Importing openvino (python) in AWS lambda
FrancescoG
When trying to import openvino 2024/4 in a AWS Lambda function, I get the following error:
Exception: Failed to find location of the openvino_telemetry file.
I tried to manually install openvino_telemetry, but didn't solve the problem.
Note that if I use openvino 2023/3 instead, I can import it correctly without any further change in the code.
Any idea of how to fix this problem?
Wan_Intel
Hi FrancescoG,
The error you encountered is similar to a GitHub thread on the following page:
https://github.com/openvinotoolkit/openvino/issues/26988
Our developers are working on it and they will provide an update on the GitHub thread above. Sorry for the inconvenience and thank you for your support.
Sincerely,
Wan
FrancescoG
Hi Wan,
thanks for replying, looking forward to hearing for some updates on this.
Francesco
Wan_Intel
Hi FrancescoG,
Thanks for your question.
If you need additional information from Intel, please submit a new thread as this thread will no longer be monitored.
Wan
