test.py
niuwj
Munesh_Intel
Hi Niu Wenju,
We are currently investigating this issue, and will get back to you.
Munesh
Munesh_Intel
Hi Niu Wenju,
Pyinstaller is not officially supported by OpenVINO, but we offer other options for similar deployment scenario: OpenVINO Deployment Manager, Conda installer, APT, and YUM.
I would suggest you try any one of those.
Munesh
Max_L_Intel
Hi @niuwj
Regardless the fact that OpenVINO toolkit does not officially support Pyinstaller, it might work on OpenVINO 2020.3 release.
We have reproduced the same error message that you see on 2020.4, however, please have a chance to try your model on 2020.3 (both plugins.xml and env variables setupvars.bat should be from 2020.3 package). We tested this with face-detection-retail-0005 and that worked.
You might also need to downgrade setuptools version with:
pip install --upgrade 'setuptools<45.0.0'
Hope this helps.
Munesh_Intel
Hi Niu Wenju,
This thread will no longer be monitored since we have provided a workaround. If you need any additional information from Intel, please submit a new question.
Munesh
GangXiong
Hi Niuwj,
I met the same problem. Have you found any solutions to this problem?
