ICL redistributable version
aag
Which version of ICL runtime is required to run 2020.1 inference engine? Is there a specific place where that requirement is documented?
Max_L_Intel
Hello Alex A.
If you are installing Inference Engine from the OpenVINO toolkit installer, then you don't need to install redistributable files for Intel C++ compiler separately.
But if you want to transfer the installed Inference Engine binaries to another machine without running OpenVINO installer there, in that case you need them. Please just use the latest 64-bit version from this page - https://software.intel.com/en-us/articles/intel-compilers-redistributable-libraries-by-version
Best regards, Max.
