6614 Discussions
I am getting Failed to initialize Inference Engine backend (device = GPU) error
hlreicha
This is the error I am receiving:
> Failed to initialize Inference Engine backend (device = GPU): Failed to create plugin /opt/intel/openvino_2021.4.752/deployment_tools/inference_engine/lib/intel64/libclDNNPlugin.so for device GPU
> Please, check your environment
> [CLDNN ERROR]. clGetPlatformIDs error -1001
Hardware:
  • I7-11700K,
  • MSI Tomahawk Z690 Motherboard,
  • 32GB 3200Mhz Cl14 Ram,
  • 1TB Nvme SSD,
  • and 750 watt PSU.
  • No dedicated GPU, using the iGPU.
Environment:
  • OS: Ubuntu 20.04 LTS
  • Running a Python 3.7 Environment in Conda and I am trying to inference an Efficientnet model I optimized through OpenVino with OpenCV on GPU.
  • I used FP16 during optimization.
Code:
import cv2
model = cv2.dnn.readNet(model_path)
model.setPreferableBackend(cv2.dnn.DNN_BACKEND_INFERENCE_ENGINE)
model.setPreferableTarget(cv2.dnn.DNN_TARGET_OPENCL_FP16 )
Attempted Fixes:
  • Reinstalled OpenVino
  • Reinstalled the OS/Environment
Further Notes:
  • I followed the directions and everything works fine on my I7 TigerLake NUC.
  • Additionally this runs fine when I try to inference on CPU as well.
Any insights on how I should fix this?
Peh_Intel
Hi hlreicha,
Please try to install the GPU driver version 21.29.20389 and see whether it can work. You can rerun the script in /opt/intel/openvino_2021/install_dependencies/ directory with the command below:
sudo -E ./install_NEO_OCL_driver.sh --install_driver 21.29.20389
If you still getting the error: [CLDNN ERROR]. clGetPlatformIDs error -1001, try to check and troubleshoot by referring to Driver issues troubleshooting.
Peh
Peh_Intel
Hi hlreicha,
This thread will no longer be monitored since we have provided solution and suggestion. If you need any additional information from Intel, please submit a new question.
Peh
