Image Segmentation OpenVino + MYRIAD
Rasheed__Umer
Hi
I came across this very handy tutorial for image segmentation last week:
https://software.intel.com/en-us/articles/intel-distribution-of-openvino-toolkit-image-segmentation-walkthrough-in-python
It works perfectly on CPU. However, since I wanted to test this on NCS device, I changed the step 13 in the link above to (Change is highlighted in red):
python3 mo_caffe.py --input_model ~/fcn.berkeleyvision.org/voc-fcn8s/fcn8s-heavy-pascal.caffemodel --input_proto ~/fcn.berkeleyvision.org/voc-fcn8s/deploy.prototxt -o ~/seg-sample --data_type FP16
This converted the model to FP16 instead of FP32. However, when I run the model for inference using the command below:
python3 segmentation_sample.py -i camvid.png -m ~/seg-sample/fp16/fcn8s-heavy-pascal.xml -d MYRIAD
I get this error on NCS:
[ INFO ] Loading network files:
/home/avidbots/seg-sample/fp16/fcn8s-heavy-pascal.xml
/home/avidbots/seg-sample/fp16/fcn8s-heavy-pascal.bin
Device: MYRIAD
[ INFO ] Preparing input blobs
[ WARNING ] Image camvid.png is resized from (720, 960) to (500, 500)
[ INFO ] Batch size is 1
[ INFO ] Loading model to the plugin
[ INFO ] Starting inference (1 iterations)
E: [xLink] [         0] dispatcherWaitEventComplete:694 waiting is timeout, sending reset remote event
E: [ncAPI] [         0] ncFifoReadElem:2853 Packet reading is failed.
Traceback (most recent call last):
  File "segmentation_sample.py", line 156, in <module>
    main() #sys.exit(main() or 0)
  File "segmentation_sample.py", line 126, in main
    res = exec_net.infer(inputs={input_blob: images})
  File "ie_api.pyx", line 130, in inference_engine.ie_api.ExecutableNetwork.infer
  File "ie_api.pyx", line 160, in inference_engine.ie_api.InferRequest.infer
  File "ie_api.pyx", line 164, in inference_engine.ie_api.InferRequest.infer
RuntimeError: Failed to read output from FIFO: NC_ERROR
/teamcity/work/scoring_engine_build/releases_openvino-2018-r4/ie_bridges/python/inference_engine/ie_api_impl.cpp:329
And this error on NCS2:
Device: MYRIAD
E: [xLink] [         0] handleIncomingEvent:240 handleIncomingEvent() Read failed -4
E: [xLink] [         0] dispatcherEventReceive:308 dispatcherEventReceive() Read failed -4 | event 0x7fdc71312ef0 USB_WRITE_REQ
E: [xLink] [         0] eventReader:254 eventReader stopped
E: [ncAPI] [         0] ncGraphAllocate:1227 Can't read input tensor descriptors of the graph, rc: X_LINK_TIMEOUT
  File "segmentation_sample.py", line 118, in main
    exec_net = plugin.load(network=net)
  File "ie_api.pyx", line 305, in inference_engine.ie_api.IEPlugin.load
  File "ie_api.pyx", line 318, in inference_engine.ie_api.IEPlugin.load
RuntimeError: Failed to allocate graph: NC_TIMEOUT
cpp:260
Umer Rasheed
