6605 Discussions
I have a tensorflow PB file and mvNCCompile fails creating a graph
Now what? -- Background I created a graph using retrain.py from tensorflow for poets
the pb file looked like it build correctly. I also have a label file.
So I thought I would try and build a graph. Ran this.
sudo mvNCCompile deeplearning_graph.pb -s 12 -o deeplearn.graph
It failed miserably. I no linux or python expert but it looks like I am missing
files. Anyone have a how to compile this graph?
Traceback (most recent call last):
File "/usr/local/bin/mvNCCompile", line 35, in
from Controllers.Scheduler import load_myriad_config, load_network
File "/usr/local/bin/ncsdk/Controllers/Scheduler.py", line 25, in
from Controllers.Optimizer import postParsingOptimizations, selectImplementations, streamEverythingSchedule, fixTensors
File "/usr/local/bin/ncsdk/Controllers/Optimizer.py", line 25, in
from Controllers.Parsers.Parser.Convert import Convert
File "/usr/local/bin/ncsdk/Controllers/Parsers/init.py", line 3, in
from .Caffe import loadNetworkObjects, parse
File "/usr/local/bin/ncsdk/Controllers/Parsers/Caffe.py", line 30, in
import caffe
ImportError: No module named 'caffe'
Sorry thought it would just work.
Did a quick search and my
echo %PYTHONPATH comes back as
:/opt/movidius/caffe/python
Read as many examples and trouble shooting guides and have no idea why this has an error.
From the page
https://movidius.github.io/ncsdk/tools/compile.html
Using a PB file should be OK.
TensorFlow:
network.meta
network.pb
As for the rest I do not even think I got that far.
I re-ran the make for example in NCSAPPZOO
so now I am at a loss. Are there any more reasons this would not even try to compile
@chicagobob123 Strange that you are using a TensorFlow model but you're having Caffe import errors. Anyway, if you are using the Tensorflow for poets from Pete Warden's blog, he uses some TensorFlow ops that we don't support, so if you're using his version, it won't work.
Thanks, well now I have several questions.
Since I can't retrain an inceptionV3 graph using retrain.py and use the pb file. Heck I can not even get mvNCCompile to even try. What do I do now?
What is the Movidius way to retrain a graph and get good recognition?
