6584 Discussions
InvalidArgumentError: You must feed a value for placeholder tensor 'input' with dtype float
I have been facing this error when I am trying to convert a tensorflow model to graph file. I have optimized the model using bazel and froze the graph using gFile function present in tensorflow.
mvNCCheck optimized_graph1.pb -s 12 -in input_input -on output/Softmax -is 28 28
mvNCCheck v02.00, Copyright @ Movidius Ltd 2016
/home/ramreddyy/.local/lib/python3.5/site-packages/tensorflow/python/util/tf_inspect.py:75: DeprecationWarning: inspect.getargspec() is deprecated, use inspect.signature() instead
return _inspect.getargspec(target)
Traceback (most recent call last):
File "/home/ramreddyy/.local/lib/python3.5/site-packages/tensorflow/python/client/session.py", line 1334, in _do_call
return fn(*args)
File "/home/ramreddyy/.local/lib/python3.5/site-packages/tensorflow/python/client/session.py", line 1319, in _run_fn
options, feed_dict, fetch_list, target_list, run_metadata)
File "/home/ramreddyy/.local/lib/python3.5/site-packages/tensorflow/python/client/session.py", line 1407, in _call_tf_sessionrun
run_metadata)
tensorflow.python.framework.errors_impl.InvalidArgumentError: You must feed a value for placeholder tensor 'input_input' with dtype float and shape [?,28,28,1]
[[{{node input_input}} = Placeholder[dtype=DT_FLOAT, shape=[?,28,28,1], _device="/job:localhost/replica:0/task:0/device:CPU:0"]()]]
During handling of the above exception, another exception occurred:
File "/usr/local/bin/mvNCCheck", line 152, in
quit_code = check_net(args.network, args.image, args.inputnode, args.outputnode, args.nshaves, args.inputsize, args.weights, args)
File "/usr/local/bin/mvNCCheck", line 130, in check_net
net = parse_tensor(args, myriad_config, file_gen=True)
File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 1059, in parse_tensor
desired_shape = node.inputs[1].eval()
File "/home/ramreddyy/.local/lib/python3.5/site-packages/tensorflow/python/framework/ops.py", line 713, in eval
return _eval_using_default_session(self, feed_dict, self.graph, session)
File "/home/ramreddyy/.local/lib/python3.5/site-packages/tensorflow/python/framework/ops.py", line 5157, in _eval_using_default_session
return session.run(tensors, feed_dict)
File "/home/ramreddyy/.local/lib/python3.5/site-packages/tensorflow/python/client/session.py", line 929, in run
run_metadata_ptr)
File "/home/ramreddyy/.local/lib/python3.5/site-packages/tensorflow/python/client/session.py", line 1152, in _run
feed_dict_tensor, options, run_metadata)
File "/home/ramreddyy/.local/lib/python3.5/site-packages/tensorflow/python/client/session.py", line 1328, in _do_run
run_metadata)
File "/home/ramreddyy/.local/lib/python3.5/site-packages/tensorflow/python/client/session.py", line 1348, in _do_call
raise type(e)(node_def, op, message)
[[node input_input (defined at /usr/local/bin/ncsdk/Controllers/TensorFlowParser.py:211) = Placeholder[dtype=DT_FLOAT, shape=[?,28,28,1], _device="/job:localhost/replica:0/task:0/device:CPU:0"]()]]
Caused by op 'input_input', defined at:
File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 211, in parse_tensor
tf.import_graph_def(graph_def, name="")
File "/home/ramreddyy/.local/lib/python3.5/site-packages/tensorflow/python/util/deprecation.py", line 488, in new_func
return func(*args, **kwargs)
File "/home/ramreddyy/.local/lib/python3.5/site-packages/tensorflow/python/framework/importer.py", line 442, in import_graph_def
_ProcessNewOps(graph)
File "/home/ramreddyy/.local/lib/python3.5/site-packages/tensorflow/python/framework/importer.py", line 234, in _ProcessNewOps
for new_op in graph._add_new_tf_operations(compute_devices=False): # pylint: disable=protected-access
File "/home/ramreddyy/.local/lib/python3.5/site-packages/tensorflow/python/framework/ops.py", line 3440, in _add_new_tf_operations
for c_op in c_api_util.new_tf_operations(self)
File "/home/ramreddyy/.local/lib/python3.5/site-packages/tensorflow/python/framework/ops.py", line 3299, in _create_op_from_tf_operation
ret = Operation(c_op, self)
File "/home/ramreddyy/.local/lib/python3.5/site-packages/tensorflow/python/framework/ops.py", line 1770, in init
self._traceback = tf_stack.extract_stack()
InvalidArgumentError (see above for traceback): You must feed a value for placeholder tensor 'input_input' with dtype float and shape [?,28,28,1]
@Tome_at_Intel Can you help me out in resolving above error?
Thanks in advance.
