Model Optimizations for EfficientNet Lite?
automationbestest
I apologize in advance, I'm a bit new to the scene. I recently purchased an iNCS2 for a project I'm working on, because I have a few tflite models I would like to run faster on my raspberry pi.
I believe I have correctly set up my raspberry pi by following the directions on the Intel website, and I have also installed the OpenVINO toolkit for my Windows 11 PC through Anaconda. Now, I'm wondering what are the next steps to optimizing my models? I've been looking around the forums and online and I'm seeing a lot of support for TF models, but not so many TFLite models. Help would be greatly appreciated! As I said, I am new to this, so please bear with me.
Thanks!
Hairul_Intel
Hi automationbestest,
Here is the comprehensive guide on how to Convert TensorFlow Model using Model Optimizer. Additionally, here is the list of Supported Topologies for TensorFlow framework for OpenVINO.
Model Optimizer does not support .tflite file to IR format conversion natively. Model Optimizer currently only supports few frozen quantized topologies hosted on TensorFlow Lite site. This information is available in the subsection "Supported Frozen Quantized Topologies" under the section Supported Topologies.
However, the frozen model file (.pb file) is required for conversion to IR format by Model Optimizer. It is also necessary to use these specific command line parameters for the Model Optimizer (HEIGHT and WIDTH are the input images height and width for which the model was trained):
  • --input input
  • --input_shape [1,HEIGHT,WIDTH,3]
These information are also mentioned at the above link.
Hairul
Hairul_Intel
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Hairul
