6590 Discussions
IE Version Incompatibility issue in CMake [ OPENVINO 2021.4 ]
resh
While building the package https://github.com/intel/ros_openvino_toolkit , I get the version incompatibility issue of IE.
Openvino Toolkit version being used is 2021.4, Should I be downgrading the Openvino Toolkit version?
Wan_Intel
Hi Resh,
We are investigating this issue and will update you at the earliest.
Wan
Wan_Intel
Hi Resh,
For your information, ros_openvino_toolkit does support the older version of OpenVINO.
Release based with OpenVINO open-source version at tag 2018_R5 is available on the following page:
https://github.com/intel/ros_openvino_toolkit/releases/tag/0.5.0_R5
Steps to set up the environment is available on the following page:
https://github.com/intel/ros_openvino_toolkit/blob/0.5.0_R5/doc/OPEN_SOURCE_CODE_README.md
For more information on ros_openvino_toolkit, you can open the ticket here.
Wan
Wan_Intel
Hi Resh,
This thread will no longer be monitored since we have provided a solution.
If you need any additional information from Intel, please submit a new question.
Wan
