Illegal instruction (core dumped) at load_network in OpenVino
Chew__Ryan
Used OpenVino to run Tensorflow model on CPU.
OpenVino installation went well and could run all test demos.
I could convert tensorflow inference model to OpenVino model .bin and .xml files successfully.
But when I run the OpenVino model, I have Illegal instruction (core dumped) error at loading network.
self.exec_net = self.ie.load_network(network=self.net, device_name=self.device)
My OpenVino version is openvino_2019.2.275. Tested with latest version, but had same error.
My python is 3.5 version and OS is Ubuntu16.04.
What could be the issue using OpenVINO.
Luis_at_Intel
Hi Chew, Ryan,
Thanks for reaching out. I am not sure what could be happening, if you can share more details about the model being used it would be a great start.
If you are writing your own code in Python*, I would strongly suggest to take a look at the samples available for reference. This should give you a pretty good idea on how things work and compare with your program. Find the samples for your reference here.
Luis
Chew__Ryan
Hi
Here are more details.
i have an error while network loading in python.
https://drive.google.com/drive/folders/1j3JnPXP_wK8BQZbh9IGnox5baUsH1-7a?usp=sharing
SuryaPSC_Intel
Hi Chew, Ryan,
As suggested by Luis, I tried loading your model using segmentation_demo.py and it loaded successfully. Attached the screenshot for the same.
Kindly refer network loading section of segmentation_demo.py.
Let us know if the issue persists.
Surya
