Inception-V3 graph file
I have try to use mvNCCompile toolkit to compile the inception-v3 pb file to graph file, with in=input and on= the Reshape_1 layer, I have finished compiling, but the graph file cannot be used by movidius,
Can anyone provide me with the graph file of inception-v3 with Reshape_1 as the output (the tensor before the softmax layer)?
@zgdsh29 If you checkout the Inception_v3 example code on the ncappzoo, the Makefile compiles the graph file using the Reshape_1 layer as the output node. See the Inception V3 Makefile line number 19.
Thank you Tome for the reply Actually I only need the graph file, could you please send me?
