model server not working models/resnet50
Scuba
Hey folks,
My model server is not coming up, this was working fine couple of months back and now stopped working, any insights
I am using this repo wget //storage.openvinotoolkit.org/repositories/open_model_zoo/2022.1/models_bin/2/resnet50-binary-0001/FP32-INT1/resnet50-binary-0001.{xml,bin} -P models/resnet50/1
sudo docker-compose down
sudo docker-compose up
WARN[0000] /home/fedora/docker-compose.yml: the attribute `version` is obsolete, it will be ignored, please remove it to avoid potential confusion
[+] Running 0/0
Network fedora_default  Creating                                                      0.1s
WARN[0000] Found orphan containers ([fedora-resnet3-1 fedora-resnet6-1 fedora-resnet5-1 fedora-resnet4-1 fedora-resnet8-1 fedora-resnet7-1 fedora-resnet2-1]) for this project. If you remov[+] Running 2/2his service in your compose file, you can run this command with the --remove-or Network fedora_default      Created                                                   0.1s
Container fedora-resnet1-1  Created                                                   0.1s
Attaching to resnet1-1
resnet1-1  | [2024-11-01 22:07:42.262][1][serving][info][server.cpp:75] OpenVINO Model Server 2024.4.28219825c
resnet1-1  | [2024-11-01 22:07:42.262][1][serving][info][server.cpp:76] OpenVINO backend c3152d32c9c7
resnet1-1  | [2024-11-01 22:07:42.262][1][serving][info][pythoninterpretermodule.cpp:35] PythonInterpreterModule starting
resnet1-1  | [2024-11-01 22:07:42.368][1][serving][info][pythoninterpretermodule.cpp:46] PythonInterpreterModule started
resnet1-1  | [2024-11-01 22:07:42.382][1][modelmanager][info][modelmanager.cpp:125] Available devices for Open VINO: CPU
resnet1-1  | [2024-11-01 22:07:42.382][1][serving][info][grpcservermodule.cpp:122] GRPCServerModule starting
resnet1-1  | [2024-11-01 22:07:42.383][1][serving][info][grpcservermodule.cpp:191] GRPCServerModule started
resnet1-1  | [2024-11-01 22:07:42.383][1][serving][info][grpcservermodule.cpp:192] Started gRPC server on port 9001
resnet1-1  | [2024-11-01 22:07:42.383][1][serving][info][servablemanagermodule.cpp:51] ServableManagerModule starting
resnet1-1  | [2024-11-01 22:07:42.383][1][modelmanager][error][modelmanager.cpp:1316] Couldn't list directories in path: /models/resnet50
resnet1-1  | [2024-11-01 22:07:42.383][1][modelmanager][error][modelmanager.cpp:157] Couldn't start model manager
resnet1-1  | [2024-11-01 22:07:42.383][1][serving][error][servablemanagermodule.cpp:58] ovms::ModelManager::Start() Error: The provided base path is invalid or doesn't exists
resnet1-1  | [2024-11-01 22:07:42.383][1][serving][info][grpcservermodule.cpp:200] GRPCServerModule shutting down
resnet1-1  | [2024-11-01 22:07:42.383][1][serving][info][grpcservermodule.cpp:205] Shutdown gRPC server
resnet1-1  | [2024-11-01 22:07:42.383][1][serving][info][grpcservermodule.cpp:209] GRPCServerModule shutdown
resnet1-1  | [2024-11-01 22:07:42.383][1][serving][info][servablemanagermodule.cpp:65] ServableManagerModule shutting down
resnet1-1  | [2024-11-01 22:07:42.384][1][serving][info][servablemanagermodule.cpp:71] ServableManagerModule shutdown
resnet1-1  | [2024-11-01 22:07:42.384][1][serving][info][pythoninterpretermodule.cpp:57] PythonInterpreterModule shutting down
resnet1-1  | [2024-11-01 22:07:42.384][1][serving][info][pythoninterpretermodule.cpp:62] PythonInterpreterModule shutdown
resnet1-1  | Python version
resnet1-1  | 3.10.12 (main, Sep 11 2024, 15:47:36) [GCC 11.4.0]
resnet1-1 exited with code 1
[fedora@fedora-vm-100g ~]$
[fedora@fedora-vm-100g ~]$ cat docker-compose.yml
version: '3'
services:
  resnet1:
    image: openvino/model_server:latest
    command: >
      --model_name resnet
      --model_path /models/resnet50
      --layout NHWC:NCHW
      --port 9001
    volumes:
      - /home/fedora/models:/models
    ports:
      - "9001:9001"
Wan_Intel
Hi Scuba,
To further investigate the issue, could you please provide us with the information as follows:
  • Hardware specifications
  • Host operating system
  • Python version
On the other hand, could you please add the following command when launching OpenVINO™ Model Server?
--log_level=DEBUG
Wan
Wan_Intel
Hi Scuba,
Thanks for your question.
If you need additional information from Intel, please submit a new question as this thread will no longer be monitored.
Wan
